Question about Microsoft Xbox 360 Console
3 flashing red lights
How do I fix this?
  • 34 Answers
This is called the 3 rings of death and is well known amongst xbox users. including me... Ive had 1 xbox replaced because of it. Try the following to diagnose the issue. All four lights illuminate = 0
One Light = 1
Two Lights = 2
Three Lights = 3
Example:
Turn on your "dead" xbox. Wait for the 3 red lights. Once you get them hold the "Synch" (for the wireless remote) button and the eject button down simultaniously. All four lights flash. (0) Press the eject button again and only one light (1) press again and all four light up (0) press again and two lights (2). Error code is 0102. compare this code to the table below to find out what is wrong with your X360. Is it overheating? Power Cord? Hardware? what ever the code is refer to this list for the reason it is flashing...
The Code he got was 0102 which means the computer does not know the problem as it is not hardware or heating or anything like that. Could be dust, loose solder or static! He used a can of compressed air and his X360 IS BACK!!!!!! He did not know for how long but he played several hours after and had not one Hiccup. This after a whole week of the dreaded RINGS OF DEATH!!
after you diagnoe the code get back to me and ill tell you the problem and how to fix it.
Posted on Oct 24, 2008
Flashing red light..playstation will not turn on
There is a blog post that related to your case. Flashing red light and won't turn on seems can be fixed by yourself.
Please read : PS3 Red Light Blinking Fix
Feb 13, 2011 | Sony Playstation 3 (PS3) Console
Red light flashing
Red light flashing can be fixed now!
Feb 05, 2011 | Sony Playstation 3 (PS3) Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
System comes on and immediately red light flashes
PS3 flashing is not hard to fix. Do you want to fix it by yourself instead of pay $150 checking to Sony? Here's the solution :
PS3 Red Light Fixing Guide
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
Red ring flashing
Red lights is normally the red light of doom, you will need to send it in to get it fixed or you can fix it yourself using a good guide to fix it and stop the heat build up.
Dec 26, 2009 | Microsoft Xbox 360 Console
Three flashing red lights
If you have the 3 red lights this is because the GPU and the CPU have heat up you need to stop the heat, you can send it in to do this or you can fix it with a good repair guide
Dec 24, 2009 | Microsoft Xbox 360 Console
Plays games then stops when red lights start flashing
How may red lights are flashing?
1 red light normally E74 error message on screen
2 red lights overheating
3 red lights the GPU and the CPU have overheated.
4 red lights is the AV cable not plugged in properly.
You can fix the 1, 2, 3, red lights yourself or send it in for a fix
Oct 25, 2009 | Microsoft Xbox 360 Console
Replaced the bulb, now the tv will turn off and flash red light
3 times red light flash shows that lamp cover is not seated / fixed properly.
Please check lamp cover and fix it securely.
Dec 11, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Microsoft Xbox 360 Console Logo
76 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
