Question about Garden
Idel problem i just replaced the drive belt on my snow thrower model #247.88190 and now the idel goes high to low dose the idel pully need adjusted the belt was the orignal is there a way to adjust the ideler pully at the pully cause i tried the other adjuster on the cabel and did not work
SOURCE: Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Posted on Jan 19, 2009
  • 28 Answers
SOURCE: How do I adjust the belt on my Ariens 11528 snow
by the handle under the handel little ajustable rod
Posted on Feb 22, 2009
  • 715 Answers
SOURCE: !332 Snow Thrower will not Start - At full choke
change gas filter and spark plug
Posted on Oct 07, 2009
  • 3911 Answers
SOURCE: Is there a GENERIC Snow thrower for John Deere 110?
Two Stage - Snowblower - Snow thrower - Bercomac All of the Bercomac attachments are interchangeable on the same quick hitch mounting. Bolts on in minutes. What a great idea for people who have more than one tractor or buy a new one. No more having to go and buy all new attachments for the new small tractor, just buy a different model hitch kit if it doesn't use the same one. The resale value is preserved when you can sell your attachments to be used on another size or model lawn and garden tractor.
camcorder-pic.jpg Snowblower video clip
Snowblower-Snowthower Q&A's
If you are ready to buy or want more details give us a call: 1-800-618-8738 or e-mail jim@jimsrepairjimstractors.com
Posted on Oct 15, 2009
rwvanlue
  • 486 Answers
SOURCE: How to adjust the Toro 826 snow thrower
Belts will have spring tension on the idler pulleys.
Both traction and auger control cables will also have cable length adjustments to cause the travel of levers or idler pulleys to tighten belts. Adjustments are commonly located under the control panel/levers.
Posted on Dec 04, 2009
The drive belt on my Sears Craftsman snow thrower model 31AM32AD599 keeps coming off
Typically that will happen when your drive belt has stretched and you can no longer adjust out the additional length. Purchase a new belt and install it and the issue should go away.
Semper Fi,
Z
Feb 01, 2018 | Craftsman Garden
Briggs&stratton snow thrower model 536.881510
Sounds like a belt that is worn out or needs adjusting to tighten it up.
Feb 11, 2014 | Garden
I need to tighten the belts on my Atlas Snow thrower
There should be an idler pulley with some sort of adjustment. Usually it is just a pulley with a bolt through the center that goes through a slotted hole on the frame. If you loosen the bolt and move the pulley toward the belt, it will increase the tension on the belt. If the bolt is already to the end of the slotted whole and cannot be moved further in, then the belt is worn and stretched and needs to be replaced. Keep in mind that there are other idler adjustment mechanisms that might be used. This is just the most common.
Dec 30, 2012 | Garden
I am looking for belt size for HABAN 24577 snowthrower to Murray 18hp lawn tractor. Book doesn't provide size info.
I have a Haban Model No. 24577A 42" front mounted snow thrower attachment, which I have mounted to a Murray lawn tractor. I needed to replace the lower drive belt, labeled: V-Belt-Long Part No. 23948 in my Haban manual. I had found it next to impossible to find a replacement belt part number or cross-reference to other brands. I tried many belt sizes and lengths to no avail - belts broke quickly and suddenly after 1 or two uses.
While researching Haban on the internet, I realized that they also supplied snow thrower attachments for Sears Craftsman lawn tractors. A thought hit me at one point in my research... that Haban probably sold the same snow thrower chassis to all manufacturers, but only with different interfaces to the tractors. So I ordered up a belt for a different Haban model that was supplied to Sears, and I think that my intuition was correct!! I have found a belt that works with my Haban Model No. 24577A snow thrower.
The belt that appears to be a direct replacement for the Haban belt part number 23948 (long) is as follows: Kevlar Blue V-Belt 5/8" x 87". It is sold by several suppliers under various part numbers, priced at $20 to $30.
I hope this helps you.
Jan 19, 2011 | Garden
My MTD 10hp auger will not turn. I adjusted the auger cable by tightening the bolt on the handle. I disconnected the spark plug and checked the shear pins on both sides of the auger. They are both still...
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Jan 08, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
