Question about Kenmore Dishwashers
Kenmore dishwasher wont turn on seems to have no power.
We used the dishwasher two days ago just fine, went to turn it on tonight and none of the buttons on the control panel will light up or start.
  • 341 Answers
Check the breaker in your breaker box, it may have tripped. Reset it and run the dishwasher. If it trips again, have the dishwasher looked at by a professional service person.
Posted on Feb 13, 2012
  • 127 Answers
SOURCE: kenmore dishwasher ultra was quiet guard 3 model
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
SOURCE: Kenmore ultra wash dishwasher control lock light flashing
Hi jabberr216,
I'm Harvey the Master Plumber.
Your question is: You have an older model Kenmore ultra wash dishwasher model #15805890. The control lock light is flashing. No buttons are working. The dishwasher does not turn on. Any solutions?
Sure! Someone must have activated the lock. It is next to either the 'air dry' or 'heated dry' button.
Press and hold that button till the lock light goes out. About 6 seconds. That's it. It turns on the same way.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 03, 2008
McLindy
  • 32 Answers
SOURCE: Kenmore Elite Dishwasher- The touchpad
I have a Kenmore Elite model 665.15962990. I have had it for 8 years. A few days ago the touch panel seemed to go dead and so did the LED. After pushing the buttons several times the motor kicked on, but the washer behaved strangely. The LED displayed what looked like Klingon.
After looking through the Repair Parts Lists with its exploded view of the washer components, I narrowed the problem down to either the power module (part # 9744031), the console assembly which includes the button touchpad (part # [white = 3384101], [bisque = 3384150], [black = 3384100]), or the dual light display a.k.a. LED (part # 3383825).
I took the washer apart because I was told I can't return the power module and it costs roughly $150 at my local appliance repair shop. In looking at everything, the power module is the most likely candidate. The LED is a separate unit and is powered by the power module. The buttons are the same way. Since both of those separate components are behaving strangely, my best guess is the power module is not powering either of them correctly.
Also I found this link: http://www.askmehelpdesk.com/appliances/kenmore-dishwasher-not-working-all-27100.html
I hope this helps someone.
Posted on Nov 18, 2008
vitg55
  • 74 Answers
SOURCE: kitchen aide dishwasher KUD101IL control panel not working
1. Check plug outlet.
2. Check electrical box underneath the d/w where power cord connected to d/w (you have to take the kick panel off . The box located on right side). Sometime you can find burn wire there.
3. Check the thermal fuse on computer board. It is inside the control panel on right hand side. The fuse has 2 white plastic connector which sticks out, easy to find.
Posted on Dec 08, 2008
rickead1
  • 1998 Answers
SOURCE: Maytag MDBtt60awb
most likely you have a bad motor when replacing the motor ihave found it is cheaper to get the pump with the motor attached where as they charge you more money for just the motor or the pump seprately try allbrands appliance parts they seem to be cheaper
Posted on Apr 30, 2010
My 2003 Mercury Mountaineer has an electrical problem. It started about a year ago with the key fob not working, I have bought 3 and all won't work even after re-programing. now tonight I went to
Could be a windshile leak down the A-Pillar & water
gets into the delayed accy relay for the GEM Module
(Body Computer as ford called it for a few years) & you
get what you have now
Try Goolge as I did a few weeks ago for a relative
He had the same issue with the blower being on &
killing the battery
No real fix I found for the windshield leak
Seem a robot didn't put the rubber sealant
on correctly at the factory fo about 5 years
on several fords.
If it isn't water related then the GEM Module
controls all those body features
If you get a used one & match up the numbers,
you supposedly can avoid buying a reman gem
& the expense of having to reflash it to your factory
built combination
Jan 27, 2013 | 2003 Mercury Mountaineer
My dishwasher (Model # FDB520RHB0) is not quite 2 years old. We had the water pump replaced a few months ago because it had been making a grinding noise. Then we tried to run it a few days ago and it...
Did you check the outlet with a voltmeter? If you did and have 120Volts then it sounds like your latch switch could be defective which would kill the power to the unit.
But remember that in most houses that the outlet under the sink is wired for a garbage disposal where the top outlet is controled by a switch and the bottom one is wired for the dishwasher.
Jul 27, 2011 | Frigidaire FDB520RH Builtin Dishwasher
Kenmore Dishwasher only hums after used bleach to clean
Kenmore d/w 363.1407 is made by GE...... sounds to me like the motor is stuck. Unplug d/w and remove access panel... try to free the motor by turning the cooling on the motor shaft. Hope this helps..
Mar 17, 2010 | Kenmore Dishwashers
My Kenmore Elite 15919001 just stop working from one day to the next. It just seems like a fuse blew because I have no power to the dishwasher. None of the buttons work on the front board. Help!!
yes, it sounds like a fuse, or a circuit breaker tripped, or, if it is a plug-in connection, it may have come unplugged(outlet usually under sink. Might also have a loose connection in dishwasher connection box ..CAREFUL HERE;VOLTAGE MAY BE PRESENT!!!
...IT MAYBE THE DOOR IS NOT FULLY PUSHED IN TO ENGAGE SAFETY SWITCH
Feb 21, 2010 | Kenmore 15919 Built-in Dishwasher
My toshiba laptop will not turn on...
This could be a few things. It could be a bad power cord not charging the battery or the machine. But it could also be various other things. The cheapest and easiest thing to try is a new power adapter.
May 26, 2009 | Toshiba Satellite A60 Notebook
Kenmore undercounter dishwasher quiet guard
Presuming that your circuit breaker is not tripped and you have power to the dishwasher, it appears that your thermo fuse is blown. You can replace it for around $20. It comes in a kit form or you can replace the thermo fuse for around $1. The part number is NTE 8096 Thermo Fuse 98 degrees Celsius and solder it in yourself. It is located on the circuit board that contains all the relays and the main computer chip. It clips on and off.
Sep 14, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
Dishwashers Logo
238 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
