Question about GE Refrigerators
GE Fridge model PSS25NG is freezing the food how do I fix it
The freezer works fine but the fridge is freezing the food and the temp adjustment will not raise the fridge temp back up above 31 degrees. How do I fix this problem?
SOURCE: I HAVE THE GE PROFILE
likely the compressor... we have the same fridge and had the same thing happen. It was sporadic...would work, then not. Finally had GE out to repair - not cheap. Part and labor was almost $300.00 and took 2 attempts to repair.
Posted on Jun 23, 2008
  • 3 Answers
SOURCE: Ge Fridge freezing in fridge area
The freezer should be set to 0 degrees and the fridge 37 degrees according to the manual. If your unit has only numbers then it would number 4 or 5 for the freezer and 6 or 7 for the fridge.
  • 74 Answers
SOURCE: GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Posted on Aug 28, 2008
SOURCE: fridge not cold
I have a side by side fredzer and refrigerator digetal thermometer . The freezer temperature will not go below 54 or 53 and the refrigerator states at 43or 45.
Posted on Aug 29, 2008
bobicehouse
  • 1524 Answers
SOURCE: fridge not holding correct temp. fridge is 55 and freezer is 25
Sounds like a defrost problem.
Posted on May 07, 2009
Why is fridge not cooling?
Did you check to see if the auto defrost mechanism is working? Defrost heater any good? Ice in back of freezer?
Nov 26, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
Food freezing in crispers in ge bottom freezer fridge
Check to see if the fan is working...put a thermometer in the refrigerator and make sure the temps are between 33-41 degrees F.
Dec 18, 2013 | GE Refrigerators
My tbx14sabnrww refrigerator is freezing my food. Suggestions?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 20, 2009 | GE Refrigerators
My refrigerator is freezing on the freezer side and the other side where the food goes is not working
Oct 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My fridge keeps freezing my food
Oct 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Food is freezing in refrigerator
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 13, 2009 | GE GSS25LGM Side by Side Refrigerator
GE Profile Side by Side is getting too cold on the fridge side.
the dampener door in the fresh food is more then likely broke . allowing air in to the fresh food.
Jun 06, 2017 | GE PSS25NGNBB Side by Side Refrigerator
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jun 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Jan 28, 2008 | Arctic Air R22CW Refrigerator
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
