Question about Garden
Idel problen on snow blower
I just replaced the drive belt on my snow thrower model # and now the idel goes high to low dose the idel pully need adjusted the belt was the orignal
  • 28 Answers
SOURCE: How do I adjust the belt on my Ariens 11528 snow
by the handle under the handel little ajustable rod
Posted on Feb 22, 2009
  • 715 Answers
SOURCE: !332 Snow Thrower will not Start - At full choke
change gas filter and spark plug
Posted on Oct 07, 2009
  • 3911 Answers
SOURCE: Is there a GENERIC Snow thrower for John Deere 110?
Two Stage - Snowblower - Snow thrower - Bercomac All of the Bercomac attachments are interchangeable on the same quick hitch mounting. Bolts on in minutes. What a great idea for people who have more than one tractor or buy a new one. No more having to go and buy all new attachments for the new small tractor, just buy a different model hitch kit if it doesn't use the same one. The resale value is preserved when you can sell your attachments to be used on another size or model lawn and garden tractor.
camcorder-pic.jpg Snowblower video clip
Snowblower-Snowthower Q&A's
If you are ready to buy or want more details give us a call: 1-800-618-8738 or e-mail jim@jimsrepairjimstractors.com
Posted on Oct 15, 2009
rwvanlue
  • 486 Answers
SOURCE: How to adjust the Toro 826 snow thrower
Belts will have spring tension on the idler pulleys.
Both traction and auger control cables will also have cable length adjustments to cause the travel of levers or idler pulleys to tighten belts. Adjustments are commonly located under the control panel/levers.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Dec 04, 2009
SOURCE: Just purchased a Poulan Pro Snow Thrower and on
i just purchased the poulan pro PR1030ES snow thrower, and the recoil spring is broken, anyone know of a place to buy a new one...can't even get an answer from poulan...did you ever get yours fixed
Posted on Nov 30, 2010
MTD Snow Flite model 316230500. Where can I get belts?
I have already answered you twice with this information!
They have there own forum.
http://www.snowblowerforum.com/forum/mtd-snowblowers/1397-mtd-snow-flite-snow-blower.html
You don't need the part number, you just need to measure the length, or you can phone and say;
I have a snow flite brand snow blower model.316230500. Serial no.811262, send me a belt for it.
All the belts are here
http://www.jackssmallengines.com/equipment/mtd/snow-blower/belts
and here
http://www.mtdparts.com/equipment/mtdparts/parts/machine-types/snow-throwers
Dec 24, 2015 | Garden
Briggs&stratton snow thrower model 536.881510
Sounds like a belt that is worn out or needs adjusting to tighten it up.
Feb 11, 2014 | Garden
Changing auger belt on snow blower
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
I am going to assume you have a Craftsman snow blower. If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drive the auger/blower and the belt closest to the engine drive the transmission.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Your Craftsman manual will show you step by step how to change th belt.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Craftsman 16" High Garden Tractor Snow and...
Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Want to replace auger belt & traction drive belt. need step by step help
When I put my snow thrower into 6th ,it still feels like 1st. whats up?
Dec 10, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Snow Thrower does not self-propel
Did you check under the handle area, near the blower itself for a transmission lever? This will engage & disengage the transmission.
Jan 25, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
