Toshiba satellite A105 S1014 won't boot up
Screen starts, but progress bar shows but is not moving, won't finish booting. tried removing battery, same thing, tried removing battery and unplugging power cord, holding down start button 30 seconds, same thing, tried replacin g battery and plugging in charger, holding down start button for 20 or 30 seconds, same thing. Progress bar on startup screen doesn't move, system will not finish booting up. Tried new hard drive, tried new memory, no success, does the same thing always. please help.
Nitrotrike
  • 589 Answers
SOURCE: Toshiba Satellite A105-S1014 Sound Problem
Does it have that silly little volume knob on the side? Gets me every time :)
Posted on Jan 09, 2008
bangjeha
  • 15 Answers
SOURCE: Satellite A105-S1014 TOSHIBA
Sound you got a virus that corrupted a certain file in your Windows operating system. Try googling with a descriptive computer keep rebooting or something similar. Basically you need to replace that corrupted file and there are hints in the Internet on how to do this.
Posted on Oct 19, 2008
SOURCE: I removed the power cord. Then I removed the
If it boots then, it is one of 3 things either you need an inverter, a backlight, or a new screen.
Posted on Jun 07, 2009
  • 742 Answers
SOURCE: Boots to progress bar before loading windows
It seems that windows tries to check your Hard Disk for errors before loading the system files to memory. Do you hear some sounds from your hard disk? If you can successfully get to windows, open my computer => right click on drive C => Click on Properties => Click on TOOLS Tab and click CHECK NOW button.
Check the next 2 options and answer YES when windows ask you to schedule a thorough scan during next boot.
Regards!
Posted on Jul 21, 2009
sardanadixit
  • 813 Answers
SOURCE: monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Posted on Aug 08, 2009
Satellite a105-s4284 powers on and goes through boot successfully for about 1 minute then does a hard shutdown
I'm sure you have reseated/replaced the Memory mods? Have you thoroughly cleaned the fan, vents, heatsink? Have you done ANY hardware updates? Graphics? If you boot to Safe Mode any change? Have you tried a System Restore? Try another Cord/Charger with the Exact same power specs. Try removing battery and boot.
Mar 31, 2013 | Toshiba Satellite A105 Notebook
Toshiba satelite a105 keeps looping in the boot menu
No blue screen or number, it use to work find, this problem start last week
Jul 05, 2017 | Toshiba Satellite A105-S1712 Notebook
How to bypass setup password on a toshiba satellite A105-S4074
You can fix this by removing first removing all power, then remove the plastic cover above the keyboard, removing removing the two keyboard screws.
You'll need to fold the keyboard in such a way that you don't damage the cable.
You will see the wifi card just to the right. It's the only card there. It is held in place by spring clips. Remove the card from the connector.
There are two solder contact points labeled "C88". Connect the power adapter to the laptop now. Short the two contact of "C88" and press the power on button. The unit should boot to the windows screen. Once it boots, you'll have to update to the latest BIOS.
Oct 12, 2012 | Toshiba Satellite A105 Notebook
Black Screen on Toshiba Satellite A105 S1014
Blown or damaged graphics chip on motherboard, would take to specialist repair shop
Feb 09, 2010 | Computers & Internet
Toshiba a105 screen goes black then stops booting up when startng
try access the safe mode.. then remove the some virus or.. if you installed same latest program remove it then start again...
it you dont installed any program check the control pannel,, add and remove program remove all programe not neccesary...
Jun 08, 2009 | Toshiba Satellite A105 Notebook
Toshiba satellite a105-s1014
try the computer with an external monitor, if it works correctly then it's the monitor that has broke and you need it replaced.
otherwise, if it does the same things on the external monitor...
I would check in order:
1)RAM memory
2)Motherboard
if the problem is only after windows boot, try changing the video driver, the problem might be caused by overheating video Chip, but that should freeze the system too...try also to remove the dust from all the heatsinks with canned air...
Jan 18, 2009 | Toshiba Satellite A105 Notebook
Display
If you've got exacttly the same each time you're start, then the VGA card has issue, or even the motherboard and CPU.
If not then try to chock the base of the screen with two fingers when starting, if nothing happen try to chock the middle of the keyboard and several spot around it. (it's a little bit brutal but the easiest way to find a bad contact or dead components)
If you feel like open it then this website will help you:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
and for the screen:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
good luck
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Toshiba A105
i advise you to reinstall windows on a new partition
May 28, 2008 | Toshiba Satellite A105 Notebook
Satellite A105-S1014 unexpectedly turns off.
First u have to open it and dust then if problem continiuing then you have problem with power suply or ram memorie!!!
Oct 15, 2007 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
