Question about GE DBXR463GDWW Gas Dryer
Dryer running but no heat , how do I check the pilot light. Thank you
    President:
  • 2,468 Answers
It can be various items,first check the thermal fuse located at appx 2:00 behind the drum it has 2 wires on it,somewhat tight area to access.if its good as in has continuity,then check the ignitor at the burner assy,there is no pilot light,if its good,start it and listen for 3 clicks as this is the gas valve coils opening the gas valve,if only 2 are heard the gas valve coils are open,,they are inexpensive and easily replaced,or the high limit thermostat on the heat difuser near the back inside behind the drum or the flame serser on the burner tube side is bad,these 2 are a very rare occurance though
Posted on Feb 13, 2012
Stops and all the lights come on
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Jan 15, 2013 | Kenmore Dryers
The dryer starts,heats up,gets good and hot,heat kicks off,electronic pilot kicks back on but does not light. runs cool from there on even as pilot continues to try and light.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 21, 2011 | Whirlpool Dryers
My dryer has no heat. is the pilot light out if so where would it be located?
Gas dryers have an electric igniter, no pilot light. If it runs but doesn't heat, it could be: igniter or thermal fuse
Mar 24, 2011 | Kenmore Dryers
Dryer runs fine but does not heat
Check that the pilot light is lit and flame kicks on when dryer is activated. If no flame, then check gas valve. If only pilot remains lit but does not increase when dryer is activated, then you could have a bad coupler or sensor or circuit problem which would have to be tested with a voltmeter and/or test light.
Nov 15, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
No heat coming on to dry the clothes
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 06, 2009 | Dryers
Kenmore dryer not heating
hi,
1) When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control."
2) On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown; reset or replace this. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
3) On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on.
4) Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repairperson.
On an older dryer, make sure the pilot light is burning. If it isn't, relight it. You can find directions in your owner's manual, and pilot light instructions are often mounted next to the pilot light on the burner, too.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
Hw120m washer/drier
Check if the dryer is heating, if it is not heating check the following There's no heat
Oct 16, 2008 | Hoover H130E Front Load Washer
Runs but does not heat
Try removing the jets and clean them out. the pilot may be off center and in need of calibration.
Jul 02, 2008 | Roper RGX4634KQ Gas Dryer
DRYER RUNS AND NO HEAT
Please tell me more as to what you have done to fix the problem.
Please check the following:
1. vent tube clear
2. lint trap/screen cleaned
3. thermostat control sensor operational
3. Flame overthrow sensor
Is your pilot light lit on your gas dryer? If it is, when turning on, does the burners fire up? If not, replace burner and control module.
May 19, 2008 | KitchenAid Dryers
Dryer tumbles but doesn't heat
When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control." On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown --check and replace or reset. Be aware that a dryer may have two breakers or fuses: the motor will run when one works, but the heating element requires both. On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on. On an older dryer, make sure the pilot light is burning. If it isn't, re-light it. You can find directions HERE or in your owner's manual (pilot light instructions are often mounted next to the pilot light on the burner, too). Note: Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repair person.
Jan 18, 2006 | AEG T57800 Electric Dryer
GE DBXR463GDWW Gas Dryer Logo
50 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
