Question about Epson Aculaser C1100 Printer
Colours are wrong
Yellow prints as orange, magenta looks brown, and all tints are accordingly inaccurate - green very muddy looking, blue too dark and warm, etc. Printer not used much, still using original toners except for yellow which I changed hoping it would make a difference; printed fine for first 200 or so pages. Any ideas?
  • Kwinten Nov 05, 2008
    All my prints are too magenta.
    gray is not gray but has a magenta tone...
    That's a problem!
    Any idea how I can fix this?
  • Epson Master
  • 691 Answers
Most likely a toner spill down the back side of the carousel. Remove all the toner and dev unit and vac out any spillage from within the printer. DO NOT VAC THE DEV OR TONER UNITS.
Replace all the units and print about 200 full colour pictures (preferably a test chart - Gretag McBeth or similar) at full size (A4). See if the colour then begins to return to normal. If not, you will probably have to replace the dev units too.
Posted on Nov 09, 2008
Xerox 8500 phaser prints brown tint
Most likely the cyan ink is burnt. If the ink sticks are left unused (printing more black than color, this will happen.
Print the test pages for PQ troubleshooting from the control panel and examine each print. Cyan will probably have very dark streaks down the page, magenta should look normal, and yellow also will have dark stripes. You need to replace this burnt ink, and the only way is to print. From within paint (or similar accessory in other OS) Create a full page of cyan, and print about 100 - 200 pages, or until the cyan starts to clear up. Yes it is a waste, but much cheaper than a print head, Do this for yellow as well.
Apr 15, 2014 | Xerox Phaser 8560DN Laser Printer
Colors not matching computer
It is possible your colour cartridge has cross contaminated the ink reservoirs. To check this take the colour cartridge out and turn it over to see the coloured pads. They should look red, dark blue, and orange ( the colours are actually Magenta, Cyan, and Yellow, but are concentrated). If any of the pads are pale or particularly green - change the cartridge.
If the colours look alright, your issue is probably that your monitor makes colour by emitting light frequencies so is bright, printed images make colour by absorbing light frequencies so will always be darker. There is always the issue of course that your monitor also has a colour "temperature" bias. Photo pros calibrate their monitors and printers to match.
Mar 25, 2012 | Canon PIXMA iP90v Printer
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
Hi, just wanted to know if there is a diagram for the head unit. the colours for the left & right speakers in a ve ute?
*Remove drivers side centre console panel
*You'll see a black plug on the "side" of the stereo, this is your speaker outputs and constant 12v+.
Dark Green - / Light Green + = Front Right Speaker
Grey - / Brown + = Front Left Speaker
Light Blue - / Dark Blue + = Rear Right Speaker
Yellow/Red - / Brown + = Rear Right Speaker
Sep 21, 2010 | Car Audio & Video
Looking for stereo wiring diagrams for 96 dodge stratus. doing this on a budget and found wiing under front pass seat that was altered
1996 Dodge Stratus Car Radio Stereo Audio Wiring Diagram
Radio Battery Constant 12v+ Wire: Pink/Yellow
Radio Accessory Switched 12v+ Wire: Red/White
Radio Ground Wire: Chassis
Radio Illumination Wire: Orange/Brown
Stereo Dimmer Wire: Black/Light Blue
Stereo Antenna Trigger: Orange/Red
Stereo Amp Trigger Wire: N/A
Stereo Amplifier Location: N/A
Jan 26, 2010 | Car Audio & Video
Need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
May 31, 2009 | 1995 Mercury Villager
I need color codes
Constant 12V+ Black/Yellow
Switched 12V+ Red/White
Ground Black/Light Blue
Illumination Orange
Dimmer Pink
Antenna Trigger Orange/Red
Antenna Right Rear
Front Speakers 4" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Feb 19, 2009 | 1996 Dodge Intrepid
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio & Video
Epson Aculaser C1100 Printer Logo
304 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
