Question about Blenders
How do I reset my Breville Motiv 700 blender?
How do I reset my Breville Motiv 700 watts blender. The power comes on, lights on but buttons not responsive.
  • 142 Answers
SOURCE: Intelli blender will not work
Do you hear it hum when you try to turn it on?
If yes, remove the cup. Try again... if the motor runs, try moving the blade by hand. If it is seized, remove it and clean it to free it again.
If not, possibly blown windings on the motor or divider circuit (which supplies different voltages to the motor for the different blend speeds). Repair will be required in either case.
Posted on Mar 24, 2008
SOURCE: Blender is not doing anything
I have had my blender sitting for over a year ( only used it once ) because of the same problem and asked my husband to take a look at it... he opened it ... cut the zip ties took the metal banding off ( note only one side of the motor has the metal banding). What you need to get at is behind the first (I think) resistor. Behind that is a thermal fuse (found at radio shack part # 270-1320 about $1.96). you will need some kind of tester to check the ohms going through it (should read zero) the bad one on mine read 334 ohms and you will need a soldering iron to put it back together. Actually a good project for someone who loves to tinker with this. Also note the shaft of the motor for turning the blender blade screws off be careful not to pull at it. Hope this helps.
Posted on Jun 29, 2008
SOURCE: Any idea where we can get a new jug for a breville blender?
This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
http://www.brevilleusa.com/home.do
Posted on Jan 21, 2009
SOURCE: blender will not run. the power button is lite but
There is a 10 Amp thermal fuse (SF129E) that is supposed to create an open circuit when the motor windings exceed 133 C degrees. Although this fuse should close again when the motor cools down it can become perminantly damaged. Locate the fuse by following the black leads from the coltrol board to the motor brushes. It's inside a cloth insulating sheath secured against the windings with a metal strap and two ty-raps. I bypassed the fuse with a wire instead of replacing it. It would probably just blow again sooner or later. p.s. you need a T10 Torx screw driver to disassemble (screws under rubber feet) $3 at ACE hardware.
Posted on Jul 22, 2010
gopakumarg43
  • 74377 Answers
SOURCE: Breville Blender BBL600/A. Only pulse touch button
Hello
Its speed regulator electronic circuit inside is faulty. There is a control circut ot determine the time and speed of the blender. It will contain a pre-programmed IC. This board is nor a repairable one. It should be repaced as card basis. Its one touch pulse only energezes. No other speed retulation section does not works, and the IC related to this is faulty. Normaly pre-programmed; otherwise known as {PIC} ICs are programmed by the manufacturing company, and will be difficult to get from outside electronci sparepart market. So you have to contact the Breville service center to get this device repaired. OK.
Posted on Jul 14, 2011
Why won't the blender start? the on/off light keeps blinking
my Ninja blender wont turn on, power button keeps blinking red ...
https://answers.yahoo.com/question/index?qid...
Dec 11, 2011 - I know I"m not supposed to drown myself in the toilet yet the don't build in a head protector. The blinking light won't go off. It worked last night ...
Ninja Blender Red Light Is Flashing ' Appliance Repair ...
appliancerepairquestions.com/question/ninja-blender-red-light-is-flashing/
Mar 29, 2015 - My new Ninja Blender has a power button that is flashing red. ... and the top of the blender is on and secure but the light keeps blinking / flashing. ... How do I set the oven off from demo mode asked by Anonymous, 2 months ago ....Whirlpool MDU1955XTSS2 won't turn on asked by Anonymous, 4 months ...
cuisinart blender red light flashing but Questions & Answers ...
www.fixya.com > Forum > Tags
Dec 26, 2015 | Euro-Pro Ninja Nj600 1000 Watt Xl...
I think I overloaded the blender. Seems like it over heated. now the light on controls goes on but blender does not run when I push buttons. I checked the fuse and its good. What else should I check?
If fuse is good and light is on, then you are getting power. Most likely and very very commonly the motor is fried. I have done it myself with 3 of these things.
Dec 31, 2010 | Breville BBL600XL. 5-Speed Blender
Breville blender won't turn on. The on light is flashing red instead of solid blue. Worked fine a few days ago.
FIXED IT - It's the screws on the bottom of the jar assembly, where the blades are attached. There are 4 Torx screws - star-shaped - and when these come loose over time the Blender will start to operate only sometimes. Eventually it will be never.
Tighten these four screws and everything will be fine!
Oct 02, 2010 | Breville BBL600XL. 5-Speed Blender
This is the second CBL25 breville blender I have had and it has, as with the first, stopped working out of the blue having not had it for very long. A year perhaps. There is a reset button on the base but...
Bridge the reset button with a jumper and see if that fixes the problem. All it is after all, is a breaker.
If that works, just install a line fuse of about 10 amps.
Mar 07, 2010 | Breville CBL25 Moda Bar Work Top Blender
The blender and lcd countdown is on...blender
If so, it's underneath the unit. If so, unplug it before resetting.
Oct 06, 2009 | Breville CBL10 BlendMaster Classic Work...
Blender will not run. the power button is lite but
Jul 01, 2009 | Breville BBL600XL. 5-Speed Blender
Breville hand blender doesn't blend continuously
I have the same problem. Mine used to work, has only seen light use, and now it runs for about 1 second before it shuts off. Expensive POS. There don't seem to be any solutions either.
Nov 18, 2008 | Breville Cordless Hand Blender - Silver
Lights/LED lit up, but blender does not start!
The motor brushes may be in need of replacement.
Sep 09, 2017 | Cuisinart CB-600 Blender
Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it...
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
Apr 16, 2008 | Breville CBL10 BlendMaster Classic Work...
Blenders Logo
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
