Question about Refrigerators
Franke STAINLESS SANDWICH CHUTE repair manual
My Kenmore Elite grinder and coffee brewer ground this morning, but then would not brew. Any ideas? The machine stayed on but never made another sound.
Try cleaning the chute from the grinder to the basket. Coffee oils build up and plug the chute. I clean mine every 3 - 4 days and have had no problems.
May 01, 2014 | Kenmore 12-Cup Coffee Grinder and Brewer,...
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
I am looking to buy a sandwich maker like the 17936 and set it on timer for the morning so they are ready for when I wake up and go to work - does this russell hobbs model heat up and then stop heating...
Here are a few links to some information about the Russell Hobbs Model 17936 Sandwich Maker:
http://www.amazon.co.uk/Russell-Hobbs-17936-Sandwich-Maker/dp/B002MRS1NM
http://www.reevoo.com/p/russell-hobbs-2-sandwich-maker
http://www.sonicdirect.co.uk/catalogue--iID--5785--russell-hobbs-17936-2-slice-sandwich-toaster-in-brushed-stainless-steel.php
I don't think you will find a small sandwich maker with the type of automatic timer you are describing. Most full size digital ovens have that function, but very few smaller units like the 17936.
Also, would it not be a bit impractical to leave a sandwich with perishable toppings in the machine overnight in order for it to begin cooking in the morning? Any kind of meat product left out overnight unrefrigerated may become dangerously contaminated and spoil.
For all the time these machines take to heat up, you might as well just get up 5 minutes earlier in the morning and prepare your sandwich then.
Good luck though either way.
Jun 14, 2011 | Microwave Ovens
The ice maker is working fine but ice cannot be dispensed because the chute keeps on freezing
The door to the chute is sticking slightly open allowing moisture in an freezing the chute and the door is then frozen open. You will have to disassemble the small door assembly, there has to be an obstruction holding this small door open.
Jan 03, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
What is the difference between franke sink and
It's what some contractor likes. If you find a sink that you like, buy it. ANY decent contractor can easily and successfully mount ANY sink.
Aug 09, 2009 | Moen 22119 - Commercial Stainless Steel...
Oven-part of Franke Stove not working.
I have a Franke gas stove top and under one burner knob the spring is broken. Model #AD 72 M WQ
Jul 10, 2009 | Ovens
Franke overflow waste connection
Once that fitting is damaged it is very difficult to repair. Try contacting Franke for nearest distributer and see if they will replace.
Mar 25, 2009 | Franke PAX-170 Papillon Undermount...
Installing a Pot Filler
Hi 13Kat,
I'm Harvey the Master Plumber.
You must connect to a flanged fitting behind the wall. The wall is sandwiched between the flange behind and the escutchen in front that holds the pot filler in place. These are usually installed on stainless steel sinks that have stainless steel back walls and do not come supplied with the flanged fitting, available at any plumbing supply.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Oct 06, 2008 | Franke PF3000 Deck Mounted Pot Filler...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
