Question about Schwinn Exercise & Fitness
Squeek in motor of 6110p treadmill
Treadmill had been standing unused in a basement for 3 years. Oiled belt and started treadmill. Appears to be stuck at a high elevation but the panel says 0 elevation. The big problem is a squeak in the electric motor that speeds up when the motor speeds up. Can this motor be oiled? Do you think it is the motor at all?
    Top Expert:
  • Schwinn Master
  • 12,223 Answers
Dear Sir:
The motor you can be oiled . But see the next instruction.
RUN THE SOFTWARE CALIBRATION FOR Easy diagnose and troubleshooting , see the instruction under the Hood of Motor, and follow the step or user manuals. Inspect the 1) Potentiometer + gear of the same Pot ( lubricate very slight).
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 16, 2012
Testimonial: "thanks for the help!"
4 Suggested Answers
  • 218 Answers
SOURCE: When my treadmill is on a slight inclient, level 2
loose pivot joint
Posted on Aug 12, 2010
  • 33 Answers
SOURCE: my sole f63 treadmill shows an elevation error and
pls do re-calibration
Posted on Dec 11, 2010
2manyhobbies
  • 129 Answers
SOURCE: Our Proform Sport 1000 treadmill
The incline operation and the walking belt operation are independent of each other. The walking belt should run regardless of the incline operation.
Although I have never had a problem with the gears in the incline motor being defective, you may need the motor replaced.. Try an incline calibration.
With the safety key in place, press start to start the machine. Press incline up. While the numbers are changing, remove the safety key. Release the incline up button. Reinstall the key, the machine should calibrate . After calibration, retry the operation normally.
Because the circumstances here are unusual, I would next disassemble the right upright and inspect the wiring harness for damage. During assembly, it is easy to pinch the harness (usually at the bottom of the upright), damaging the wiring to the console. The console may work, the the information may not get to the motor control PCB. The machine may have worked for a period of time before the damage became apparent, the flexing and movement of the frame eventually will eat through the wiring causing a number of unusual symptoms.
Posted on Dec 18, 2010
Schwinn 6110P Treadmill won't elevate
https://www.treadmilldoctor.com/incline-motor-problems
Sep 03, 2015 | Schwinn Exercise & Fitness
How do you get the track to stop squeeking?
when was the last time you lube the walking belt
Jan 28, 2015 | Proform Walking Belt For The 520x...
Reebok RBTL18911 squeeks when walking or running. Left side is more than the right side.
I would check manual, it may need to be oiled or cleaned. You can always call tech support for help
Apr 16, 2014 | Horizon Exercise & Fitness
Image 935 treadmill wont turn on
see the video and proceed for fix it. God bless you
Nov 25, 2012 | Exercise & Fitness
My treadmill starts up and run but when i stand on it the belt stop rolling but the motor is still going
check tension on w/belt and motor belt signs of worn out belt. black dust cracking treads or flaking.
Mar 13, 2011 | Proform 530 Treadmill Walking Belt
The belt is dragging and sticking...
hi if the belt is dragging and slipping when your standing on top that means you need a new belt, not the one you are standing on. the belt that is attached to the motor. if you start the treadmill and dont step on it i bet the belt runs smoothly. not that expensive to repalce under £20.00. hope i have helped
Nov 11, 2010 | Proform XP 542S TREADMILL Drive Motor
Reebok 8050es treadmill walking belt has started slipping/skipping. It has been oiled and it is 2 years old.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
May 05, 2010 | Reebok 8050 ES Treadmill
I started up my treadmill after a year sabbatical :) to find that it stops abruptly when I increase the speed above 4 and then when I restarted it as soon as I stood on the belt the motor lagged & then...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift the edges of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Apr 28, 2010 | HEALTHRIDER S600 Treadmill Motor Control...
I have a proform j8li treadmill, all 4 led lights work properly. Console lights all seem to work. Incline works fine but no belt motor function
I have the exact same problem with the very same treadmill that i bouth 10 years ago and it has been sitting for 5 years unused. The last time it was turned on it worked but now that I plug it in and try to start it, everything works but the belt drive motor. Any ideas?
Jan 26, 2010 | Exercise & Fitness
Exercise & Fitness Logo
268 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
