Question about Telemania 027367 Spiderman Animated Phone
Multiple Telephone System Compatibility Issues
I have three separate telephone systems operating off the same line in my home. There are two separate Panasonic telephones: an old 2.4 Ghz DSS (Model KX-TG2564CS), a new Digital 5.8 Ghz (Model Kx-TG5438C) and a Uniden 2.4 Ghz possibly analog??? (Model EX13246). I can hear conversations on the 5.8 Ghz from the 2.4 Ghz systems but I cannot be heard by those using the 5.8 Ghz. Only the 5.8 GHz rings. I can determine ring count for the 5.8 ghz (default is 4) but not the 2.4 Ghz systems. Perhaps the ring count for the 2.4 Ghz systems is greater. As well, there does not seem to be any way to alter the ring count on the 2.4 Ghz systems. Whether rationalizing the ring count would solve the ring problem is another question. An added complexity is that the 5.8 Ghz has its own built in answering system while the 2.4 Ghz systems access the existing Bell Canada voice mail service. Sometimes voice mail is trapped by one but not the others. There does not appear to be a pattern. Does anyone have any suggestions?
    New Friend:
  • 163 Answers
Ring count, timing, and speed, are direrent in all model, and thats the problem, even if you use two phones of the same model can experiment the same problem with the aswering sistem, the other problem is the phone not the line check for mute button...good luck
Posted on Aug 11, 2006
    Problem Solver:
  • 14 Answers
I most cases it should not matter that you have different phones to 1 phone line. You should make sure that all the phones are running off the main feed box for your property and not off each other. Check that all the wires are connected in each port and that the phone line running between the phone itself and the feed box does not exceed 50 feet because this can cause the phone to echo or not work at all.
Every time I print or receive a fax, it kicks me off of the internet.? PLEASE HELP!! Thank you :)
Try it:1..Telephone line straight away to system modem line in socket.. from modem line out socket to printer line in socket(marked as box symbol)dont insert tele phone line in phone symbol socket.. 2..Telephone line straight away to printer line in socket.. from extension socket(marked as phone symbol) to system modem line in socket...Note:dont split telephone line like branch.. Describe this issue with telephone operator because of both fax & internet will work in digital signals, result conflict may happen..
Jan 31, 2012 | HP Laserjet CM2320nf All-In-One Color...
Printer kicks me off internet
What does "parallel set on"
helo, check and make sure other phone is not on, looks like it saying that the line is tied up by other phone . If you only have one phone, try disconnecting base from power and remove battery from phone. hope this helps
Jan 28, 2011 | Computers & Internet
When the phone ring, the internet connection is broken. I have filters on all the phones.Can this be a modem problem?
try a separate splitter on the telephone line which is cheap and simple device to split the signal to telephone and modem separately. Also, enable "Tone" mode on the telephone if your telephone system allows.
Mar 14, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
I am considering buying a Nortel T7208 2 Line phone for my home office. I have two separate lines, with two separate numbers. I need a phone that will allow me to plug both lines into the desk top unit. I...
Hi there...
OK, the Nortel T7208 set works only on a Nortel system.
It has only one line cord plugged into it, cause the telephone system can be programmed for more telephone lines and features from the system.
If you want just a home (analog) telephone service; look at Aastra/ Telematrix/ there are others - 2 line sets.
ONLY buy this Nortel set is you have a Norstar system. Otherwise the set will not work for you. It needs a system to run off.
Good luck in your search!
Aug 29, 2009 | Nortel Business Series Terminal T7208 -...
Can Siemens optiPoint 500 phone be used at home
An "Optipoint 500" phone can not be used at home!
It is a digital phone, specifically designed for Siemens digital phone systems. Do not plug it in at home. That could damage the phone or may knock your phone line off.
However you can use a "Optipoint 500 IP" phone at home for voice over IP calls. But this would be connected into your broadband router and would connect via the web to your companys Siemens phone system.
Nov 25, 2008 | Siemens optiPoint 500 Standard Corded...
Hi, I am setting up a canon mp730 for a friend. I have run into a problem with the fax phone line. I have connected the lines correctly to the copier and her answering machine but when I try to use the...
Remove the connection and once again try to re connect the lines between the copier and phone line . You might have some connection . Just give a try .
If this doesnot work . I will let you know how to proceed further .
Oct 12, 2008 | Canon Office Equipment & Supplies
Need to connect ans. machine to single line on a multi line business phone. Help!
Out of box, the AT&T 1738 is designed to operate on a single telephone line. I don't know of any device on the market today that could automatically switch it between multiple telephone lines.
Some options include (in no particular order):
1) Purchasing additional 1738s to cover the other telephone lines.
2) Some cordless telephones on the market are designed to handle 2 telephone lines. Their answering machines will cover both lines. AT&T and Panasonic offer such phones.
3) Check out AT&T's line of NoKSU small office telephone sets. The phones will handle up to 4 telephone lines and 1 model features a built in answering machine. In order for the telephones to function 100% all phones would have to be replaced with the models within the AT&T NoKSU family.
4) If this is strictly a business application, consider purchasing a true business telephone system for the office.
Sep 24, 2008 | AT&T 1738 Digital Answering Machine
Westinghouse Security Systems
an easy fix is to get a dsl filter for your system and reconnect it back up to the telephone line.
http://www.safemart.com/Alarm-System-Essentials/Z-Blocker-Alarm-DSL-Filter-1EZ-A431PJ31X.htm
and no ido not work for Safemart.
if this doesnot help you email me...
mj
Jul 22, 2008 | GE Security Simon 3 Wireless Home Security...
NorStar T7316E Corded Phone Manual
1 you can but it must be done via log on to switch with lap top (you may use handset but very tricky)
2 use feature *4
Speed dial -
using
FEATURE 0
Dial an external telephone number using a two- or three-digit code. There
are two types of speed dial codes: system (01-70 or 001 to 255) and
personal (71 to 94). System speed dial codes can be used from any
display telephone in the system. System speed dial codes are assigned by
your System Administrator.
Personal speed dial codes are used exclusively at your telephone.
To make a call using a speed dial code:
1. Press FEATURE 0.
2. Enter the two- or three-digit code for the number.
Speed dial -
programming
To program personal speed dial numbers:
1. Press FEATURE *4.
2. Enter a two-digit code from 71 to 94.
3. Specify the external line by pressing a line button, a line pool button, or
the intercom button. If you do not specify the external line, the system
automatically chooses a line for the call.
4. Dial the telephone number you want to program (up to 24 digits).
5. Press HOLD.
6. Record the code and number you have just programmed.
Note: You cannot program personal speed dial numbers while another
user is programming your system.
May 15, 2008 | NorStar T7316E Corded Phone
Lands Phones Logo
404 people viewed this question
Top Telemania Lands Phones Experts
Marvin
Marvin
k24674
Are you a Telemania Lands Phone Expert? Answer questions, earn points and help others
