Question about Hotpoint Washing Machines
Hotpoint aqualtis keeps tripping switch
My hotpoint aqualitis AQ9D 69 U washing machine is on the baby cycle and keeps tripping the main trip switch and can't do anything cause as soon as you plug it back in it trips again
5 Suggested Answers
  • 166 Answers
SOURCE: hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Posted on Aug 26, 2009
  • 41 Answers
SOURCE: Hotpoint 9537 washing machine tripping electric
You have a problem with Live feed shorting to earth on a main component. You need to switch off machine and seek a qualified electrician ASAP
Posted on Sep 03, 2009
beltronic205
  • 1460 Answers
SOURCE: just bought a new hotpoint aqualtis aq9d 69 s
Firstly remove transit bolts. Then connect hoses..Make sure water turned on..Good luck
Posted on Sep 29, 2009
richroth
  • 9472 Answers
SOURCE: my hotpoint aqualtis aq9d 69 u is changing the
You will need to replace the "atc board" (automatic temperature control) in your machine. Here is a link to the part.
Posted on Jan 13, 2011
My Aqualtis AQGD 169 S keeps tripping the mains switch
Make sure you are on a dedicated circuit for this machine and that it is a 50 amp circuit. After that you may have a bad breaker switch which is pretty easy to fix. You also cannot rule out that one of your components went bad on your washer.
Feb 28, 2015 | Washing Machines
Aqualtis aq9d 69 s change language to english
WITH THE MACHINE SWITCHED OFF HOLD IN THE TEMPERATURE BUTTON ,AND THE SPIN BUTTON AND ALSO THE TIMER BUTTON ON THE TOUCH SCREEN TOGETHER FOR ABOUT 20 SECONDS THEN IT WILL COME UP THE LANGUAGE,SELECT THE UP OR DOWN ARROW THEN PRESS OK TO CONFIRM ON SCREEN .IT DOES WORK AS I HAVE JUST BOUGHT THE SAME MACHINE AND DONE IT FOLKS VERY EASY
Jan 09, 2013 | Washing Machines
My washing machine keeps tripping the electricity
there is a shot on the power supply board, that's why it trips. Have is checked.
Jan 05, 2012 | Hotpoint Washing Machines
My Hotpoint Aqualtis washing machine leaves
the drain **** in the machine is partially clogged. my best guess is at the water pump. your washer needs to be serviced. call a serviceman..
Nov 15, 2009 | Washing Machines
Hotpoint aquarious wd 440 two years old tripping main board
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WM64 keeps fusing and cutting out
it's possible that one of the carbon brushes have worn down to the bottom and it is sparking on the motor causing it to trip the fuse. It's just one possibility. Have you checked the carbon brushes are connected properly and that they have not 1) worn down and 2) that the wires are connected to them correctly.
Mar 12, 2009 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
596 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
