Question about Onkyo Audio Players & Recorders
TX-SR919 THX has an "FS ERROR" from the optical in connected to my Blu-Ray player (PS 3). Sound comes out fine, but I don't know what the "FS ERROR" is.
  • Anonymous Feb 02, 2009
    Same thing here: "Fs Error" when connecting thru Optical Input. Sound only comes out of the center channel speaker.
  • brainstorm9 Mar 23, 2009
    I am building my new home cinema with a ps3, Epson EH-TW 5000 Beamer and my old Onkyo TX-SV919 THX. But when i use the optical out from ps3 to the onkyo receiver, I have the same error "FS Error".
    Gruitings from Germany.
    Dieter
I had this problem as well. In short the digital audio port id out-dated. You will need to buy an analog converter or an Onkyo ED-301 sound processor.
Posted on Feb 07, 2011
Onkyo TX-DS676 Receiver
check that you have selected that option on both player and receiver.
optical setting. a lot of systems are defaulted to hdmi
Apr 12, 2014 | Onkyo TX-DS676 Receiver
Panasonic BD35 won't play blu ray discs, but will play dvds
You may have come close to what the issue is---Blu Ray for several design reasons is much more critical than DVD---seen a lot with this issue----either a dirty or a failing optical pickup in the unit---I know as when first started seeing it in our shop changed a few and since under warranty found the answer--optical unit was the problem---shortly after that they started just exchanging the cheaper units.
Jun 13, 2012 | Panasonic Televison & Video
I have an audio problem with my TX-SR502.
If your remote also controls the Cable Box you might want to look at its audio settings. Maybe you muted it.
BTW: it would be a good idea to also run video and analog audio from the cable box directly to the TV if it has speakers so you can watch and listen independent of the Onkyo.
Mar 11, 2010 | Onkyo TX-SR502 Receiver
No sound through home theatre with blu ray connected
Make sure that your receiver says optical 1 or 2 on the front display.
Nov 21, 2009 | LG BD370 BLU RAY PLAYER
How to get non-hd DD or DTS sound from blue-ray on old receivers
It is not necessarily what features you have to look for, it is what connections you need to look for. Most blu ray players have the hdmi ports. On my blue ray I found it and it has the fiber optic end. I have used that and to me it sound just as good.
Oct 28, 2009 | Audio Players & Recorders
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Oct 09, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Onkyo 876 with hdmi from blu-ray sound is fantastic video poor
Get a THX video set up disk (some movies have them on) and read the Onkyo manual for video setup between source and target. I have the BD35 Blu ray and a Panasonc 37" plasma, the pic via the amp was a bit off before the 4 hours of tweaking but now looks fab, after the process tweaks the sound sync needed a bit of work to get it all synched up but it is really worth the effort.
May 19, 2009 | Onkyo TX-SR875 Receiver
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Jan 02, 2009 | Onkyo TX-NR801 Receiver
Remote Control Not Communicating with TX-DS787
Hello, I am sorry about your issue. Your hook up should have nothing to do with the remote. You should get some functions like on/off, volume control. Thank you, Onkyo, USA
Apr 25, 2017 | Onkyo TX-DS787 Receiver
536 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
