Question about Franke Evolution
My franke evolution reads eo44 motor time out how do I repair?
Franke evolution error steam supply
wich nr does appear? 030, 032?
Sep 06, 2014 | Franke Evolution
Error 44 time out motor
Could be faulty design.
Apr 17, 2014 | Franke Evolution
Franke evolution no install card
try ebay. password for card once entered is 1000 or 0001. install cards are only given to franke trained engineers.
Jan 08, 2014 | Franke Evolution
Need a service manual for franke evolution
I hope this is the one you are looking for.
http://www.xpresscoffeeuk.co.uk/pdf/evolution_plus_manual.pdf
Nov 13, 2012 | Franke Evolution
I have a Franke Evolution machine and it's giving me a fault code 3 on the modaul board in it and I do not have a manual top know what is that code and michine is not working.
Hi. I think it a pump problem. You would have to take the panels off and check the pump. The evolution may have two pumps, so swapping the terminals on the pump may help you in findingthe fault. Dazza REPAIRER
Sep 22, 2011 | Franke Evolution
Not a problem more of a question. Is the Franke evolution espresso machine a water processed machine? Also what does that mean for it to be water processed? THnak yOu
the evolution is a super automatic ,im not sure what you mean by water processed? but i do know you need water with a low ppm of hardness or you risk ruining the machine. water processed refers to the way beans are prepared, usually decaf.
Sep 05, 2011 | Franke Evolution
We have a Franke Evolution coffee machine and the fault 'E43 Motor Time Out' error keeps appearing. Could you please advise me what this fault is. Is it related to the upper head micro switches and if so...
E43 error motortime out refers to the brew unit not being "sensed" by the micro switch, the most common fault is the micro switch failing. other causes are the failure of the brewmotor itself, or bushes within the brewer. The micro switch is simple to replace as its obvious withits location. the other however will require the expertise of an engineer.
Sep 30, 2010 | Franke Evolution
Coffee Makers & Espresso Machines Logo
442 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
frankecoffee
Level 1 Expert
Jay Finke
Jay Finke
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
