Question about Whirlpool Microwave Ovens
Microwave oven runs but dont give heat
Whirlpool xt-20ms/w oven is running but not giving heat
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave ahs power but doesn't heat.
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Sep 28, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven
Yes, it could be. The first thing to try is a "hard reset".
Unplug it from the power line for a few minutes, plug it back in, then try again.
Let us know if the hard reset doen't fix it.
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
SOURCE: Sylvania microwave
my sylvania mircro wave doesnt shut off after i use it. it is healing---just rnning with th light on. i have to unplug it to stop it and then plug it bak in when i want o use it. can i repair it?
Posted on Jul 22, 2008
scottowa
  • 87 Answers
SOURCE: Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523111.pdf
Labor to replace it would be about $125
Posted on Mar 04, 2009
SOURCE: oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Posted on Apr 17, 2009
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Set oven for cooking time, on setting 900 ,but only comes on for 4 seconds. I have tried the same on 600 it will run but does not heat
GO IN CONTACT WITH THE MAKER OF THE OVEN..AND DONT FORGET TO GIVE THEM THE MODEL NUMBER..AND IF STILL NEW UR RECEIPT AS IT WILL COVER UR WARENTY...
Oct 18, 2013 | Neff H5430 Convection Microwave Oven
Whirlpool microwave model GT4175SPB-2: sounds like it is running properly but is not heating up
No! by all indicators it is the magnetron and a tricky replacement. The cost to repair should be measured against a new one.
Apr 04, 2012 | Whirlpool Microwave Ovens
Buzzing sound when you turn on .also smells like burning
The magnetron is failing, "heats food" and in some cases gives off a burning smell, "classic symptom" repairs will run close to a new microwave oven or more.
Jun 07, 2011 | Whirlpool MH7140XF Microwave Oven
Microwave Whirlpool accuwave still runs but does not heat, can this be fixed?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 31, 2011 | Whirlpool Accuwave Microwave Oven
Blue spark come out of vent now it dont heat?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 19, 2011 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Microwave is still running when the door is open
The cooling fans run for a time after the magnatrons have stopped, The magnatrons are the heating components so I dont think you are in any danger as the microwave doors are double locked so the magnatrons cant run once the door is open
Sep 27, 2009 | Panasonic Microwave Ovens
Microwave runs but does not heat--is is repairable???
I replied to your other post as well: It could be any multitude of issues from a faulty magnetron,a bad high voltage diode, a door switch issue or a faulty circuit board. A magnetron for your model is ~ the $60 area. A Circuit board is ~ the $100.00 mark. If your a wiz at electronics I would say give it a go and try to repair it yourself. Otherwise I would say that a new microwave oven would be your best bet. A technician may charge you up to $250 for the work they will do, bringing you to around the same cost of a new microwave with a warranty. Hope this helps. P.S. If you are interested in buying the parts and fixing it yourself, may I recommend this site: http://www.repairclinic.com They are top notch and really helpful.
Jul 26, 2007 | Whirlpool MH1150XMQ Microwave Oven
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
