Question about Car Audio & Video
Insignia amp is stuck in protect mode
1000w
Jexx
  • 148 Answers
SOURCE: amp shutting off going into protection mode
Check this out: http://www.techlore.com/article/14696/
Posted on Aug 17, 2006
imseth85
  • 30 Answers
SOURCE: Stuck in protection mode
First disconnect the subwoofer wires from the amp, turn the car off and back on...is the amp on? If so your subs are shorting it out, either from a frayed wire, or blown subs.
If it is still in protection mode, check the fuses in the side of the amp.
Posted on Mar 31, 2008
  • 13 Answers
SOURCE: amp displays the letters curr
? The amplifier has been shutdown due to excessive current. ? Find and eliminate the cause of the excessive current, then turn the power off then back on from the remote control unit. ALPINE ELECTRONICS OF AMERICA, INC. 19145 Gramercy Place, Torrance, California 90501, U.S.A. Phone 1-800-ALPINE-1 (1-800-257-4631)
Posted on Jun 10, 2009
ginko
  • 19396 Answers
SOURCE: Autotek XS-900.4 stuck in protect mode
Hi.
The amp does not go on protection only because of wiring or power source problem , but also and mainly when there is an internal fault.
Protection is started whenever an out-of range voltage value is detected from the controller circuit.
Protection can be triggered from a burnt final IC or from a speaker wiring problem.
Since you have ruled out speake, wiring and power source problems, then this Amp is probably defective
If the Amp works fine on a different vehicle, then protection mode may start either because speakers impedance is not within Amp specs, or because the amp has a too big power draw. In this last case the problem is fixed installing a capacitor on the Amp 12V line.
Regards.
Ginko.
Posted on Jun 06, 2010
caroldon
  • 17130 Answers
SOURCE: When i hook my one 12inch sub up to a sony xplod
yes once in protect the amplifier is cut off because the current drain is more and can damage the outputs.
You might have to check the impedance of the speakers to confirm if this is lower that the rating prescribed for the outputs.
Also try to lower down the low frequency so as the load reduces.
If not the sub woofer is not matching and must be changed.
Posted on Sep 21, 2010
Audiopipe amp 1000w on 2 8" double ended bazooka
You may be over driving the speakers or there may be an impedance mismatch between the amplifier and speakers, especially if they are connected in parallel
Nov 12, 2012 | Car Audio & Video
It is stuck in protect and wont come out
bro...i had problem like that before and i found out that the load(speakers) was high thats why the fuse always blow...or...check the wire to the speakers if they are sorted or touched.gud luck
Oct 26, 2012 | Rockford Fosgate T1000-1bd - 1000W...
When i hook my one 12inch sub up to a sony xplod 1000w amp the amp gose into protect mode when you turn it up it just stop playing
Sep 21, 2010 | Sony Car Audio & Video
MY AMP TURNS TURNS ON THE PROTECTIVE MODE
The amp is being overworked and is overheating so it is shutting down to protect itself. You could try to add a fan and point it at the amp to help keep it cool. Also make sure the amp is not located where it will get heat from an exhaust pipe under the car for example. They may have external fans that you can attatch to the amp to help cool it. The constant overheating could eventually damage the amplifier.
Oct 09, 2009 | Legacy 2CH 1000W AMP Car Audio Amplifier
Amp on "protect" mode
Hi, what you need to do is unplug all the connections to the amp. The amp goes into protection when the circuitry over heats.\
First decrease all your gains to minimal volume.
Connect your 12+V, remote, and ground.
See if the protection light comes on then.
Next plug in your RCA cables.
Check protection light.
Then plug in your subwoofer cables.
See if you are still in protect mode.
Hopefully everything works alright again.
Just slowly increase the gain to see what the cut-off is. Make sure you aren't dropping the ohmage too low on the amplifier. Check manual for correct wiring and such.
Feb 08, 2009 | Phoenix Digital PD-394 Car Amp
Mar 21, 2008 | Kenwood KAC-7251 Car Audio Amplifier
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Amp shutting off going into protection mode
Aug 14, 2006 | Legacy Audio American Legacy II LA690 Car...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
