Question about Sylvania SMPK8858 MP3 Player
Speakers don't work
Replace the speakers
Posted on Feb 14, 2012
No factory speakers working
You don't mention the year/make/model of the vehicle so, my response will be as vague as your problem/question. Either the speakers are not connected properly, defective or, your factory amp ( no way of knowing because you don't mention the vehicle) is not powered up or not working.
Oct 15, 2012 | Pioneer Car Audio & Video
Peavey decade manual
Recommend an Ashdown or Fender with a 15" speaker, they will give a good sound, are gig-worthy, and will last. I use a Behringher 120W for rehearsal work, it only has a 12" speaker and thus cannot give a good 'presence', also I have been reliably informed, a lot of custom chips are used in thier amps.
Don't forget, a bass 'E' goes down to something like 60Hz, and a good speaker and amp are a must for bass work
Feb 12, 2012 | Peavey Music
Hooked up a cd player to my 2005moms grand am but volume don't work? Why?
Check to make sure it is not manually muted, if that doesn't work make sure your speaker wires are connected properly in the back of the radio and speakers work also. If it is run through an amplifier, make sure the amp works and the speaker wires are connected properly too! Don't forget to check gain on the amp too!
Jan 16, 2012 | JVC Car Audio & Video
I have just bought an Behringer EP4000 amp. How do I connect 2 x B1520 and 1 x B1800X speakers to this amp? Thanks!
You don't (unless you want two B1520's on one channel and the sub on another). Reading the manuals would help.
The EP4000 amp drives only two channels. It CAN be bridged for one speaker but it won't support two channel and bridged mode simultaneously.
http://www.retrevo.com/support/Behringer-EP4000-Amps-manual/id/23591dj795/t/2/
The B1520 subwoofeer is PASSIVE so it will need a dedicated amplifier to power it and control its volume independently of other speaker channels.
http://www.behringer.com/EN/Products/B1800X.aspx
Aug 31, 2011 | Behringer Eurolive B212A Speaker
I replaced the 2 ohm 6x9's in my buick with the monsoon amp, with 4 ohm 6x9's. After i put the speakers in, almost no sound came out. I've read that you can wire them in parallel from one...
If you did wire these in parallel to get the 2 ohm load, you will loose your balance. Also, you may have to bridge your amp.
To do this, go from the positive of the amp to both positives of both speakers. Then from the negative of the amp to both negatives of both speakers. If you have a 2 channel amp, you will have to bridge it. Note, make sure your amp is 2 ohm stable.
hope this helps
Aug 27, 2011 | Car Audio & Video
I have bose 401 speakers and need them to work with a stero that puts out 8ohms can you help?
Amps don't 'put out' 8-ohms; they're spec'd to drive a nominal load, usually 8-ohms, and always have some leeway as speakers are reactive loads that will vary with frequency.
You need to evaluate what your amp can do with a nominal 4-ohm load. The manual says they will work with amps rated for 4-8 ohm loads. Plug them in and keep an eye (and ear) out for any sign of stress (heat, distortion, smoke) when driving them hard.
Jul 16, 2011 | Hitachi Electronics - Others
My Mirage S10 subwoofer light comes on showing the subwoofer is on but I cannot get any bass sound to come on. How can this be resolved?
More diagnosis first. We can't assume the source is squawking bass to this thing and you don't mention that you know that to be the case. IS it? The problem could be up the food chain.
We also don't know if you're feeding it Speaker Level or Line Level.
Prove the subwoofer amp is dead or alive by jacking in any source you have that has an RCA output (Tape Out on your unnamed source, CD, TV, etc). Turn the sub volume down to minimum to start as most RCA outputs are at maximum volume. Try that to assess the amp's health. Still dead? Get it worked on.
Jul 07, 2011 | Mirage Prestige S10 Subwoofer Speaker
How do u make Channels A&B work at the same time as one anouther.insted off just channalA or B
No model specified, but if they don't allow activation of two pairs of speakers at the same time it is probably to prevent the impedance presented to the amp from being too low.
If you REALLY want to do it just wire two pairs to the same speaker outputs and risk damaging the amp. Or wire the speakers in series and you'll be safe. Amp + to speaker A +; Speaker A - to Speaker B +; Speaker B - to Amp -.
May 11, 2011 | Technics Audio Players & Recorders
Where can I download a driver for Altec Lansing ADA745 speakers?
HI, maybe theres been a bit of confusion but your Altec Lansing ADA745 speakers shouldn't need any drivers.
Its kind of similar to you plugging in a pair of headphones into your cumputer, they should work just fine.
Are you not getting any sound? Post the details of your PC (is it a dell?)
model number etc... and describe your problem
You probably need audio drivers for your audio device(inside your pc on your motherboard),
Aug 04, 2009 | Dell Audio Players & Recorders
Sylvania SMPK8858 MP3 Player Logo
55 people viewed this question
Top Sylvania Audio Players & Recorders Experts
David Payne
David Payne
Tre Elkins
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
