Code for universal remote to work my Jensen awm 970
I have a Jensen AWM 970 and lost the remote. I need to know if i can use a normal universal tv remote to work it and if so, wath is the code?
josh1856
  • 105 Answers
SOURCE: Jensen JER321 3-Device Universal Remote
coding:
1.Manually turn on the component you want the remote to control.
2.Press and hold the component key (TV, VCR, Etc..) you wish to program. The illuminated ON-OFF key turns and remains on.
3.While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4.After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5.Release both keys. The illuminated ON-OFF key remains on.
6.Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks and the next code in the list is sent. This process continues until all of the codes in the Code lists have been searched. If your component turns off, you have found the correct code.
7.Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored.
Posted on Jan 26, 2008
SOURCE: need codes please for Jensen JER 422 for Magnabox TV
magnavox tv jer 422 codes are: 1000 1004 1006 1008 1019 1062 1068 1069 1075 1076 1133 1219
Posted on Apr 05, 2008
  • 1694 Answers
SOURCE: universal remotes
www.remotecodelist.com T.
Posted on Apr 08, 2008
IrishDruid
  • 2712 Answers
SOURCE: tv universal remote/jensen surf series sc330
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: I NEED THE CODES
thank you so much
Posted on Jun 01, 2008
Iwould like to change to region 4 on a jensen awm 970 dvd radio as we have shipped a yank 5th wheeler to australia and the player does not like our region ,What is the changing code
john, Did you get your problem with your Jensen AWM970 solved? I have just bought the same device in an imported caravan and can't for the life of me get into the region menu??? I'm about to throw it out but because it's so large it will leave a huge hole to fill. Any help would be good. Cheers, Phil.
Nov 30, 2012 | Jensen Car Audio & Video
Hi I need a ge unversal remote code for my awm dvd player. thanks
Have you tried a direct tv remote? Or dishnet since they are universal?I have these iam a dealer for them both ericandmandy08@aol.com
Sep 29, 2010 | Televison & Video
I lost the code for my jensen jer 422 universal remote to my prima tv
i lost the code to my remote and now i need to reenter the code and i cannot find it please help me.
Jan 20, 2010 | Jensen JER-422 Universal Remote Control
JENSEN JER321 3-Device Universal Remote
i lost my code for tv its a toshiba please help!!!
Oct 18, 2008 | Jensen 143307 Remote Control
Lost booklet of codes
the codes i have for the zenith are 1000 1001 1004 1051 1083 1151 1152 1154 1217. they come from my jensen remote list i dont know if they will work but its worth a try
Mar 27, 2008 | Jensen JER-422 Universal Remote Control
Need codes please for Jensen JER 422 for Magnabox TV
Jan 12, 2008 | Jensen JER-422 Universal Remote Control
Universal remote
the universal remotes work fine in any tv, but limited to basic funcion, if you whant full funcion one, go to, www.remotes.com or call 1-800-remotes..good luck
Aug 10, 2006 | Jensen TS2050J 20" TV
Televison & Video Logo
969 people viewed this question
Top Televison & Video Experts
