Question about InFocus LP 820 Multimedia Projector
Display green circle section in middle of screen
Image began having a light green circluar section in middle of screen. Over time continues to grow and also a blue/purple hue shows in right top corner of the screen.
5 Suggested Answers
Marrie
  • 563 Answers
SOURCE: Color not correct on project
Hi there
You will have to find your nearest InFocus repair centre.
But that said , it is the most expensive part on a Projector to have repaired , because they will have to replace it.
My advice would be to rather purchase a new unit.
Posted on Apr 16, 2008
projdoc
  • 2236 Answers
SOURCE: Proxima Ultralight X350 DLP - no image showing
go into the menu and the service or settings option. reset the settings to factory default. also, it does not do hd. make sure the resolution matches.
Posted on Sep 04, 2009
  • 269 Answers
SOURCE: thick purple line scrolling up from bottom of screen continually
if it is a uniform pulsating line, then it is the main board or engine. if it is a fuzzy line it is the light tunnel
Posted on May 11, 2010
  • 17 Answers
SOURCE: We have used our projector
Are you using component video inputs? You could check the green connectors on both ends of the video inputs. They sometimes develop a poor connection. I would not throw a lot of money at it. It was a good projector in its day but they sell used on ebay or craigslist for $100 - $300 now.
Hope this helps,
Posted on Feb 20, 2011
What board to replace on my tv?
OK. Replace all the boards in it; one at a time. If it do not help you, discard the set, and buy a new one. What else?
Aug 27, 2016 | LG Televison & Video
Tip
Wide screen monitor distortion Depending upon the screen resolution that has...
Depending upon the screen resolution that has been set in Display, the image will be distorted on these large wide screen monitors.
To correct this distortion.
1. Create a large circle image using a draw program such as Paint (hold down the Shift key as you create the circle as it will draw a perfect circle).
2. Open Control Panel - Display - Settings tab and adjust the Screen resolution slider, increase or decrease the screen resolution then bring the circle image to the front and check the image, if the circle is still distorted then change the screen resolution and check the circle again until you are satisfied with the image of the circle.
3. When you are satisfied then click apply.
on Feb 24, 2011 | Computers & Internet
Mitsubishi flickering white lights on screen
this sounds like a bad optical light engine, the spots will only continue to grow in number.
See typical engine for this brand, lens on left is where image comes out and is directed on the screen.
Dec 22, 2012 | Mitsubishi WD-65733 65" HDTV
FIX SCREEN RESOLUTION
Depending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Mar 14, 2012 | Dell OptiPlex GX260 PC Desktop
Wide screen stretches all my photos
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Dec 09, 2011 | Samsung Computers & Internet
Green spot in middle of image as though a spot light was shinning on the screen. I've replaced the lamp
Welcome to LCD 101, the blue device is dying in the projector. Replace product with dlp brand and it will last a lifetime. good luck
Apr 14, 2009 | Epson PowerLite® 1700c LCD Projector
3LCD Projection TV 2.5 years old displaying blue hue/blobs
I would first try a new lamp. If the reflector portion of the lamp has any defects, it could show up this way as the light would not be uniform. The next possibility is a defective light engine. The engine portion if not field repairable and would need to be replaced. Try the lamp first and let us know what happens.
Dan
Jan 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
Aug 08, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Image has big yellow
Hi Zenmast
This is a burnt LCD that will need replacement. If the circle is yellow on a white screen , then it is your blue LCD that will need replacement.
Apr 22, 2008 | SharpVision XV-Z1U Multimedia Projector
InFocus LP 820 Multimedia Projector Logo
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
