Question about Acer Aspire 3680 Laptop
NO LCD MY SON PUT A MAGNET UP TO THE SCREEN AND THEN WENT BLANK
    Genius:
  • Acer Master
  • 1,250 Answers
You have to degauss the screen for this its better consult some technician
Posted on Oct 27, 2008
My son put a magnet on the screen of his InnoTab2. Now it has a blank spot on the screen where the magnet was. Is there any way to repair this?
LCD displays are not affected by magnetic fields like CRT displays are. It sounds like the display might have been damaged by hitting it with the magnet and if this is the case the display will need to be replaced.
Dec 31, 2014 | Televison & Video
Sidekick lx screen went blank isnt working..
You can try to reseat the lcd cable and make sure it is tight. It that fails then you will need to replace the LCD screen
Here are instructions for replacing the Sidekick LX screen: How to replace the Sidekick LX LCD Screen
and here is a link to the LCD screen son ebay.
Sidekick LX LCD Screens
Oct 05, 2009 | T-Mobile Sidekick® 3 Cellular Phone
My Motorola Razr v3 cell phone's lcd is blank
unscrew it and change the flex to enable it view programms
Jul 17, 2009 | Motorola Mobility RAZR V3
Laptop screen is totally blank as a duster with magnet was used to wipe the screen by erros
It is highly unlikely that using the magnetic duster could damage a LCD screen except putting scratches on the surface of the screen. There is nothing in a LCD screen that can be affected by a magnet. A magnet will affect a CRT monitor because a magnetic field will affect/deflect the electronic beams that hit the color phoaphorus dots on the screen.
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 05, 2009 | Computers & Internet
My screen went blank and i can't see anything
It sounds like the LCD backlight went bad. If you are still under warranty, get it replaced.
If not, you can buy a replacement 5310 LCD and replace it yourself.
A new 5310 display costs about 20 dollars from ebay.
I wrote a detailed guide to help you put in the new Nokia 5310 LCD screen.
Check it out at the following link for the guide and links to buy the LCD
Nokia 5310 Screen Replacement
Hope that helps
Apr 11, 2009 | Nokia 5310 Cellular Phone
Screen not working
Lisa-
I am sorry to hear that the new sidekick 3 is not working for your son.
Is the screen white, blank, or just hard to see?
If white, then the flex cable needs to be reseated.
How to fix a blank white Screen on a Sidekick
If dark blank, then reseat the lcd assy itself and see if it works
Reseat the Sidekick 3 LCD Screen
If hard to see the screen, then the backlight is dead. A new screen is needed for that.
Replace the Sidekick 3 LCD Screen
I hope that helps
Feel free to contact me if you have questions
Dec 15, 2008 | T-Mobile Sidekick II
Poloroid PDM 8551
The Poloroid PDM 8551 is notoriously prone to failure.
the current top of the heap of portable DVD players is a company called Venturer
The Venturer Portable HD home theater complete with wireless headphones sells for around 100$
The solution here is clear , ditch that ****** and hunt down new one.
Shalom :-)
Apr 16, 2008 | Polaroid PDM-0723 Portable DVD Player
RAZR V3M thinks it's always open - Screen will not turn off
in the top right corner you are suppose to have a little circular magnet that changes the screen when the phone is open or closed. I just changed my housing yesterday and took the magnet out and put it in my new housing but for some reason i have the same problem as you. so maybe you lost the magnet when you replaced the lcd and if that is the case then you are screwed. try have Motorola fix it, don't tell them you replaced the lcd
Dec 04, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Key icon on polariod television
When your son stepped on the remote apparently the set was put into a lock out mode.Probably several (at least 2) buttons were pushed at the same time. If you still have your owner's manual you might find the answer as to how to unlock you set. If not then you need to call tech support and ask how to unlock it. Stargazer
Jan 27, 2007 | Polaroid TDM-1421C TV
Acer Aspire 3680 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
