Question about Garden
Changing drive belts on Greenfield mower
How to change drive and cutter blade belts on Greenfield 32" mower
rockitman187
  • 2559 Answers
SOURCE: need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
Posted on May 10, 2009
  • 4 Answers
SOURCE: deck drive belt comes off when disengaging mower
Need to adjust the tension on the belt.
Posted on May 18, 2009
  • 153 Answers
SOURCE: BELT ADJUSTMENT
There is an idler pulley near the drive pulley under the engine. It is made of plastic and is a common failure. It freezes up and doesn't want to let the belt move. Have you noticed the smell of hot/burning plastic? You can replace it with an original, but it is still plastic. Metal replacements can be had. I think I got some from mcmaster.com so try there. They are a great resource. Shipping is fast and inexpensive and they have everything a guy could want.
Posted on May 28, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
vincob
  • 718 Answers
SOURCE: I need a diagrahm of a belt drive greenfield ride
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Posted on Nov 10, 2010
Have a Cox Stockman ride-on lawnmower that wont cut. Just added 2 new blades (using 4 high lift blades) and still have to go over 100mm grass 3, 4 or more times to cut it down.
check for slipping drive belts
check that the cutter spindle bearings are in good condition as they may be failing and slowing down the cutter blade speed
Dec 16, 2016 | Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
How to change the belt on a craftsman rear wheel drive lawnmower
open drive cover take plug out roll belt off pully by pulling it to the side and hand turnig the blade after comes off drive remove blade and take off belt to reinstall do reverse
Aug 28, 2014 | Craftsman Garden
Can't get mower belt on
Make sure that the brake is off and the cutter control is on. Most mowers lock the blade drive belt when you brake or switch off the blades.
Nov 21, 2013 | Garden
Changing Blades
With most small lawn tractors I've dealt with, you want to unhook the deck-blade drive belt, some have one large belt that turns the blades as well as the rear wheels, others have more than one belt.. usually you will find four brackets that suspend the entire mower deck below the lawn tractor. To locate these brackets raise the mower deck so that its not resting on the ground, then push the mower deck side to side and notice where the attaching arms are moving under mower but above the deck, once you find the four brackets, lower the deck 2 its lowest point. remove the connecting pins noting the exact hole each pin came out of, if you have not removed the belt bye now do so at this time. you may find a stubborn piece of metal preventing the belt from coming off near the larger pulley Don't bend it out of the way just remove or loosen its nut,its there 4 a reason. so now, 1 the belts off the pulley. 2. the pins or bolts have been removed from the suspending arms and the hole positions have been noted. remove any other actuating rods or levers remaining so that the mower deck can slide out from under the mower. you may have to put the front wheels on a 4x4 blocks or similar to accomplish this. once you've got the deck out carefully turn it upside down, use blocks to keep from mashing pulleys, etc. you will probably see two or three blades, remove hex head bolt w/ washer holding blade to spindle, be sure to note cutting side of blade and direction of travel. If you don't see bolts in the center of blade look for my other solution for changing blades and blade bearings.
Jul 16, 2013 | Garden
Install mower blades
hi there firstly disconect the battery under the seat ,then lower your cutter carraige as far down as it will go then remove all the split pins attached to the lifting arms then gently slide it out from under the carraige oh before hand disconnect the drive belt on the front pulley there you will see a round bar bracket wich you must rove from the one lacation hole and twist it then slide out the carraige and turn it over loosen the bolts and replace the old blades ad the reinstall it the same way but do yourself a favour and take a picture of the assembly in case you are not sure how to replace the cutter carraige grease all the bush nipples and bobs you uncle
Apr 29, 2013 | Garden
I am trying to remove the cutter drive pulley from my greenfield ride on mower (will not move) tried puller with heat any ideas.
Hello Mate, I know its been awhile since you posted but the deck pulley has a left hand thread. hope this helps.
May 11, 2010 | Garden
Have a husquvarna RB 150 and the belt that drives the cutter blades has come looose, how do i tighten
Normally there is no adjustment for a belt that drives the cutter assembly, the problem is the belt has stretched out and is no longer tight enough to engage the blade sufficintly, in which case it needs to be replaced. Hope This Helps Don
Nov 07, 2009 | Husqvarna Garden
Cutting deck on greenfield evolution mower will not disengage
Usually this is caused by badly worn belt or incorrect type of belt fitted, check allignment, tension, belt size should be marked as A... not 13A..... if marked as the latter it is an "automotive" type belt not suited to "slipping" when belt loosened to disengage cutter. Check also for the belt has not rolled over in the groove.
Oct 31, 2009 | Greenfield Industries Disston #752980 Mm...
Garden Logo
467 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
