Question about Cameras
Vivitar auto/bounce 40d flash manual
Instuction manual
3 Suggested Answers
bestdarngood
  • 3037 Answers
SOURCE: Need an instuction manual
http://www.retrevo.com/s/Vivitar-35-Digital-Cameras-review-manual/id/200ci752/t/1-2/
this should help
Posted on Mar 19, 2008
greenspan
  • 1734 Answers
Download the manual at http://manualfox.com/link/vivitar.htm
Posted on Mar 29, 2009
Which of the following Vivitar flashes will work on a nikon D5100? Vivitar auto thyristor 2800 or vivitar electronic flash 1900?
they should both fire, but they were not meant for modern digital cameras, and the auto features the the camera may have won't be able to control this flash. so it just a manual strobe, to set your camera on manual and experiment.
that little pin on the bottom as well as the 2 on the inside of the flash shoe should fire the flash.
good luck.
Sep 13, 2017 | Nikon Cameras
Canon flash won't pop up
Flash will not pop up automatically if you're in manual mode. Try putting it in the green auto mode, then try again. Still not working? See if the little flash symbol button is on OFF. If so, put it to ON or auto. Should work.
Jul 08, 2014 | Canon EOS 40D Digital SLR Camera Digital...
Can i use my vivitar 4600 with my nikon d300s?
Yes. You can use the flash in auto or manual mode by setting the camera to manual shutter speed within the x-sync range and then selecting the aperture prescribed by the flash guide number or the displayed automatic f-stop on the flash. The flash can provide auto exposure with the camera in manual mode, but you need to be aware of the amount of ambient light which will not cause any exposure corrections by the camera in this mode. Another alternative is to select Aperture preferred automatic on the camera and the f-stop shown for the auto flash settings. This will allow the camera to vary the shutter speed but may cause long exposures if the camera is not sensitive to real-time flash readings.
May 05, 2014 | Vivitar Cameras
Overexposing in auto modes, low light being reported.
The Auto modes on the 40D weren't very reliable when I ran comparison tests with other models..and systems. In fact I gave up with the 40D altogether! :) The anti-aliasing filter was a joke and the auto focus was....blaaah.
You mentioned you 'reset everything'? Yet it sounds like there may be some residual settings left behind. EG, white balance settings, flash sync speed. You might also want to check the individual presets for LANDSCAPE, PORTRAIT, NATURAL etc... Once you can start afresh, things should start to make sense as you make adjustments. Just remember to keep account of what adjustments you make.
CF (custom functions): are normally reset to factory however some settings remain (white balance adjustments, tonal adjustments etc)
Nov 25, 2013 | Canon EOS 40D Digital Camera
Why is the flash not working on my vivitar 8025
The Vivitar 8025 has the following flash settings: Auto mode , Fill-in mode , Flash OFF mode. Since the cam doesn't have a manual flash setting, check to see if it's set to OFF mode. Or even Fill-in mode (sometimes it barely flashes). Auto mode will only work if needed......
thanks.
Apr 08, 2011 | Vivitar Cameras
Canon 40D
Hey D1ppy,
There are two ways to get rid of shadows behind a subject, but both require you to use a hotshoe mounted flash. The first way is to bounce the light off a ceiling or some other white surface by turning the flash head towards that surface instead of your subject. The second way would be to connect the flash to the camera using a off camera flash cord and hold the flash above your head when your taking the picture, and by doing this you are able to aim where the shadows show up in the image. Bounced flash is what is called soft light and generally is more pleasing light. I of course am assuming the shadows are caused by the built in flash on the camera. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 30, 2008 | Canon EOS 40D Digital Camera
Will a Vivitar 285HV fry my Canon EOS 40D? I'd like to experiment with a Vivitar 285HV as an on-camera hot shoe flash. However, I'm reluctant to proceed because of conflicting reports about voltage...
Personally, I would not try it. While the Canon has a protection system built into the camera, the trigger voltage on the Vivitar is pretty high. I have had good results using a 283 on a slave shoe, you will have to stop down more with the extra light
Jan 08, 2008 | Vivitar 285HV Flash
Cameras Logo
105 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
