Using Cisco Linksys e1000 to PPPOE ISP through Nanostation set on 172,29.x.x. Have connection LAN connection to 192.169.10.1. How can I set up a static route to the Naostaion on 172.29.x.x. Internet working fine. But want to the details on the Nanostation. Thanks Warren
  • 639 Answers
Hi Warren,
Hope you are doing well. Sorry about replying a bit late.
I would like to know some more detail from you before giving you the solution.Please provide the following details.
1)Is the internet connection terminated to the Cisco linksys router?2)What is the Ip address of the Cisco linksys?3)From where do you need a Static route to the nano station.4)Do you have a pc connected to the Nanostation?5)Do you have another Nano?If yes, where is the other Nanostation and what is the IP?
Please provide the details and you shall get back a solution soon.Thanks,Avishek
Posted on Feb 14, 2012
  • Warren Robinson Feb 14, 2012
    1) The Cisco Router is conected to the internet via PPPOE showing the ISP internet address (WAN)
    2)The LAN address of the CISCO router is 192.168.10.1.This is the gateway address on the PC. PC is 192.168.10.6.
    3) I what to connect to the Nanostaion 172.29.x.x which is the station bridge to the AP, from the PC
    4) Only one Nanostation.
    5) The PC is connected to the Cisco router as above.
  • Avishek Samaddar
    Avishek Samaddar Feb 14, 2012
    Yes, to do this there are some simple steps that you need to perform in your PC.
    1)Go to the network connections wizard and give an additional ip address to the Wifi / LAN connection through which you want to connect ot the Nno in the same ip range as 172.29.0.10 and a subnet mask as requiredbut no give any gateway ip as the primary gateway of your PC is 192.168.10.6
    Now go to start and Run and type "cmd" then pres Enter.
    Command prompt will come. Here type the following
    cd\ then Enter
    route add 172.29.0.0 mask 255.255.0.0 172.29.x.x(NANO IP)
    now ping the nano and see what you get..
Need to add another computer to my Linksys E1000 but lost the CD
You don't need the CD. Post the make, model of computer and the OS on it.
Dec 26, 2012 | Cisco Linksys Wirelessn Router Black...
When I try and install my E1000 linksys router it causes the phone line (dial tone) to disappear. Also it doesn't have PPPOA as a protocol option. Also the linksys setup software says that it is n
Don't you require an RJ-11 for a phone line, cause I don't see one on this model? In any case, the ATM protocol should be handled by the ISP modem, and the router should just pick up the established network over Ethernet.
Connect the ISP modem to main uplink port. Then connect pc to any other port. Done. Some models come with a setup disc, but not absolutely required.
http://homedownloads.cisco.com/downloads/userguide/E1000_V10_UG_USA_NC-WEB,0.pdf
Nov 22, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Where do you get cisco connect
Cisco connect is the software that comes with the router.
You might have installed the Cisco connect software while installing your router for the first time.
Once you open the Cisco connect software for E1000, you will find the password to access the wireless network.
If you have not installed Cisco connect then you can open the setup page of the router and check the wireless settings.
Dec 17, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
I lost y E1000'spassward and cannot access wireless connection
Have you installed Cisco connect software while setting up Your E1000 router?
If you have installed the Cisco connect then you will find all the settings there. If not then you can open the setup page of the router and check the wireless settings. Read Linksys E1000 Cisco connect
Nov 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Just purchased a Cisco Linksys E1000 Wireless-N Router. I am unable on my wireless laptop to connect to the internet. The Error I am getting from my computer is: The settings saved on this computer for the...
make sure you
1.install the router properly with Cisco Connect software
2, turn on wireless modem in you PC
3. check the signal receive status are found and connected.
if you still can't solve the problem you can get more technical information here.
Dec 25, 2010 | Linksys E1000 IEEE 80211bgn Wireless...
I cannot connect wirelessly to my router from my lap top
Check this link
http://fixhomenetwork.com/blog/linksys-e1000-e2000-e2100l-e3000-router-setup/
Set up a Linksys Wireless Router
  • 1 Choose and purchase a Linksys router, taking into account your budget and computing habits.
  • 2 Attach the antennas to the Linksys wireless router.
  • 3 Place the router in a central location, making sure it's not surrounded by metal. (A signal can't be obtained through metal.) The router should be located so that the distance between clients (computers) is somewhat equal. This will create a better connection.
  • 4 Plug the Ethernet cable into the "Internet" port on the back of the Linksys router.
  • 5 Connect a computer to the router by plugging another Ethernet cable into the Ethernet port on your computer and attaching the other end to one of the available ports on the back of the router. You can choose any port except the one labeled "WAN."
  • 6 Plug the router into an electrical outlet.
  • 7 Wait for the power light to stop flashing, at which time the router is finished booting up. While the router is booting, the power light will be blinking. This process may take a few minutes to complete.
  • 8 Reboot your computer so it can access a new IP address from the router through the Dynamic Host Configuration Protocol (DHCP).
  • Configure the Router
  • 1 Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
  • 2 Use "Admin" as the username in the pop-up box and leave the password blank.
  • 3 Connect to the Internet and click on "Internet Setup."
  • 4 Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
  • 5 Set a service set identifier (SSID) to identify the router and change the password.
  • 6 Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
  • Sep 26, 2010 | Cisco Linksys E1000 WirelessN Broadband...
    Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
    by default ip address of linksys is 192.168.1.1
    to star config you need to be connected with ethernet cord rj-45
    or conenct via wireless by conencting to linksys on wireless
    admin user: blank
    admin pws: admin
    *choose a protocol on your linksys router on internect conenction type:
    check isp protocol :
    dhcp: needs serail number of mac address
    it picks up automatic
    pppoe: needs username and pws from isp
    *the ip address has to be diferent from the isp modem:
    isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
    isp modem 192.168.1.1 linksys 192.168.2.1 correct
    change the ip on lan settings on your router
    *wireless: ssid by default is linksys
    ssid: linksys
    wep : none
    to setup wireless
    access the wireless basic
    change the ssid to any network name
    enable the wireless password
    choose wireless security
    enable wep key 10 digit hex pws
    make shure you saved settings on every setting
    May 04, 2010 | Linksys WRT160N Wireless Router
    Trying to set up LInksys WPS54G, connected as
    admin user: blank
    admin pws: admin
    ssid: linksys
    wep : none
    to setup wireless
    make shure you saved settings on every settings
    Feb 12, 2010 | HP LaserJet 1320n Printer
    Cant get my linksys router to work
    does your ISP use DHCP or PPPOE and what is the LAN IP address of their MODEM ,,, now IF they use DHCP and Lan ip is anything other than 192.168.1.1 then in back of linksys press reset button in back of linksys and hold it down (with power on to linksys) for 20 seconds then wait for 2 min and turn linksys off (unplug pwr cord) and your modem off for 3 to 5 min. turn your modem on first and wait for your dsl light and wait 2 min then turn pwr on to linksys (plug pwr back in) and wait another 2 min. IF ISP is PPPOE or if their mdm has same lan ip have your ISP bridge mdm if they have dhcp you won't have to do any thing else but pwr cyc as i said above if they use pppoe then have linksys on and type 192.168.1.1 in address bar and type "admin" in for password only (if that don't work use it for both then where it say internet connection type set it for pppoe and type in your email address and password in the username and password field and save and pwr cyc mdm and router again
    Oct 25, 2009 | Linksys Wireless-G WRT54G Router
    Computers & Internet Logo
    66 people viewed this question
    David Payne
    David Payne
