Question about Mgc P700 17" Flat Panel LCD Monitor
Mgc computer moniter
I bought a new HP tower and brought a discarded moniter home from my office. When I power on I get a message out of range, vga in 102x768, h snyc +68.5, v snyc +84.7
    President:
  • 1,901 Answers
Reboot your computer.
When it begins to boot, tap the F8 key repeatedly.
When the menu appears, select Enable VGA mode and press enter.
When the system comes up, right click on the desktp, and select Properties.
Click Settings and set the resolution to 800x600 to start with.
Click Apply or OK
Restart your computer.
Here is a link for this:
Out of Range Error
If this solution has been helpful, please take a moment to rate it. Thank you.
Posted on Oct 24, 2008
Hi i am looking for vga cable 9 Pin Female to 15 Pin Female thanks
The 9-pin port on your PC tower is NOT a video port, it is a serial data port. All VGA connectors are 15-pin. Hooking up to the 9-pin port will not get you a picture. There should be a VGA port on the PC, or else a DVI an/or HDMI port. You can get DVI-to-VGA adapters that work, but only if the DVI port is an analog DVI, not if it is a digital DVI (DVI-D or DVI-DD).
Feb 02, 2016 | LG Computers & Internet
No vga input on working monitor
Turned on computer (Pavilion a1657c), HD light operates, Monitor has little window saying:
HDMI Input: No Input Signal
VGA Input: No Input Signal
Recommended Settings: 1920x1080 - 60hz
Changed from the monitor that came with it (HP f2105 digital ouyput) to my Samsung analog and same message comes on dark screen.
Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Computer Support
Mar 21, 2014 | HP Media Center m7657c home PC - RC640AAR...
Bought a 36" oscillating tower fan model FZ10-9LR
this happen to me one i just went in bought new fan took the good remote out and gave them back the bad one brought it all back and got my money back.good luck
Aug 05, 2011 | Hampton Bay Dryers
Need to connect hp flat screen moniter to dellgx280 pc tower
Hi. Just Plugin the signal cable of your HP flat screen into the VGA port at the back of your dell optiflex computer, look for a blue port on the back with fifteen holes on it and that should be your VGA port. Hope this Helps
Jun 04, 2010 | Dell OptiPlex GX280 PC Desktop
I bought Microsoft Office (home office and student
The only thing i suggest you here is to remove the older all the versions of MS office from your computer and then completely install new MS office.
That would solve the problem.
Thanks
Jimmy
Jun 02, 2010 | Microsoft Office Home and Student 2007...
F2105 hp monitor went to sleep and cannot wake.
i cannot help you its either your moniter or the vga port at the back of you tower there the only things i can figue out
Jun 01, 2010 | HP f2105 21" LCD Monitor
I have the NVIDIA 6200 in an IBM tower. Tower was
Compaq's are notoriously under powered. You should take a look at the power rating on your power supply, then cheque the necessary voltage for the card. Also make sure that the card doesn't have an extra power connection that you need to fill to make it work.
Jul 22, 2009 | PNY GeForce 6200 (VCG6200APB) (128 MB)...
Intstalled starlogic moniter to PC and got error message
the "Out of Range" message usually appears when the video card is putting out a video resolution or frequency that the monitor isn't able to handle. You should reboot your computer and BEFORE the Windows screen shows up, press the F8 button once every half-second. THis will bring up the boot menu for Windows. Select "Enable VGA Mode" and press enter. THis will load Windows in VGA mode where the screen resolution will be 800x600 @ 60Hz. Any modern monitor is able to use this. Once you log into Windows with the basic video settings, you can go into the Display properties within Windows and bump up your resolution and frequency as needed.
May 11, 2009 | Computers & Internet
Flatscreen didn't have a CD
I bought this monitor brand new and as I recall there was no software in the box.
Aug 03, 2008 | Balance CM2015 15" LCD Monitor
How to hook this monitor onto my computer
You would have got a CD with this moniter..
we ahve install that cd..
and its better to check the cables first which would be the
VGA CORD that is blue in colour which connects your moniter with the tower.
We can check the connections with the moniter for the Tower and then install the cd.
Feb 06, 2008 | Computers & Internet
Mgc P700 17" Flat Panel LCD Monitor Logo
195 people viewed this question
Top Mgc Computers & Internet Experts
David Payne
David Payne
Are you a Mgc Computer and Internet Expert? Answer questions, earn points and help others
