Question about Canon PIXMA iP5300 InkJet Photo Printer
Canon ip5300 orange flash 10 times
I've changed printer cartridges, turned power on and off etc - but cant get the printer to work. The orange led flashes 10 times.
silly girl
  • 513 Answers
SOURCE: Canon BJC 6000 Beeps and Power Light Flashes Orange
The 6 beeps along with the orange light stands for "Re-install BJ cartridge or replace it". You might have already fixed the problem by replacing the cartridge, and you're still stuck with the error indication. Waste Error Reset 1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 6: Press Power to set data If it still doesn't go away, try cleaning the contacts the cartridge makes with the printhead. Dip the carts contacts(dipping only the contact area) in shallow hot water for a minute, then wipe dry with a cloth that doesn't shed fiber. Also clean the contacts on the printhead using a damp cloth, maybe also some alcohol. If it still doesn't go away you have to think of replacing the printhead, or chucking it. Good luck
Posted on Jun 22, 2006
SOURCE: CANON IP 1880
i need install canon ip1880.. how?
Posted on Oct 05, 2008
devdeep545
  • 137 Answers
SOURCE: why flash by 5 times the orange led?
Probably your waste ink counter should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Good Luck, I hope this helps?!
Posted on Aug 12, 2009
cene765
  • 787 Answers
SOURCE: My canon ip1880 printer orange light flashing 7 times.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
Posted on Oct 19, 2009
  • 37 Answers
SOURCE: canon ip5300 b200 error message unplugged and
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Posted on Aug 02, 2010
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
How do I reset the print cartridge on an IP5300?
Word to the wise, NEVER EVER use refilled or non OEM cartridges in any printer! They can do serious damage and you end up buying a whole new printer by trying to save a few bucks on the front end. I used to work for a national chain where we pushed our own after market cartridges. Even at that time I knew what headaches and heartaches it caused. I still directed people pass our own company cartridges straight to HP, Canon, Lexmark, or whomever. Try buying a Canon cartridge and hopefully this will fix it.
Oct 20, 2012 | Canon PIXMA iP5300 InkJet Photo Printer
The printer is not working. the orange light flashes five times.. how to solve this problem?
cartidge cannot be recognized ma'am. try to change the color cartridge ma'am. by: cris
Sep 28, 2012 | Canon Pixma iP2700 InkJet Photo Printer
Ip5300 fault light flashing
Hi Good day!! I think the problem is that the waste ink tank is full and you need to reset it..
Please try these steps. and hope it works..
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
To actually drain the waste ink tank, you'll need to take your printer to pieces and find, clean, wash and dry the felt pads found in the base of the printer. This is a complicated procedure, but it is a good idea to do it if you're technically minded. Many people have just reset the code without actually draining the pads and very few have run into problems as a result. If you do this, you risk damaging your printer and/or the surface it sits on if the pads absorb too much ink. However, if you're going to buy a new printer anyway, you might just reset the code and stand it on a piece of paper or card. It's up to you, just understand the risks.
Thank you
Aug 29, 2012 | Canon PIXMA iP5300 InkJet Photo Printer
I've changed the ink cartidges but the black and color ink lights remain on and it won't print. I think the E2 error message is on.
This hapens when refilled cartridges are installed in the printer. To rectify the problem, look for the 'Resume button' normally black with a red circle around an arrow head pointing towards you. With the printer powered on, press and hold this button down for about 10 seconds. The error code will usually clear and the printer will print but the orange lights will still flash.
Sep 11, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Hello , I'm using Canon MP160 for windows XP bit 32 ... I can't scan or print ... The printer flashes E22 .. What should i do ? healp please .. thanks !
E22 means cartridge error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
May 17, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber - what is it and how do we rep[lace it?
plz try
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) [hth: I believe the power button has to be pressed once more after cycling the alarm button to complete the action. The power/resume-cancel button LEDs toggle to help you count.]
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is not installed, the
carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print See 3-4. Verification Items, (1) Service test print.
2 times Green (Power) EEPROM information print
See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange (Alarm) EEPROM initialization [hth: does not re-initialize Waste ink counter]
>>>> 4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings [hth: not applicable]
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
[hth: 7-10 not applicable]
11 to 13 times Orange, Green, Orange (Alarm, Power, Alarm) Return to the menu selection
14 not used in servicing
15 Orange (alarm) return to the menu selection,.
Note: If the Resume/Cancel button is pressed 16 or more times, the Alarm or Power LED lights steadily without
any changes.
Note : if the alarm light is flashing 15 times at turn-on [cartridge not recognized error], none of these procedures seem to work.
Aug 26, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Printer reads "Waste Ink Near Full"
www.fixyourownprinter.com/forums/inkjet/50418
The above link will assist you.
any changes.
[hth: if the alarm light is flashing 15 times at turn-on [cartridge not recognized error], none of these procedures seem to work. If anyone knows how to defeat this error, I would like to know.]
Aug 24, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Hi My Canon Pixma iP5300 injet printer will not...
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
May 21, 2010 | Canon PIXMA iP5300 InkJet Photo Printer
Error 5B00 trying to get to service mode to reset waste ink code but need to bypass the alarm mode.
Hello there..
Here is how you fix this error:
any changes.
I really hope this can help you.
Best regards
Andrea
Oct 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA iP5300 InkJet Photo Printer Logo
180 people viewed this question
old marine
old marine
