Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool Cabrio WTW6600SW1 ul code - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 39 Answers
SOURCE: Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Posted on Jun 23, 2009
57 varieties
  • 1653 Answers
SOURCE: washer whirlpool cabrio message code f50,washer
F50 - This is a motor stalled failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Posted on Oct 02, 2009
  • 410 Answers
SOURCE: i have a ul error code on my washing machine it is
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. The ul error code means unbalanced load. I can suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on washing machines and other appliances. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 26, 2009
  • 572 Answers
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Posted on Feb 06, 2010
blueextc3221
  • 15935 Answers
SOURCE: i have a cabrio wtw6600sw1
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&$%@#
Posted on Sep 21, 2010
Whirlpool Cabrio spins off center and stop with ul code
Ul-Unbalanced Load
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute
the load.
May 28, 2012 | Whirlpool Washing Machines
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washer will not stay balanced and show on UL code.
the repair man says i need to replace the inner tub for 299 dollars with a total price of 424 and its only 4 years old
Jan 19, 2010 | Whirlpool WTW6400SW Cabrio Washer
I have a Whirlpool Cabrio he wtw6600SW1. Its
That sounds like the gearbox has gone bad, I've replaced several that were doing the same thing and were still under warranty
Sep 23, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
The time display section indicated a code UL instead of the time left on the washing cycle. What does this code mean
keep getting a ul code and machine barrel knocks back and forth in the washer on spin cycle until the ul comes up. Cannot get it to quit. What is the problem?
Thanks
Aug 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio (WTW6600SW1) drains completely then Ld error!
I have a call with the same problem. Pumps all the water out but still flashes LD. Should be the board, The electronic pressure switch is built in to the board. Make sure the pressure chamber on the back right side is not cloged
Aug 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio won't balance even empty
Check the four suspension rods on the outer tub to make sure they are not broken and/or out of placement.
Jun 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
91 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
