Dark streaks on the inside of the screen
I have three lines running down my is wider on the bottom then the other two. It almost looks as if liquid got inside and there is now a smear on the inside on the screen. Is this something that can be fixed or should I scrap the TV? Magnavox 32" LCD HDTV
I have a dark band or line running down the right side of my screen. Kind of where the the 4:3 aspect ratio ends. I don't usually use 4:3 so I don't know if that's just a coincidence.
The dark stripe started very small up in the corner and has continued to grow over the past 4 months. It is mostly noticeable on solid colors.
It's only slightly distracting, but I am worried that it means the entire screen is about to die on me.
  • 35 Answers
If it's an LCD TV, then what your seeing is Liquid Crystals inside. Chances are that someone has bumped the LCD or damaged it, and now the screen is broken. The "Dark Lines" are from misfiring pixels which is a sign that the LCD is damaged and will either stay the same, or get much much worse. I'd lean towards much much worse.
Just keep it until it really gets bad then just replace it. You can have it fixed, but the repair would cost more then just buying a brand new one.
Posted on Oct 24, 2008
What causes black streak lines on the entire copy
open the right door and look at the drum, lines on it? If not, its the hot section/fuser. -Carl
Jun 26, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
Can't get picture screen clean
If the dark streak is static, then is liquid in lcd panel.
Oct 24, 2008 | Polaroid Televison & Video
I have three black circles, and some color streaking at he bottom inch of my RCA, LCD tv
that is usually caused by cleaning the screen with windex the windex runs down the screen bewteen the screen and plastic frame and actually seeps inside between the screen layers. Eventually it may go away by itself if the circles are not too bad but in most cases the damage is permanent.It can also be an issue called screen delamination which there is no fix for.
Mar 02, 2012 | RCA Televison & Video
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    My front load kenmore leaves faint dark streaks in
    look carefully inside the tub, gasket, lid. There may be some debris of some sort stuck somewhere causing this problem.
    Then run the machine adding only two cups of vinegar. this will clean it.
    Aug 20, 2009 | Washing Machines
    Dark shadow-like vertical streaks thru LCD screen (Sharp)
    Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
    Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
    Hi, my canon mx310 is showing a daRK line when we
    Use a flashlight and look closely at the narrow glass next to the platen glass. I usually find a spot of white out on the glass causing the streak. Also a dark spot on the white guide above the glass will cause a streak like you mentioned.
    Jun 22, 2009 | Canon PIXMA MX310 All-In-One Printer
    This can be from a bad ribbon cable between the screen assembly and the driver board, or a failure in the screen driver board, or a failure in the screen itself.
    Without trying the modules it is impossible to easily know the exact fault. These modules are fairly expensive. There is no manufacture support for component level servicing.
    Jerry G.
    Feb 09, 2008 | Olevia LT37HVS 37 in. LCD HDTV
    Copies and outgoing fax quality
    your machine most likely has toner spills in it.
    if you send faxes face side down follow these instructions ;
    1- take out toner
    2- look for thin glass strip on bottom inside the machine
    3-wipe clean
    if you make copies side up then do the same except look for glass strip on the upper side of machine
    Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
    Dark toner streaks
    can only be toner, drum or fuser, pull out drum and look at surface are you streaks present? usually drum.
    Stop a print half way threw machine and then remove drum and look at print, pre hot bit (fuser) are you marks there? If so it is drum, if not fuser.
    Nov 21, 2007 | Brother IntelliFAX 4100 Laser Fax
    Televison & Video Logo
    689 people viewed this question
    Top Televison & Video Experts
