Have a Gateway GM5474 w/ Windows Vista SP1 newly reinstalled. it was reinstalled b/c it kept randomly freezing up and no problems could be found or sloved by Windows Pc repair or other. Now it still continues to randomly freez, and has missing drivers for the Visx Pure tv-u 4899 (NTSC/ATSC combo)and other multimedia device. What can I do????
  • ratman_sr Dec 11, 2008
    I have changed my memory to Crucial memory, run 3 weeks of memory testing, updated all of the drivers changed the video card, changed the CPU, checked the fans changed the hard drive. disconnected the additional peripherals, but I am still getting IRQL is less than or equal, after checking the minidumps, it shows different system programs have accessed memory that it should not have. I have reinstalled vista 3 times upgraded to sp1 and even tried sp2 beta. the only time the system ran without failure is when I downgraded to XP, but not all of the hardware has drivers that will work in XP.
    I am like the original poster, with the same problem.
  • 35 Answers
If it's a fresh install and it's still freezing, then it's 100% a HARDWARE issue. The following problems can cause this issue:
1) Faulty ram. The ram hasn't completely failed yet, but when it has data written to the bad part of it, your system freezes. Best way to test: If you have multiple ram chips, take out one, and see if the system stalls, if it doesn't you know the one you took out is faulty and replace it, if it still stalls try the other one instead, if it still stalls it's not the ram. (Sometimes it'll give a Blue Screen of Death)
2) The next thing is the CPU fan has failed, (is failing). Take off the side of the case and look at the fan on the motherboard, is it turning slowly or not at all? If so just replace the heatsink and fan (usually around $20)
3) Hard drive is failing: It is possible that your hard drive is failing. There's a sure fire way of testing it, but the software costs $80 (It's called Spinrite 6.0) but if you don't want to spend that kind of money on diagnostics software, do this instead:
1. Open Computer by clicking the Start button have a Gateway GM5474 w/ - getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, and then clicking Computer.
2. Right-click the hard disk drive that you want to check, and then click Properties.
3. Click the Tools tab, and then, under Error-checking, click Check Now. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
To automatically repair problems with files and folders that the scan detects, select Automatically fix file system errors. Otherwise, the disk check will simply report problems but not fix them.
To perform a thorough disk check, select Scan for and attempt recovery of bad sectors. This scan attempts to find and repair physical errors on the hard disk itself, and it can take much longer to complete.
To check for both file errors and physical errors, select both Automatically fix file system errors and Scan for and attempt recovery of bad sectors.
4. Click Start.
Those are usually the major culprits. If you try all the above, and still are having problems, then the only thing else would be a faulty motherboard or CPU.
Posted on Oct 24, 2008
Product key of emachines D620
Hello here is the homepage:
http://support.gateway.com/us/en/emac/product/default.aspx?modelId=1263
The product key 25 digit number is under the pc on a sticker.
To make a reinstall you need the original windows disk.
You can not buy windows vista on a disk anymore.
I recommend to change your windows system to windows 7 because the support for windows vista is phased out.
A new windows system cost about 200 dollars for an oem version with the product key and can be bought online or in a computer shop.
Good luck
Dec 15, 2012 | Microsoft Windows Vista Home Basic with...
Tip
The not-so-secret Vista SP1 download link is...
... here. You can stop Googling for it now. ;)
Msoft seems to be of two minds about letting Vista SP1 get out there-- it wants to do it but not too fast. So they have kept this URL fairly unadvertised. I found it here on the official Windows Vista Blog.
Read the caveats and "Before you install" notes. This is a big update and proceed with caution and AYOR (At Your Own Risk). Advise strongly backing up your entire hard drive (the one with the O/S on it, usually the C:\ drive) before installing. SP1 installer will make a restore point for you but better safe than sorry-- back up your system drive to a different volume, too (ie don't back it up the same drive it's on-- what if that drive crashes?).
Good luck.
on Mar 20, 2008 | Microsoft Windows Vista Ultimate Edition
Windows explorer windows 7 freeze up
what the problem clearly type do u have problem sp1 or other problem write write and clear
Sep 25, 2011 | Microsoft Windows Vista Home Premium with...
IT FREEZES AND HANGS DAILY, AND KEEP ON SHOWING ERRORS AND NOT RESPONDING MESSAGES
Above you have posted that you have SP1, vista is up too SP2, you should check for updates, because your system will update too SP2,
unless you don't have a valid copy of windows.
SP2 fixes a lot of problems with vista.
You should also open task MGR, and watch the process list, so you can see what program is causing the system to freeze.
If you post what program is causing the system to spike, we can maybe get a solution for the problem.
If you need to know how to do any of this just post back with any questions.
Feb 14, 2010 | Microsoft Windows Vista Home Premium with...
Vista SP2
I want to stop you there. You should stick with Windows Vista SP1 because Sp2 has A LOT of program incapability problems (e.g. some games will not work in SP2, but work fine in SP1). Hope I helped - donman92
Jun 06, 2009 | Microsoft Windows Vista Ultimate Edition
Gateway M6340U hard drive problem
It sound like memory problem. Change the memory and test if the problem is solved.
Dec 11, 2008 | Gateway M6307 Notebook
Gateway laptop keeps freezing every few minutes
I had the same problem with my gateway laptop. try reinstalling windows xp pro instead of vista if this does not work replace your hardrive.
Nov 02, 2008 | Computers & Internet
Windows Freezing
Do you have Sp1 installed ? i am assuming you are using windows vista. If not i suggest you download this. if its Xp install SP1 and SP2. In Windows vista there is a problems and reporting app located in the control panel, open it up and see if you problem is there , if it is then there should be an option to find a solution, Try that option.
Also veryify that the systems are fully updated.
Dont rule out a virus or worm yet. the problem you are describing does seem to be this which can infect other system providing you copied the pics to them. Back up the pictures to anoter folder and empty the my pictures folder. save a picture from the internet to it and try right clicking then. If this works then copy back the images one by one to the my pictures folder m everytime right clicking to see if it freezes. Eventually you will find the offending image. you can also try Super Anti Spyware Remover or tuneup utilities and let it do a registery scan.
Let me know what happens
Jul 10, 2008 | Microsoft Windows XP Home Edition
Windows installer package
I've ran into windows installer issues on vista(especially around windows update) You have two options... Try and install the Vista Service Pack 1 standalone(google it.) or reinstall windows Vista.
I'm sorry, if I had a better solution that worked for me in the past I would tell you, but reinstall or try to see if SP1 fixes it are the only solutions that have worked for me.
Apr 30, 2008 | HP Pavilion dv6000z Notebook
Vista SP1
Call their activation line. 1-866-740-1256
Jan 06, 2008 | D-Link Wireless
Computers & Internet Logo
830 people viewed this question
David Payne
David Payne
