Question about Motorola Mobility V551
Display does not appear when the phone is opened
When I open the flip phone, the display does not come on reliably. The button that controls whether the display appears on the internal or external display seems to get "stuck." Pressing the button with a pen, slightly hitting the phone, or sometimes just waiting several seconds will eventually cause the display to appear. The problem mainly lies in the fact that I can't reliably answer calls. I have just changed the setting so that it's not set to answer when opened. It works better, but any additional suggestions to correct the problem would be corrected. Thanks!
    New Friend:
  • 163 Answers
This model have many problems with the display, but yours is new at least for me, if you got a stuck button, could be the problem, but is not a big problem, get the celu to the celu store they will fix it for cheap...good luck
Posted on Aug 11, 2006
How to unlocking kyocera wx04k
Leyne: According to, "1. Remove the battery cover on the back of the Kyocera cell phone.
2. Open the flip once the back of the phone has been exposed.
3. Press the "Reset" button with the phone's stylus or a small pointed object.
4. Press the "Backlight" button located on top of the phone while continuing to hold the "Reset" button.
5. Release the "Reset" button after approximately 3 seconds.
6. Release the "Backlight" button when the display screen on your phone appears.
7. Select the "Yes" option by pressing the "Up" button when the "Erase all data?" message appears. You must select the "Yes" option to complete the hard reset."
May 12, 2015 | Kyocera Cell Phones
Flip the screen
Flipping the screen is part of the Display in the Control Panel. You have to go to the Settings tab then click Advanced and look for Rotation.
Click Start/Control Panel or Start/Settings/Control Panel then look for Display or Appearance and Personalization. Open the Display then click Settings/Advanced/Rotation.
Jun 08, 2012 | Computers & Internet
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    How do you change language from Spanish to English on this phone? I put it on spanish somehow and i cant get it back to english.
    Using Settings
    Settings contains many submenus that let you customize your phone.
    Display/Info Features The Display/Info menu controls how the keypad and display appear: - changes the wallpaper that • Wallpaper appears on the idle screen. - sets the size of text on the display. • Text Size - changes the look of the display. • Theme - controls whether main menu • Home Icons icons appear on the idle screen. - controls backlight illumination. • Backlight133 Customizing Your Phone - controls whether the time and date • Clock appear on the idle screen; sets time and date format; sets year. - controls whether the items on • Menu View your main menu and Java applications menu appear as large icons or a list. - sets large digits to appear on • Large Dialing the idle screen when you enter a number. - sets the language that your phone • Language displays.
    for more information Get the manual from here
    Hope this helps if so do rate the solution
    Jan 05, 2011 | Motorola Mobility i850 Cellular Phone
    How to print a usage page for HP color laserjet CP2025n
    You can print usage page as follows via front control panel on the printer itself.
    1. Control-panel display: The display provides information about the product. Use the menus on the display to establish product settings.
    2. Back arrow ( ) button: Use this button for the following actions:
      • Exit the control-panel menus.
      • Scroll back to a previous menu in a submenu list.
      • Scroll back to a previous menu item in a submenu list (without saving changes to the menu item).
    3. Left arrow ( ) button: Use this button to navigate through the menus or to decrease a value that appears on the display.
    4. OK button: Press the OK button for the following actions:
      • Open the control-panel menus.
      • Open a submenu displayed on the control-panel display.
      • Select a menu item.
      • Clear some errors.
      • Begin a print job in response to a control-panel prompt (for example, when the message [OK] to print appears on the control-panel display).
    5. Right arrow ( ) button: Use this button to navigate through the menus or to increase a value that appears on the display.
    6. Cancel Job (X) button: Press this button to cancel a print job whenever the attention light is blinking or to exit the controlpanel
    Now follow these points to print th required page:
    1. Press OK to open the menus.
    2. Press the Left arrow ( ) or Right arrow ( ) button to navigate to Reports, and then press OK.
    3. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the reports, and then press
    4. OK to print a report.
    5. Press X to exit the menus.
    The following information pages are available:
    • Demo page
    • Menu structure
    • Configuration page
    • Supplies status page
    • Network configuration page
    • Usage report
    • PCL font list
    • PS font list
    • PCL6 font list
    • Color usage report
    • Service report
    • Diagnostics report
    Oct 25, 2010 | Computers & Internet
    Display faulty
    hi :) motorola K1 is a flip phone,when open flip no display,that mean phone ribbon was spoil.pls send for mobile technician to change a new ribbon. pro will solve.
    Jul 06, 2010 | T-Mobile Motorola Razor V3 Custom Cell...
    Water damage from my skin
    You need to open the phone housing and try to dry up or clean the board for any wet situation or moisture and check for any bad connection specially the connector from LCD display into the main circuit board. This connection is frequently loose in Motorola phone due to the flipping function is not reliable. I am surprise that since a flip phone which is mean it will open and close almost every minute for million time per month or year htne how come they made the connection so loudsy. I have fixed these problems for my relatives and friends and always see this common failure in Motorola Flip phone. Everytime you are no longer see the display but still heard sound and ring which is mean that either your cable is loosen or bad then you have to replace it. Please see below link for hoe to replace the LCD: I have an instruction of how to fix a water damaged phone but I have not been tried it before so you must read the instruction of water damaged guide carefully and make decision whether you want to do it. Please email me at so I can email you the link. I am at work so I cannot reach to my laptop hard drive to get the info. Try the link above to see how ot open the phone housing first then will try others later. Good Luck
    Apr 06, 2007 | Motorola Mobility RAZR V3
    Motorola Mobility V551 Logo
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
