How i can host my local website on world wide web through a static ip address
How i can i host my website through an static ip address
  • 565 Answers
There are a slew of free DNS services out there. Here are just a few:
http://freedns.afraid.org/
http://www.dnsdynamic.org/
They have instructions on how to use it.
Remember when using a typical United States home Internet Service Provider that your upload speeds are very slow compared to the down speed. That's why most people will just go to a Domain Name and Web Hosting company such as: http://www.namecheap.com/domains/domain-name-search.aspx
You can let them host your website for a small fee each month if your site will eventually have a lot of traffic.
Posted on Feb 13, 2012
shaky120
  • 310 Answers
SOURCE: How to set a static IP address in Windows behind a Linksys Router
Sorry mate but you have kinda lost me here, if you need a static IP address for the internet you need to contact you isp and they will provide you one, if you want to set your machine to set IP Address just go into properties for local network connection and use somthing like 192.168.1.1 255.255.255.0 and leave the dns to obtain. but you wont be able to set a internet static ip address by doing this, only way is to contact your isp.. All the best John
Posted on Mar 08, 2007
  • 556 Answers
SOURCE: I cant open an ip address for an assigned webpage.
There are several private address ranges that may be affecting the operations you are attempting to perform see table
IP Address Ranges Reserved for Private Use
Class Networks A 10.0.0.0 through 10.255.255.255 B 172.16.0.0 through 172.31.0.0 C 192.168.0.0 through 192.168.255.0
All addresses in this range in your network are only directly addressable to machines within your network at most by default. The router to your ISP and the internet as a whole maps these addresses onto the IP address assigned statically or dynamically by your ISP to the WAN side of your router using an address translation (NAT) service. So where you are attempting to connect to this device from may be significant. You may need to review your setup guide to see if it references router configuration requirements to support access to the Web_xpander port from devices not attached to your internal network. If you have multiple internal networks (address ranges and not devices) this could also be an issue.
Secondly -- does the Setup software for the device tell you the IP address assuming it is dynamically assigned. Otherwise how would you know what the address is. Static assignment could resolve that issue however you must understand your network to assign your own address. Given a theoretical network where the router gateway is 192.169.0.1 and the network mask is 255.255.255.0 the valid network addresses are 192.168.1.0 - 192.168.1.255. A router or other device supporting DHCP address assignment reserves another range such as 192.168.0.100 for 50 leases (ending at 192.168.0.149) for dynamic assignment to requesting network adapters. Ignoring the 0 and 255 address this leaves open to the network administrator (you in your home) the possibility of assigning static IP address in the ranges of say 192.168.0.2 - 192.168.0.99 and 192.168.0.150 - 192.168.0.254 or so. You as well as the DHCP server are required to assure that there are no duplicate IP addresses assigned on your network. So statically assigning 192.168.0.100 (which is DHCP assignable in our case) could and would most likely result in duplicate addressing and network problems.
Posted on Dec 08, 2007
  • 84 Answers
SOURCE: factory settings for a Linksys RV042
connect your router your computer via LAN cable
click start on windows
click run and type CMD
On the DOS command prompt type IPCONFIG/ALL
look for the gateway address, that is the IP Adress of your router
Posted on Feb 11, 2008
SOURCE: port forwading
http://portforward.com/
this site may be of some assistance
Posted on Jun 19, 2008
  • 96 Answers
SOURCE: Change the local IP address of Billion 400G
You need to login to the router page with the IP 10.0.0.2 and the on that and you can change the IP from that page
On login it will ask for username and password it is admin and password is "password" by default if you have any issue in getting user name and password you can reset the router as below
To restore the factory default configuration settings without knowing the administration password or IP address, you must use the Default Reset button on the rear panel of the router. 1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot.
it will come back to factory settings of 192.168.1.1 and then you need to configure the router as per your internet service provider
you can check the manual at the below link
http://kbserver.netgear.com/pdf/dg834g_dg834gb_ref_manual_03Jun05.pdf
Posted on Nov 27, 2009
Windows 8.1 Store Error 0x80072ee7 Fix?
The 0x80072EE7 error code may occur if the client computer cannot find the correct IP address when it tries to resolve a URL for the Windows Update Web site or for the Microsoft Update Web site. This error may occur if the Hosts file contains a static IP address.
To resolve this error, examine the Hosts file. (This file may also be named Hosts.sam.) Make sure that the file does not list any static IP entries for the Windows Update Web site or for the Microsoft Update Web site.
The Hosts file is located in the C:\Windows\system32\drivers\etc folder. To view the Hosts file, you may have to associate the file with Notepad. To do this, follow these steps:
  1. Right-click the Hosts file.
  2. Click Open With, and then select Notepad from the list of programs.
If the Hosts file contains a static IP address that is associated with Windows Update or with Microsoft Update, comment the entry by adding the # sign at the beginning of the entry. You can also delete the whole line and save changes to the Hosts file.
Note Programs, such as Web accelerators, DNS accelerators, DNS caching utilities, and Spyblockers, can add static IP entries for the Windows Update Web site or for the Microsoft Update Web site to your Hosts file. This scenario can cause Windows Update or Microsoft Update to fail.
Aug 15, 2014 | Lenovo IdeaPad Y510 Notebook
What is the meaning of IP
IP Address stands for internet protocol...its a kind of internet communication protocol.....
The Internet Protocol is responsible for addressing hosts and routing datagrams from a source host to the destination host across one or more IP networks.
it having two types
1>static ip address(which is used by any hosting company)
2>dynamic ip address(which we genrally uses)
and it having two version
1.IP V4
2.IP V6.
i think its enough if you want to know more about it then feel free to contact........thnks blacktulips
Aug 11, 2011 | Computers & Internet
Diffrent between Dynamic&static ip address
Static IP address is usually a single IP address provided by the ISP to you, which can be configured so that you can run a web server (host web sites etc), or access your home computer from any where in the world ( your computer and internet should be on ).
Dynamic IP address is usually IP address provided by the ISP to your DSL modem / computer (for dialup modems) for that internet session, next day or next time you connect the IP address will be a different one. (usually home internet connections are Dynamic IP based.
In a typical home environment if you have one wireless adaptor and planning for a wireless repeater its better to configure dynamic IP address in the repeater (so that you repeater will acquire IP address from the wireless adaptor)
Dec 09, 2010 | Computers & Internet
I have a message that say Ip address conflict, what can I do
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
Nov 24, 2010 | Computers & Internet
I want to set up an internet file server how and what software is best
creating web space (internet file server) to store data over the internet or retrieve it from that PC to any other PC in the world follows the same lines as creating a self hosted website, although you arent creating a website, the principal is muc hthe same, i do it myself (but with a website as well) using a miple desktop computer at home..
first things you are going to need to do are:
1. contact your ISP and arrange for a static IP to assigned to your internet connection (if you dont have one already) anbd sometimes you have to pay for it, this gives your file server a SET WAN IP address and means you can access it via IP rather than using a domain.
2. obviously have the file server, and you will need to give it a static IP on the local network, as your ISP gave you one for the external WAN, and then you will also have to setup port forwarding so that any FTP ot specifit HTTP traffic points to the server and is forwarded and retrieved from there, but you will need software to do it, i use a neat little peice of software called WampServer (obtainable here: http://www.wampserver.com/en/download.php)
this should enable you to configure as you please, download/upload/FTP setting to set up a web based storage option, and i must say it is very handy for a travelling tech like myself..
when it is eventually setup, you will use your static IP assigned to you by your ISP as a web address (eg. instead of www.mywebsite.com you will use http:\\152.133.133.133 - this means you do not have to pay for a domain.. awesome!) this is a fairly involved process and if you dont know alot about it already.. i know you will by the time your done! once you have those 3 main things setup;
-static IP from ISP
-Wampserver installed
-file server on network
i can help you out further with more specific instrctions and details if you like.. good luck!
Sep 03, 2010 | Computers & Internet
How to forward website to belkin n1 vision router
You would have to log into the router to configure port forwarding on port 80. You would have to know the IP address of the computer hosting the website and put that in the routers config under port forwarding.
Oct 27, 2009 | Belkin N1 Vision Router
Pix 515 E allow few websites only.
Do the nslookup for the three websites and write an access list to permit the traffic only to the said website ip addresses
Eg.
1. go to dos prompt
2. type "nslookup"
3. type "www.rediff.com
Note : You will get the ip address of the websites
4. Create an object group for these websites
5. Add ip addresses of the websites
6. create an access-control list element to permit the traffic from your circle office to this object group for port tcp 80 and 443
You are done
Mar 09, 2009 | Cisco PIX 515E Firewall
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: 192.168.1.100 ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
WINS:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Feb 23, 2008 | Dell Inspiron 1200 Notebook
Computers & Internet Logo
251 people viewed this question
David Payne
David Payne
