Question about IBM Lenovo ThinkPad T61p T9500 Notebook
How to enable a touchpad - IBM Lenovo ThinkPad T61p T9500 Notebook
    Novelist:
  • 73 Answers
Fn+F6. An icon would appear on the screen to indicate if pressing it is turning it ON or OFF. In some Models, holding down Fn and tapping F6 would cycle functions from Touchpad ON -> Touchpad OFF -> Trackpoint ON -> Trackpoint OFF -> BOTH ON -> BOTH OFF (but not necessarily in that order).
Posted on Feb 13, 2012
Inspiron N7010 touchpad is disabled, how to enable?
Inspiron N7010
Key to the right of the F12 key
Press the Touchpad Disable/Enable key,
(the key is located to the right of the <F12> key). Inspiron N7010
Inspiron N7010 Key to the right of the F12 key
Press the Touchpad Disable/Enable key,(the key is located to the right of the <F12> key).
Sep 23, 2011 | Dell Inspiron 1545 Notebook
How to enable touch pad
hello,
here are the steps to enable touchpad
Please, Press the "On/Off" button to turn on the touchpad. If your HP laptop does not include an "On/Off" button, press and hold the top right corner of the touchpad for five seconds and then release. A small light turns off and the touchpad icon appears briefly.
Click the Windows "Start" menu and click the "Control Panel."
Select the "Device Settings" tab and click "Enable" to enable the touchpad. Click "OK" to save the changes.
After performing the above steps touchpad will be enable.
if the issue persists, please do not hesitate to contact.
regards
Apr 24, 2011 | HP Computers & Internet
How to enable touch pad operation in ubuntu 10.04
Ubuntu provides configuration of the most common touchpad options in System > Preferences > Mouse, under the Touchpad tab.
Try the touchpad after unchecking the Enable mouse clicks with touchpad check box.
Check operation after Enable horizontal scrolling is checked. This may not have been the default setting.
Disabling Touchpad while Typing
  • Go to System > Preferences > Mouse > Touchpad and uncheck 'Disable touchpad while typing' and 'Enable mouse clicks with touchpad'
Feb 15, 2011 | Dell F3534 Touchpad
How to enable touchpad I disabled by mistake and
Step 1: Click on Start and then click on control panel.
Step 2: Hardware and Sound......Devices and Printers....Mouse.....Mouse Properties.....Device Settings.....Touchpad.......Enable........(Windows 7).
In Windows XP
Dec 18, 2010 | Dell Inspiron 1545 Notebook
Orange light comes on occassionally on mouse pad and cursor freezes, how do i stop this
Tap the orange light quickly two times to enable the touchpad. Touch the same spot twice to disable the touchpad. To see the instructions from HP type "mouse" into the Search Programs and Files. Click on "Change mouse settings" and click Device Settings. Click on "Settings" and click "Touch pad disable zone". I was delighted to have found this as I had been restarting the computer manually to enable the touchpad. Shame on HP. The instructions for this simple problem are difficult to locate for the average user. They can do better.
Dec 08, 2010 | HP Compaq Presario F730US Notebook
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
My mousepad's scroll feature is no longer working after I took my laptop to Best Buy and had them install a new harddrive under warranty
Right above the Touchpad is the On/Off button to Enable the Touchpad, or Disable the Touchpad.
If the Touchpad light is on, then the Touchpad is Enabled. (The On light is right above the Touchpad also)
Do you have the Touchpad enabled?
Dec 12, 2009 | HP Pavilion dv1000 Notebook
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
Quickplay touchpad above keyboard
The following illustration and table describe the computer TouchPad.
(6)
TouchPad on/off button Enables/disables the TouchPad.
Component Description
(1)
TouchPad light Blue: TouchPad is enabled.
Amber: TouchPad is disabled.
(2) TouchPad* Moves the pointer and selects or activates items on the screen.
(3) Left TouchPad button* Functions like the left button on an external mouse.
(4) Right TouchPad button* Functions like the right button on an external mouse.
(5) TouchPad scroll zone* Allows you to scroll up or down.
(6) TouchPad on/off button Enables/disables the TouchPad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 08, 2009 | HP Pavilion dv9000z Notebook
Touchpad inactive
is there a small button near or on the touchpad, most laptops have a small button that enables and disables the touchpad just by pressing it.
Jan 13, 2008 | Acer Aspire 5630 Notebook
IBM Lenovo ThinkPad T61p T9500 Notebook Logo
269 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
