Question about Linksys Wireless-G WRT54GS Router (e125894)
CAN'T cONNECT I am unable to connect to the Wireless Router with my Lap Top. Indicates can't anthenicate.
    Scholar:
  • 87 Answers
You must set up the security settings that are in the laptop to match the settings in the router. These may be WEP, WAP, MAC address filtering or others. To change the settings in the router, you would used the web based interface. If you need more info:
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859761879&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=6187945678B11
Posted on Oct 24, 2008
Lap top wireless connection to internet router
you need to turn on the wifi button on router
Feb 16, 2014 | HP Compaq nx6110 PC Laptop
I cannot get wirelessconect to my laptop from my netgear modem router DG834G.I can see the signal but unable to connect
check whether the dhcp option is turned on in ur wireless router. if its turned off, change it to on state and try. u will be able to connect. still if u din get access. use some other lap to connect to ur wireless network. if it is possible to connect with someother lap, then the problem is with ur lap. the wifi drivers might get corrupted. re-install it to fix the problems. if all above doesn't gets work, then the problem is with ur wireless router.
Jul 21, 2010 | NetGear DG834G Router
I purchased a D Link (Model # DIR 601) along with a Retail Plus USB Adapter. My router was set up so that I could bring it home and plug it in. I was not supposed to have any issues with it. My Lap top is...
check to see if your wireless connection is on on your laptop and set to work with your router - check to see if your laptop's wireless signal is b/g/n - if it's only an "n" - and your router is a b/g - then you will need to purchase an "n" class router...
normally, routers do not "just work without issues" when you bring it home and plug it in - it should have come with a setup disk or instruction guide - have you completed the steps to connect?
Feb 17, 2010 | D-Link DGL-4500 Wireless Router
I am unable to connect to the internet using a wireless connectio
I would first try and reset the router, then run a Repair on the connection again.
If this doesn't work, try going into the Device Manager and removing the Wireless Device. Restart the computer and reinstall the Wireless Device drivers.
Jan 26, 2010 | Intel S6240 Notebook
Although cable to desktop connects to internet, my router from desktop to laptop via router won't connect.
Desk top to internet is OK.
How about Destop through Router connection to Internet OK?
Assuming you want to connect wireless from Lap top to Network, need to configure correctly for wireless in Router.
If you connect Lap top to router by wire and it didn't work that mean your router is bad.
Jul 03, 2009 | Linksys WRT160N Wireless Router
Cant connect to the internet on my lap top
first thing is to identify the wireless settings of the router,you need to identify the wireless name (SSID), channel and the encryption you are getting from the airlink router. Next is to make sure that the wireless computer has enabled wireless signal/ or the wireless is on.
after that, you may connecting wirelessly to the computer, right click wireless connection and go to view available wireless networks, try to connect -input the encryption key from you wireless router or password and hit connect.
Jun 28, 2009 | Airlink AR430W Wireless Router
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
Previously able to connect now cannot
turn the router off for two minutes then turn it on.
go to the command prompt on your computer and type in ipconfig/release, click enter. then ipconfig/renew, click enter.
Apr 09, 2009 | D-Link DI 514 Wireless Router (DI-514)
Belkin n1 router - wireless light not on - laptop has limited connectivity
If could be that you were unable to reset the router properly. You have to make sure that the router is on while pressing and holding the reset button using a paper clip. the reset button is usually found at the back of the router, then you may have to reconfigure the settings again.
you can also manually access the router page for you to change the settings.
Oct 05, 2008 | Belkin (F5D7230-4) Router (587009)
Dropping Connection
This link indicates there may be an issue with hiding the SSID in the wireless router. A security item employed by some users. IF this is the case consider broadcasting the SSID and employing WEP or WPA encryption in the wireless configuration for both the router and the adapter cards to secure the wireless connections..
see
http://arstechnica.com/guides/askars/wifi-drop.ars
Dec 11, 2007 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54GS Router (e125894) Logo
64 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
