Question about Uniden DCX640 Cordless Expansion Handset
Can i register vtech phone model cs6319-2 to the uniden phone model d-1688-2 base
SOURCE: Uniden DCT648 register phone problem
I have contacted Uniden about solving this problem. They suggested I clear the eeprom on the handsets and reset the base. To clear the eeprom detach all of the batteries and reattach while holding the star and pound. You'll hear a beep. Press select and the unit will clear the eeprom. Now hit end and the unit will say "Welcome...something or other". Next unplug the base unit reattach while holding delete. Next hit delete twice...the base is reset. Apparently this is the last possible solution to marrying the handsets and base. This didn't work for me and the units have been declared dead. Good luck in solving your electronic problems.
Posted on May 14, 2007
SOURCE: how to deregister a handset without the base with which it orginally registered
I successfully reset uniden TCX800 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near LCD.
Posted on Feb 24, 2008
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
SOURCE: tru9466 base and tru9465-2 handset
You need to simultaneously hold down the red hangup and # buttons for about five seconds or until the handset says de-registered. You can then put the handset into the base unit and it will registere.
I had this problem myself on two Uniden TCX905 phones and that was the solution. I couldn't find it in the manual but verified it with Uniden support.
Posted on Jul 15, 2008
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
CAN NOT CLEAR WATER PROOF DECT 6.0 PHONE TO REGISTER IT SAYS TO PUT ON BASE BUT I WANT TO REGISTER ON MY OTHER UNIDEN BASE BUT PHONE WON'T FIT ON BASE
Not stating the model number of your phone makes it a bit difficult because the process is not the same on all models. I am going to deal with the cordless main base only Remove any handset from the main base cradle. Then
On the waterproof handset Press and Hold the # sign until the Registering handset option shows then release it.Then on the main base, Press and Hold the FIND hs or Find or locator button for 5 seconds ( if there is no IN USE light on the base) or until the IN USE light come on, then release it. Hold the handset near the base and it will register.
Please note the Uniden waterproof handset could be a bit tricky to register and not knowing the model makes it more difficult. and you may have to apply other methods.
May 03, 2017 | Uniden Lands Phones
Handset display says "Connecting" I can't deregister. How can I get the handset to display "not registered"?
The procedures to deregister are, of course, specific
to each make and model number of cordless phone.
All of them are a LOT more involved than simply
removing the battery.
For some AT&T, VTech, Uniden, & GE model numbers
you might try the following:
For many AT&T models it is simple:
1. When the handset says "Connecting..."
enter *331734 [menu]
it will soon (chirp) and display "Not registered"
For many VTech models it is a bit more involved:
1. Start by taking off the battery compartment cover.
2. press [menu]
3. scroll up/down to "Settings"
4. enter * 7 8 9 0 #
5. if display reads "Test Base",
scroll to "Test Handset", press [select]
scroll to "next page", press [select]
6. scroll to "Register Clear?", press [select]
7. display asks "Confirm?" or "Register Clear??",
press [select]
8. display reads "Ok" (chirps), press [ off ]
9. UNPLUG THE HANDSET BATTERY
(this is why the cover is off)
10. Wait ~30 seconds, re-connect the battery &
replace the cover
11. display reads "Not Registered"
For many Uniden models:
1. Press and hold the [END] and [ # ] keys at the
same time, after a few seconds the display reads
2. "System Reset, Deregister Handset"
3. scroll to "... Base Unavailable"
press [SELECT]
4. Handset (chirps)
press [END]
5. display reads "Not Registered, Place in base..." =====================================
For some GE models:
1. press "program[mute]"
2. scroll to "Handset Setup" press "program[mute]"
3. scroll to "Deregistration" press "program[mute]"
4. scroll to "Yes" press "program[mute]"
5. display reads "Not Registered"
Once you have the handset displaying "Not Registered"
you can follow the User's Manual instructions to register
the handset.
The model number for your cordless phone is shown on
a small sticker underneath the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual if you need it.
Mar 14, 2016 | Lands Phones
How do I register my vetch cordless phone?
General - Product Troubleshooting - VTech® Cordless Phones
www.vtechphones.com/support/.../35/178
VTech Communications Inc.Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger. Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds.
Product Registration - VTech® Cordless Phones
https://www.vtechphones.com/.../product-re...
VTech Communications Inc.Vtech DECT 6.0 cordless phones are among the most advanced and innovative homephones on the ... Product Registration. How do I register my product?
vtech cordless handset, how to register - YouTube
? 3:21
https://www.youtube.com/watch?v=dV9rZ_cYcks
Feb 22, 2015 - Uploaded by Brian Williams
i registered my handset but im not able to call and answer call from my ... you lose your phone you have to de register allphones and start over.
Jan 21, 2016 | VTech Communications CS6114 - cordless...
Register vtect handset to base
Enter the model of your VTech DECT 6.0 phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Feb 02, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
Cannot find how to register my new vtech phone.
Since you declined to specify the model of your VTech phone, please download the manual by entering the model number into the search box at http://www.vtechphones.com/support/general/manuals and read the section on registering the handset to the base.
Dec 14, 2013 | Vtech Lands Phones
My vtech digital 6.0 cordless phone says not registered but when someone calles the base of the phone still rings and people are able to leave messages but the actual phone isnt ringing, how can i fix it?
The base and the handset are not communicating. To have them do so, you need to "register" the handset with the base. Since you neglected to specify the model of your VTech DECT 6.0 phone I can't tell you how to do that. I can suggest you enter the model number into the search box here to download a copy of the manual. The manual will give you instructions on how to register the handset.
Jun 22, 2012 | Vtech DECT 6.0 Digital Cordless Phone
How do I register my Uniden handset? It keeps saying it tis searching and then out of range even though I have it on the cradle
Which Uniden phone do you have? Some should register with the handset in the base unit cradle for 30 seconds to a minute. Others need to be within a few feet of the base but not in the base charging.
For the models that need to be registered with a multiple step process, first make sure that the handset is fully charged; this could take 15 hours. (Make sure the battery is properly connected; if it is loose, the registration may fail. If the battery may have been sitting in a warehouse for months, you may want fresh batteries even for a new phone.) Make sure that the base is plugged in (power and telephone line). I like to check the phone line with a basic corded phone for dial tone if there are any issues with a cordless phone. With some Uniden phones, a registration problem can be cleared up by disconnecting the battery and then reconnecting it before attempting to register the handset. (Make sure that you do not have more registered handsets than the base can deal with. You may need to deregister all of the handsets and start over. Make sure that the handset is compatible with the base.)
The rest of the process requires you to have the handset close to the base and be relatively quick. (You need to tell the handset to get the registration information from the base and the base to send the information before they time out). For the D1688, at the base, you need to press Menu and go to the Register Accy submenu. Press Select. Then press and hold # on the handset you need to register until you see Registering Handset. Wait for the Registration Complete (or Failed) message.
For the DECT1060, the procedure starts at the handset. Press Menu and navigate to Add. Settings. Press Menu/OK and navigate to Register and press Menu/OK. Select the base number and press Menu/OK. Then press and hold the Find HS button on the base for 3+ seconds until the unit enters registering mode. Now on the handset, you need to enter a PIN that matches the one set for the base. (The default is 0000.)
If you still have problems with registering the handset, then it's likely that the transmitter or the receiver for either the base or the handset may have a problem sending and receiving the codes that synch the base and the handset. Most Uniden phones are not meant to be user serviced for this type of proble. You will need to contact Uniden if the phone is under warranty or decide if you want to replace or repair the phone through Uniden's support.
The manuals for all Uniden DECT 6.0 phones are available as PDFs from Uniden. See http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl for a list of all models or search for your specific model. On the manuals pages, the models are listed in numerical and alphabetical order.
I hope this helps.
Sep 10, 2011 | Uniden DECT 6.0 Cordless Telephone...
Vtech Dect 6.0 says not registered. how do I register?
Instructions for registering additional new handsets on VTech Model DS6151: Place additional handset on main base. Press HOLD on main base and # on handset. Asks you to de-register. Press no. Registration of additional handset takes place.
Aug 17, 2010 | Vtech DECT 6.0 Digital Cordless Phone
Deregister a ds6322-4 without the base
for the Vtech cordless phones model DS6322-4 models
In the handset press
*331734# and the menu button, yur handset will be deregistered.
Enjoy unlocking :-)
May 06, 2010 | Vtech Lands Phones
Vtech not working
Have you tried putting in freshly charged batteries and registering the handsets to the base station?
May 01, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Uniden DCX640 Cordless Expansion Handset Logo
293 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
