Question about Ovens
F2:E3 error on kitchenaid superba - Ovens
4 Suggested Answers
SOURCE: F2 E3 error code- Oven won't turn on now
I ended up calling a technician to come out and look at it. He said that the front panel where you push all the buttons went out and I would need to get a new panel.
Posted on Feb 18, 2009
TheMobilian
  • 8220 Answers
SOURCE: error message on panel of my kitchenaid oven
shorted keypad
Posted on Mar 21, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: My KitchenAid Superba oven is not heating. Code
Hello and sorry to hear about your problem. The code you have given, will have this problem. I suggest you contact a service person.
F2-E5 - Cancel Key Line Open - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
I have tried to help you. Please help me by Vote/Rate the response. Thanks and good luck
Posted on Dec 20, 2010
Kitchenaid Superba Gas oven and cooktop. I frequently get a F2: E1 code, which goes away when I reset the fuse. Also, the 1, 4, and 7 touch pads don't work but all others do.
You have a bad touchpad. The ribbon cable is a failure point on all of these whirlpool built ovens. Enter the model number in at this link and see if they make a replacement keypad for your oven: Introducing the Ledgestone Technologies Touchpad
Aug 25, 2016 | KitchenAid Architect II Superba EQ Series...
Fix f5 e 1
F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
Kitchenaid superba oven
Defective keypad, control panel or both.
Nov 22, 2013 | Ovens
Just got error code "fe02"
The F2-E0 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F2-E0 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced . GENE
Sep 18, 2011 | KitchenAid Ovens
Getting an error message from the oven, F2:E3
If you've determined the keypad on your Kitchenaid oven, range, or wall microwave is faulty and youre searching for an obsolete part, http://www.FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order. We're happy to help you solve your problem!
FixYourBoard.com
May 08, 2011 | KitchenAid KEMC378 Electric Double Oven
My KitchenAid Superba oven is not heating. Code F2- E5. thank you
Dec 20, 2010 | KitchenAid KEBC107 Electric Single Oven
My oevn will not work and range had the mesaage: F2:E3 and now F2:E1. Can diagnose the problem. Tom Wilson Thomas_Wilson@rush.edu
F2 - E1 Keypad cable unplugged 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
.com
Nov 26, 2010 | KitchenAid Ovens
Error code F2 E3 r:02 E:03
Kitchen Aid Error Code F2-E3
Called kitchen aid, they said you need a new control board part #9782455.
Mar 16, 2010 | KitchenAid KEBC107 Electric Single Oven
Kitchen aid oven is'nt working and giving code F2:E3 help what does it mean
Here is a page with all of the error codes for your oven.
http://www.appliancetimers.com/index.php?page=failure_code_page&manufacturer=ka&type=r
Your code is 2 parts, F2 is oven temp is too high, and the E0 wants you to test the relay contact operation. In simpler language make sure the connections are tight.
May 09, 2009 | KitchenAid Ovens
Ovens Logo
607 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
