I have a redhead safe with keypad, everytime I push any number it flashes yellow and wont let you press any other numbers. Whats up with that? Even left it alone for hours and still does this.
  • 3,799 Answers
Replace the batteries.
Posted on Feb 17, 2012
How do i fix keypad
Keypads will flash when new oven or when disconnected and setting are lost. First try setting the clock
  • push CLOCK--enter numbers--push CLOCK to see if keypad becomes operational.
If not, unplug, replug and try again. As for "fixing" keypad ....that is not likely to be the problem and even it it were, keypads are not user repairable. For further info, dial the the factory customer support phone number.
Mar 14, 2015 | Microwave Ovens
I push in the wrong radio code 3x on my 2001 audi now its stuck on safe mode and wont let me in to push in the right code
First of all you should exit from safe mode. Then turn ON the radio and let it turned ON for at least one hour, in order to exit from safe mode.
IMPORTANT NOTE:
You must have the security anti-theft code for your VW radio from the car manufacturer, or from a VW dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of a 2001 Audi Concert radio programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Audi Delta CC Radio
Please perform the following procedures while the car is parked. Otherwise you risk getting into an accident while your attention is not focused on the driving. Entering anti-theft code The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  1. Turn on radio. The radio display shows "SAFE".
  2. Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
  4. Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  5. The radio should unlock and be usable shortly afterwards.
  6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
Oct 27, 2011 | 2001 Audi A6
Have a SURESAFE brand safe at work which have no instructions
Hi there all I have a SURESAFE electronic security safe MODEL-OWSAFE30ES
(1) To set your own code first on safe
(2) locate the red reset button on the hinge end of the door.
(3) Press the red button, which will illuminate the yellow light on the keypad.
(4) Now key in your new code (3 to 8 digits) and press A or B to end. Note you have 30 second to complete this step.
(5) Test your new code whilst the door is open. Safe will beep twice to confirm code has been entered correctly, and knob can be turned clockwise.
(6) Repeat process any time you wish to change your code.,
Hope this help
regards
rick
Dec 30, 2009 | Safe International Digital Electronic Safe...
I have a safe lock SP00072 safe. And I need to know how to change the combination on it. Please help.
To reset your combination:
Press then release the red re-set button on the inside of the door.
Input 1 to 8 numbers then push the # button. The yellow light will flash on after you enter each number.
You should hear two beeps.
This will confirm the new code has been accepted.
Hope this helps.
Nov 13, 2009 | Computers & Internet
My new wireless keypad is not being recognized. WHen I push the "Learn button on the opener it does not flash.
Press and immediately release the learn button and then walk over and key in your 4 digit PIN and press enter. If your opener is older and the keypad is the new generation it may not be compatible with your opener. You need to make sure you take the model number off the motor unit when you order new parts or accessories. The model number starts with 139.
Sep 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kaypad lock won't go away.
If you are not able to unlock you mobile with the unlock key press. Try this trick
Just dial the emergency number when the phone keypad is locked.
Dial 911 or 911 it will start dialing. Then you can cancel the call and you will find your keypad unlocked.
Don't forget to give feedback
Aug 30, 2009 | Kyocera Strobe K612B Cellular Phone
My safe is open i have key but need to change combination forgot original numbers and how many numbers i need and how to do it i have lost paperwork could you please help me i am not to clever at this i am...
You need to open the door and press the red button inside the safe, on the door, near the hinge. Yellow LED will go on. Enter your new code (3-8 digits) followed by the hash key '#'. Yellow LED will go off to indicate the new code has been accepted and stored.
If the new programming attempt fails, the Yellow LED will flash with 5 beeps. You must attempt you new code again.
Aug 24, 2009 | Kitchen Appliances - Others
I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
Apr 27, 2009 | Safe International Digital Electronic Safe...
I cannot open my safe.
try holding the # and the * key for 5 seconds that should reset the safe and open it up
Dec 22, 2008 | Sentry Fireproof Safe
How do I use Dell inspiron 1300 keypad?
If you are referring to the Number keypad.
Tap the "Num lock" key and you will see a light flashing.
Make sure the light is on when you stop.
Now try the keypad.
Mar 15, 2008 | Computers & Internet
Computers & Internet Logo
316 people viewed this question
David Payne
David Payne
