Question about Kenmore Refrigerators
Kenmore Refrigerator Model Number 596.75932401 not working
Our refrigerator is suddenly stopped working. We bought this refrigerator 3 years ago. It makes some sound and pushing air instead of cold. It was a lot of dust under refrigerator. We cleaned it.
Please let us know what should we check and where the part that needs to be checked is located.
You can e-mail me at avalon_a2003@yahoo.com or call 612-245-2395.
Any help will be greatly appreciated,
Anthony
5 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: freezer works fine but no cold air in refrigerator...
Check make sure evapurator fan is blowing and nothing blocking any return vents in refrigeratro side prevent air from recirclating
Posted on Dec 01, 2007
aborcass
  • 2651 Answers
SOURCE: Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
its what we in the business call "refrigerator cancer" they are rusting form the inside out. there is not repairing them and not worth the cost of replacing, you can take them off and spray them you might get a little time outta them. reason it happens is the insulation used years ago was fiberglass and would trap moisture between door and liner, eventually rusting through.. new refrigs are insulated with blown in poly-styrene. they don't hold moisture.
Posted on Mar 11, 2008
SOURCE: have an amana refrigerator model BC121VW bottem freezer
In the back of the refrigerator, there should be a vent. Put your hand over it and see if air is coming out. This will tell you if the fan the other poster mentioned is working. If no air is moving then either the fan is bad or the channel is plugged. If only a small amount of air is moving through, open the freezer door and check the air flow again. If the flow got much better, then the return channel is plugged. Try these steps, and if they help post back and I will tell you what to do next.
Posted on Aug 11, 2009
  • 20 Answers
SOURCE: Refrigerator Model 596-65232403 2 Yrs old
Ed, check your freezer gasket..it may be partially frozen or torn..RDS
Posted on Apr 23, 2010
What is the lifespan of a Kenmore Elite Model 795?
Free Kenmore Refrigerator User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Kenmore > Kitchen Appliance Kenmore Products 1 - 50 of 357 - Kenmore Refrigerator User Manual.
Jul 19, 2015 | Kenmore Refrigerators
What was production year of Kenmore Refrigerator series 60821, Model 106-8608260?
Hello Nancy;
My name is Peter. I am a retired field service refrigeration technician.
The production year is based on your unit serial number. Both the serial number and month and year of manufacture is on a label in your fresh food section, on the side wall near the top.
Jan 01, 2015 | Kenmore Refrigerators
Where do I find a manual for the kenmore coldspot # 59099990 refridgerator
Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
May 10, 2014 | Kenmore Side by Side Refrigerator
I have one and half year old Kenmore refrigerator. Model 106.58902802. Now suddenly refrigerator portion of it stopped working. All the ice cubes melted. Can you suggest what could be wrong?
Check compressor working. If yes,keep your arm on discharge side. It's warm and whistling sound (nicely) inside the freezer means it's working well.If no warm in discharge side, gas leak or chocked. Remove all gas, leak test and flush out the system. Then do gas charging.
Jan 24, 2011 | Kenmore Side by Side Refrigerator
I have a kenmore modle 52559100
I am working through Sears Commercial Parts Direct and I cannot find that correct model number. Double check. Filters do not suddenly stop flow. Water control valves yes and when you have an ice maker the water valve has two sides. Water control valves are located most times on rear of refrigerator and near floor where the house hold water enters the refrigerator. Sometimes hiding behind a paper cover. Your number really looks good to me and I was surprised that it will not work. Double check and correct that number and I will be able to assist you better. In a way I wish Sears would not change the numbers. The 525 in the number is who made your model and 525 does not come up. Sea Breeze
Mar 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator was making a 'Thump'' noise every so often and just stopped working. Freezer is still working It's a kenmore elite 3 door bottom freezer refrigerator model number 76539
Unplugging for an hour won't allow it to defrost if that is what the problem is.
Look inside the freezer at the back wall. Look for heavy accumulations of ice building on the cooling coil, which is behind the back wall panel. You may have to look in the louvers or past where the evap fan is located.
Once we know if there is heavy frost or ice there, we'll have a better idea how to resolve. Is there any warranty on this refrigerator that you know of, besides the 5 year compressor warranty?
Dec 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working
the water valve soleniod on the lower back of frig. is bad,get the model number out of the frig. top right and replace,let me know-mike
Sep 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Temperature Displays Flash
just stop getting cold, both sides no ice, everything runs, bought new, sat in storage 3 years, been running 2 years
May 15, 2008 | Kenmore 44353
Refrigerators Logo
80 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
