Question about Dryers
Vortalex wiring diagram
Ge 3 speed 4 blade 12" pedestal fan 1949 blue gray in color with red badging. I need to find wiring diagrams
SOURCE: WIRING OF 3-WAY SPEED SWITCH FOR HAMPTON FAN
1 - Red/Pink
2 - Purple
3 - Yellow
L - Black
Posted on Jun 20, 2009
SOURCE: need wiring diagram for 4 wire switch
I have similar problem, although I have 1 high speed and 2 lows, no medium. before I replaced the switch (which was no help) I marked the wires.
L= Black
1= Grey
2- Brown
3= Green
Posted on Jul 05, 2009
  • 2976 Answers
SOURCE: have a lakewood shop fan pedestal type with 3
The switch has numbers on it. Mark the wires. Just connect the new switch the same way.
Posted on Jul 26, 2009
SOURCE: How to clean and oil GE Vortalex 4 blade fan
Use nondetergent oil in a very lightweight viscosity. Zoom Spout Sewing Machine Oil is excellent. This oil is used in the front oil cup after the old congealed oil is cleaned out of the cup and the oil wool wicking. The wool wicking can be hard as a rock and requires replacement sometimes. Duo-Felt Products is a great source for new wool wicking. 3/16" for a GE Vortalex fan.
The rear oscillator gear box uses wheel bearing grease commonly available at automotive stores, Walmart, etc. Clean out all the old grease with mineral spirits. Use any small nylon brush and cotton tipped swabs. You do not have to pack in as much as you think. Mainly coat the gears
Posted on Feb 20, 2010
SOURCE: Ceiling fan capacitor hook up problem. I have a 3
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
Posted on Jun 11, 2010
I have a 3 speed fan with a red, blue, black an white wires, how are the supposed to be wired with power. the wires go to a little black box that appears to just be wires with no circuit board
The BOX is a GE splicer - with 6 wires - 2 grey power wires, then the red, blue, black, and white from the fan motor. I have the same problem and cannot find another GE SPLICER 3 SPEED SWITCH for the fan. All switches that I have tried have 4 connections.........so a WIRING DIAGRAM would be GREAT!
Can anyone offer any help? I have tried every electrical store in the area!
Thanks
May 29, 2011 | Patton U2-1887HO Floor / Box Fan
Wiring diagram, sony cdx 3100 car cd player
Pin Number Wire Color Description
1 White Left front +
2 Green Left rear +
3 Purple Right rear +
4 Gray Right front +
5 Blue/white AMP Remote
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
9 White/black Left front -
10 Green/black Left rear -
11 Purple/black Right rear -
12 Bray/black Right front -
13 Sky blue ATT
14
15 Orange/white Illumination
Feb 24, 2010 | Car Audio & Video
Sony cd player, CDX-3100 wiring diagram
This is the pinout shown on the Sony website for the CDX series players. Pin numbering is as follows:
1 2 3 4 5 6 7 8
9 10 11 12 13 14 15 16
This is looking at the connector with the wires towards you.
2 Green Left rear +
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
13 Sky blue ATT
14
16 Yellow Battery
Feb 24, 2010 | Sony Car Audio & Video
Just need a pic to see what color wire goes to each of the 20 pins on the back of the deck
Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
Jan 13, 2010 | Jensen CD4610 CD Player
I need to know where the wires comming out of the plug go to?? wiring diagram. thank you sony cdx-3100
1 2 3 4 5 6 7 8
2 Green Left rear +
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
13 Sky blue ATT
14
16 Yellow Battery
Jan 05, 2010 | Sony CDX-3100 CD Changer
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
Need wiring diagram for harness
1) Black Ground
2) Red 12V Ignition
3) Yellow 12V Constant
4) Orange Illumination
(Sometimes there's an extra orange for cell phone mute)
5) Blue Remote
6) Blue/White Power Antenna
7) White Front Left
8) White/Blk Front Left
9) Gray Rear Left
10) Gray/Blk Rear Left
11) Green Front Right
12) Green/Blk Front Right
13) Purple Rear Right
13) Purple/Blk Rear Right
May 04, 2009 | Car Audio & Video
Still seeking db15 pin-outs for a samsung AQ17LS7LK
Here is the wiring colors for the VGA cable:
1- Red
2- Green
3- Blue
4- NC
5- Gray Shield
6- Red Shield
7- Green Shield
8- Blue Shield
9- NC
10- Violet
11- NC
12- Orange
13- Gray
14- Yellow
15- White
Apr 14, 2008 | Samsung SyncMaster 750S Monitor
Dryers Logo
113 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
