Question about Bburago Citroen C6 Diecast Model
Peugeot 807 my keeps smoking the electronic dash says change deisel filter,only had a new one installed in january can you tell me how to change the filter
THE MESSAGE ON THE DASH MAY BE RELATED TO THE DIESEL PRTICULATE FILTER WHICH IS PART OF THE EXHAUST SYSTEM AND WHICH CAN BE REGENERATED. THIS IS DONE USING THE DIAGNOSTIC MACHINE. IS THERE ANY OTHER MESSAGES ON THE DASH i.e MINIMUM ADDITIVE LEVEL REACHED OR RISK OF BLOCKING?
Posted on Nov 20, 2008
Looking too buy peugeot 807 deisel 2.2 hdi been told it goes in limp mode but it still drives and willeventually get to 70 or 90
When a transmission is put into limp mode by the pcm/tcm, it's for a reason. The limp mode is to limit further damage until the problem can be diagnosed and properly repaired. Keep driving it and it will require a new transmission.
Jan 30, 2017 | Peugeot Cars & Trucks
How to remove seats from a Peugeot 807
fronts are bolted in ,move seat back and forewards to gain access ,rear seats should lift out to turn into a van,,, think you lower back tilt seat then pull a lever or a strap ,my galaxy comes out easy but getting them back in ,,,,so heavy
Dec 01, 2015 | 2005 Peugeot 807 2.0
Citroen dispatch
Had the same-problem with the peaugot 807 giving out black smoke, I was fueling at morrisons regular was told to change petrol pump so I start using shells and the black smoke stopped compeletely. Try using a different petrol pump if that dont work than take it to the workshop.
Jun 02, 2013 | 2006 Peugeot 604
Sliding door fuse keeps blowing
unless someone disabled needs that function, just let it not work. i have a 2000 pontiac montana whos electric sliding door doesnt move electronically anymore but if you just yank it, itll open and slam it shut. its an inconvienience but its not worth the money to fix unless, like i said, someone disabled needs it
Oct 18, 2012 | 2005 Peugeot 807 2.2
Peugout 807 lighter sockit
Did you ground it because you need to ground it my friend
Sep 22, 2017 | 2005 Peugeot 405
Hi, I have a peugeot 807 & shortly after I had the water pump changed the Antipolution warning started cumming up & the motor shakes like its about to jump out of the car,black smoke,higer fuel...
the 807 uses an additional small tank of additive which needs to be checked refilled to basically burn off the carbon build-up in the exhaust chamber this is linked to the filler cap sensor if the ceramic in the exhaust is clogged then damage can result from continuning to drive the car check this site for how it works mine cost 400 euros to sort!! http://www.psa-peugeot-citroen.com/modules/fap/anglais/index.html
Sep 19, 2010 | Peugeot 604 Cars & Trucks
Bburago Citroen C6 Diecast Model Logo
222 people viewed this question
Top Bburago Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Bburago Toy Expert? Answer questions, earn points and help others
