Question about Garden
Can you adjust the idler pully on the pully - Garden
5 Suggested Answers
c17hydro
  • 2984 Answers
SOURCE: 1996 Cadillac Seville idler Pully Belt will not tighten
Your belt may be the wrong length. It is too long. Where did you get it from?
Posted on Mar 14, 2009
dmsr63
  • 2050 Answers
SOURCE: 2003 chryler concord ltd 3.5l engine ac belt replaced
Sounds like the tensioner bearing is frozen, not turning at all. You need to remove the belt and see if it spins.
Posted on Aug 14, 2009
milten1
  • 1304 Answers
SOURCE: how dose belly go on around idler pully
pull the loop togehter from the bottom of the drum
feed the loop threough and under the pully wheel
clip the loop on the motor pully
Posted on Oct 18, 2009
dmsr63
  • 2050 Answers
SOURCE: I have a 1997 Jimmy. I smelled rubber burning,
Just an idler, probably has a frozen bearing, you will need to get it repaired.
Posted on Jun 18, 2011
Replace idler pully on 92 Nissan. Pathfinder 4~4
Looks like there is an idler pulley for the ac belt. The alternator and ps belts are adjusted by moving the components.
The pulley is available without the bracket, so you should be able to loosen the center bolt without removing the bracket. There is an adjusting bolt or rod that you turn to tighten or loosen the belt once you have loosened the bolts for the bracket.
Apr 02, 2013 | Cars & Trucks
How to put belt back on drum on my dryer
You have to take the back off of the dryer and see the motor pully and the idler pully. slip the belt around the drum, around the mototr pully and usind a flat blade putty knife, work the belt over the idler pully so that it puts tension on the belt. you may have to loosen the idler pully housing bolts, but try it first with working it over the idler as that was set for optimum tension.
Feb 04, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Need to know how to adjust serpentine belt, please show diagram. 6 cyl engine.
Really don't need a diagram. Loosen the slide bolts on the power steering pump. loosen or tighten the pump by turning the jack screw (long transverse bolt) under the pump. Once the belt is tightened up, lock down the slide bolts and you are finished.
Jun 17, 2010 | 1994 Jeep Grand Cherokee
How to put dryer belt on pully
The idler wheel has an adjustment screw - loosen it and move the pulley.
If there is no idler - you pry it on over the lip of the pulley.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 13, 2010 | GE Dryers
How do you check the idler pully to stop squealing?
NO ADJUSTMENT IS PROVIDED FOR, THE BLET NOISE MAY BE DUE TO A DEFECTIVE IDLER
Jun 20, 2009 | 2003 Toyota Camry
Belt replacement 1990 acura integra
Ok, you will need a 10 mm socket and extension and a 14 and 15 mm wrench. One of the "idler" pullies is actualy an adjustable tension pully. loosen the center nut on the pully, and then begin loosening the 10 mm bolt from above. as you loosen it, the pully will drop, and soon enough you can slip the belt off.
good luck
Dec 14, 2008 | 1990 Acura Integra Hatchback
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
