Question about DeLonghi Electric Coffee Mill Grinder
DeLongi coffee mill #DCG-4TB
I have a DeLongi coffee mill #DCG-4TB and need the part that holds the ground coffee beans. Where can I buy the replacement? Thank you.
Doreen Cohen
doreenc@optonline.net
DeLonghi PARTS AND ACCESSORIES
1 (800) 865-6330.
8:30 a.m. – 5:00 p.m. (EST) Monday through Friday.
Posted on Feb 11, 2009
The problem is when I use pre ground coffee beans. The water doesn't run through. It comes over the top and the grounds get in the coffee. I buy them that way because they mark them down half price. I
There are whole coffee beans, and there are ground coffee beans, but there is no such thing as "pre-ground" coffee beans because you wouldn't want the beans to be ground AFTER making coffee.
If you have a problem using "pre-ground" beans, then STOP using pre-ground beans and grind them yourself.
I hope this helps.
Randy
Dec 01, 2012 | Coffee Makers & Espresso Machines
How do I clean my burr mill (Models BMX3, BMX4, BMX5 and BMX6)?
Clean your burr mill before using it for the first time. Then, to ensure optimal mill function and durability, clean it regularly following these simple steps.
  1. Always unplug your burr mill after use and before cleaning.
  2. Open the hopper lid. Empty any whole beans from the hopper. Remove the top burr mill by rotating it clockwise. For better results hold the grind setting button while rotating the burr mill clockwise. This will allow you to clean the grinding wheel and the grinding compartment.
  3. Clean the interior recesses with a soft brush. Note: Never use water or liquid for cleaning the lower grinding section of this appliance. BRUSH NOT INCLUDED.
  4. Wipe the whole bean hopper, its lid and the mill exterior with a damp cloth.
  5. The ground coffee chamber and lid can be washed in mild detergent and water. They both are top rack dishwasher safe. Do not immerse the mill or the whole bean hopper in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  6. After completely drying the whole bean hopper and top burr mill, replace the burr mill in position by aligning snaps with receptacle and rotating counterclockwise to lock it in position. For better results, hold the grind setting button while rotating the burr mill counterclockwise. Once the burr mill is in position, pull gently to check it is properly locked in position. If the burr mill comes out, repeat this step again.
  7. Replace the ground coffee chamber and lid, making sure both snap securely into place.
  8. Fill the hopper with whole beans.
Sep 02, 2011 | Bunn NHB Coffee Maker
How do I clean my burr mill (Models BM1 and BM3)?
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Blade will not spin
While I don't have this brand or model of grinder, (coffee beans, spices?), I use a small elec. grinder for grinding coffee beans and unless the grinder and cover or perfectly lined up and locked in place, it willnot grind, a safety feature. Check and make sure everything is lined up so it closed with all the lines in place and the grinder is also put into the lock position.
Aug 21, 2011 | Cuisinart Grind Central DCG-20N Electric...
WHY WON'T THE COFFEE BEANS SLIDE DOWN INTO THE MILL TO BE GROUND???
Beans as you know have lots of oil on them. Over a period of time, the oil from the beans get caked up on the shoot, or hopper area where beans are filled/stored and so it needs to be cleaned. First get as many beans out as possible, then take a soft no lint cloth and put little vinegar on it, and clean in area best you can. ( make sure machine is unplugged ofncourse) then, spray a little Pam in that area, let completely dry, then add beans and should flow easier . Thanks for using, mike from fixya
Jun 15, 2011 | Jura Capresso CoffeeTEAM TS 46505
Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
Grinder starts up but wont grind..nothing happens. one week old
I think this might be because no beans have gone down into the mill. There is a definite difference in sound when it is actually grinding beans. Try emptying the beans out, set it to the coarsest setting, put the beans back in, shake the thing a bit then turn it on.
Jan 17, 2009 | Krups Burr Coffee Grinder
Coffee Makers & Espresso Machines Logo
684 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
