Question about Maytag Washing Machines
Mav408daww leaking out of plastic tub liner - Maytag Washing Machines
  • 1073 Answers
SOURCE: water is leaking from washer
you also need to replace the stem and seal kit and the bearing kit you also have to have a spanner toll to remove the stem and install the new one aint gonna be a cheap repair but you do have a good maytag washer that is nolonger produced
Posted on Apr 25, 2008
Maytag317
  • 1136 Answers
SOURCE: My Whirlpool washer leaks when filling. We have located that it leaks from the plastic liner. Therefore leaking water onto floor.
Hi, The plastic liner you are talking about, is it the outer tub? If you could get me a model#, I could look this up for you.
Please let me know if I can help.
Vic
Posted on Jun 01, 2009
  • 1937 Answers
SOURCE: HOW DO I REMOVE THE OUTER TUB PLASTIC LINER ON A
First, see the Sears parts site for your washer with detailed diagrams of all the components.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24642300
Then see the following for how to remove the cabinet and agitators.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
In order to get the agitators out, you need to remove the "Spanner Nut" and "Drive Block".
Many instructions call for a special spanner wrench to remove the nut. However,
You don't need a special spanner wrench. (About $20 retail)
I've used a short 10" pipe wrench (About $9 also good for cracking walnuts) hooked around one of the tabs on the spanner nut and tapped the handle with a hammer to loosen it.
Also, don't directly hit the drive block with a hammer (it's soft metal). Put a short piece of wood under the drive block and tap it up with a hammer.
It's probably easier to get to the bearings and seal at the base of the tub after pulling the pump, motor and gearcase. A close look at the sears diagrams should give you a good idea of how to do it.
Posted on Jan 27, 2010
  • 30 Answers
SOURCE: The washer leaks thru the door. The plastic liner
replace damaged parts
Posted on Apr 22, 2010
  • 1937 Answers
SOURCE: I have a Kenmore Series 70 top loading wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The numbers following the 110 (which means it's made by Whirlpool) are usually 8 digits. Using the number that you provided, I couldn't find your washer on the Sears site. You will want to verify the number (usually by lifting the lid) and/or check for manuals / parts site from the following Sears site:
http://www.managemyhome.com/
Sears has replacement tubs (at least for my 12 year old top load for about $116.75 (U.S.) but you may be able to get one from Whirlpool for about the same cost. If you can get to the diagrams on the sears site. they often have "Manufacturer Authorized Substitutes) which are Whirlpool numbers.
FOR EXAMPLE, SEE THE SITE FOR OUR WASHER AND YOU'LL SEE EXAMPLES OF PARTS, DIAGRAMS AND COSTS.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26902691&pop=flush
Posted on Jun 22, 2010
Where can I buy a removable drum liner insert for a washing machine?
There are a number of detergent plastic drum (200ltrs) availble from drum recyclers and you can also get 1000ltr plastic tanks made for your purpose from plastic tank manafacturers.
Mar 11, 2013 | Maytag Neptune Washing Machines
Spin cycle problem
I suspect you definitely have a clutch problem. It might be the liner or it could be the transmission seal leaked some oil into the clutch you would know it by the oil on the cabinet74eb356.jpgThats a hint of a clutch problem with leaky top seal. An easy fix.ef45d86.jpgthe newer washer have a square recess you unscrew and lift the top of the agitator off and then you have access to the bolt that holds the lower portion on. The agitator has to come out first then drop the tranny
(3 bolts) Put the tranny on a bench. You can use a pair of pliers and squeeze the spring and the clutch liner comes right out. You can buy just the liner, no need to buy the kit but you can do that too. None of the parts are expensive and anybody can do these repairs.
Apr 16, 2010 | Kenmore 24962 Top Load Washer
Vic
Jun 01, 2009 | Washing Machines
Leaking around center spindle gasket of outer plastic basket
There was a hole in the plastic liner tub from the inner metal basket rubbing on it during the spin cycle. I got some plastic cement and put it in there and it willl hold for a little while while anyway. Not a very well designed washer when you look into the guts of the monster.
Feb 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
I have the inner basket out of a Whirlpool LSR5132PQ Top Load Washerand I filled it with water to see water dripping out around the rubber gasket? in the center of the outer plastic liner basket. I'm...
wow ok you have there srprnigs to remove on the right side remove the clip spring by removing the 1/4 in nut driver head screw,,and do the same for the lef side,,,noe you have 1 more spring in the rear,,the counter balance spring this has 2 screws remove them,,now on the right side remove your pressure switch hose...go to the bottom of tub and remove your tub to pump hose..ok nw left hold tub up and twist back and forth and pull at the same time...reverse to put together..onthejob
Maytag Legacy washer MAV408DAWW loud noise, dumped all water
Tub bearings and seal have failed. My SAV405DAWW just started with the loud grinding and I am now in the process of finding out if I can fix it myself. Kurt
Jan 12, 2009 | Maytag Legacy Top Load Washer
Water is leaking from washer during spin cycles and bottom of tub liner has rusted out and looks like it needs to be replaced. Need to know where to buy a replacement liner for the Maytag tub we have
Apr 25, 2008 | Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
