Question about Dishwashers
I have a GE dishwasher model #GSP2300R20WW it runs but will not drain.
I installed it myself following the new instructions, as I removed my old dishwasher. I did not want to mess with changing out the drain hose, since the new one fit I just used the old one that was still connected to the sink. There was always a little water left in the bottom of the dishwsher after use. Since I live alone I just washed my dishes in the sink and did not use it very often. But there was also a bad odor coming from the drain in the sink/garbage disposal, even after cleaning the garbage disposaland drain with a cleaner from home depot. Last weekend I turned it on and there was a burning smell coming from the bottom, there was nothing touching the heater elements so I turned it off. It was more of an electrical burning smell. Since I had company coming I put off checking it out till today. I did not want to turn it back on unless I could see underneath it and to try to see where the burning odor was coming from. Well, I pulled it out. I decided to change out the old drain hose with the new one that came with the dishwasher to see if that would help with the odor while I had it pulled out. I also removed the connection where the hose went into the sump to see if there was food blocking the drain. It was clear....But a little white ball fell out. I left the ball there thinking it belonged. I then put it all back together and it ran through all cycles but did not drain at all. There was no burning smell and the solenoid went up and down. In an earlier post Joseph Weisenberger said that the ball did not belong, remove it and to drop it back in a hole to the left under the food trap basket. I am having a problem getting the spray arm off. I cannot see the clip/tab to pull out. Would there be a problem if I just did not put the ball back in??
  • Lori Potrykus Feb 16, 2012
    Well folks I was able to get the basket lifted enough to get the little ball in the hole on the left side of the basket. I put it all back together and it was able to go through a complete cycle draining as needed. However......there was still a little water left in the bottom ( @ 2 cups). Does anyone know why or how to fix that???
aborcass
  • 2651 Answers
SOURCE: Kenmore Built In Dishwasher
the obstruction they talk about in the disposer, its where the connection for the d/w drain is made, there is a "knockout" plug within the drain line connector( in case you dont have a d/w) that would need to be removed before the d/w will drain. can be popped out with a good smack with a screw driver, the plastic knockout will land within the disposer. disconnect power and remove the plug, it will not break up and wash away
Posted on Mar 25, 2008
jsrock516
  • 5911 Answers
SOURCE: How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Posted on Apr 08, 2008
  • 1073 Answers
SOURCE: Dishwasher won't drain
remve the drain line connected to the garbage disposal take a flat blade screwdriver insert it into the garbage disposal and hit the end of the screwdriver , the plug will pop out
to verify after hitting it stick the screwdriver back in if it has not removed the plug do it again
Posted on Apr 30, 2008
Loringh
  • 185 Answers
SOURCE: garbage disposal (water won't drain out of sink standing water)
There should be an overload button somewhere on the bottom of the disposal motor. This is to prevent the motor from trying to run if the chopping blades are jammed, otherwise the motor would burn up.
First, try to move the blades with something like a broom handle. Using a flashlight you should be able to see the blades. there's probably three of them. try to make sure each one can move even a little bit.
Next, with the disposal switch in the off position, find the overload button and push it in, Then turn on the disposal switch and see if it runs. If the overload button trips off again, repeat the above steps until the blades can turn.
Let me know how this goes. Loringh
Posted on Nov 08, 2008
  • 360 Answers
SOURCE: GE Profile PDW7300, Leaves 2 - 3 inches of dirty water in bottom
check for a clogged discharge hose where it connects to the plumbing under the sink...this is the most common area for a clog. if no restriction is found, the discharge valve will need to be tested
Posted on Feb 20, 2009
GE Dishwasher not draining on a new install but used unit.
Inspect drain hose for clog. There may be a check valve in it to prevent water from reentering the machine. I found a piece of a stainless steel scrub pad in mine. It would drain, but not completely. Remove the hose & run water thru it to test.
Aug 20, 2014 | GE Dishwashers
I have GE Profile dishwasher Model PDW9880 series. It will not drain. We had a repair man come & he said it needed a new control board. Do you think this is true? If so, can I purchase one one my...
Of course you can purchase the part. Module runs around $100. Dishwasher control boards are usually easy to replace, but there's no way I can determine if you're capable of doing it.
Jul 14, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher leak dripping down side of drain solenoid
it is possible that the plastic has developed a crack at the end of the threaded section
if you are handy with tools , turn the water off and remove that assembly( turn the power off at the plug)
check with a service agent spares department first as that part may not be available because of the age
Jun 13, 2017 | GE 24 in. GSD2220Z Built-in Dishwasher
Water is puddeling on the bottom of my 18 yr. old GE dishwasher
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Sep 22, 2009 | EuroTech 24 in. EDW194E Built-in...
Dishwasher won't drain?
HI. check the following areas for fualts.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jul 15, 2009 | General Electric Adora GHDA670N Built-in...
My G E Power1 Dishwasher is holding in alot of water,I know a little is normal.There is a lot and the water it feels slimmy.Just 2 yrs old well takeen care of.HELP
Check the following areas for faults. This is an apparent drainage issue.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
Jun 24, 2009 | GE Dishwashers
GE Nautilius Dishwasher - Water will not drain out after washing
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Apr 23, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher wont run
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important)reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
Mar 24, 2009 | GE Nautilus 24" Built-in Dishwasher
My ge Profile dishwasher will not drain
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Replace if defective (note: uncommon problem).....
Feb 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwashing machine not fully draining (2 inches of water remain). I have an open problem concerning this problem. I have a new pump. dishwashing machine not fully draining (2 inches of water remain) For...
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Apr 19, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
