Question about Apple iPod touch Second Gen (8 GB, MB528LL/A) Digital Media Player
Ipod playing too fast
How do I adjust the playback spped? My podcasts are playing at an accelerated speed.
Immediately below the bar showing how far you have gone/how much you have left, note on the left side you have an icon with a number followed by a "x". Tap that until it indicates a white 1x (regular speed) or, if to slow try tapping that an you will see an orange 2x. Your 3rd setting is what you have now and started when you accidently hit the button without meaning to or were aware of.
Posted on May 31, 2013
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
In the play area of the podcast, at the top right just below where the time remaining shows there is a number plus a cross i.e. 1x, 2x etc. press the 2x and it will go to 1/2x and then to 1x. That will set it back to normal speed. Hope this helps.
Posted on Feb 13, 2012
2 Suggested Answers
  • 1099 Answers
SOURCE: playing podcasts fast
With podcasts on the ipod touch you can vary the speed of play. From normal speed to 1.5 times, 2 times and half speed. Just under the play indication is a button which is probably reading 1.5x or 2x press this button and you will be able to change the speed back to 1x. Hope this helps.
Posted on Mar 18, 2010
Ct-720 tape deck pioneer. only plays backwards and quick. speed adjust pot Works but motor doesn't have power and stops. plays in reverse and the playback rev control won't change play direction.
The tape speed is an indication of another problem. Probably the same as all other mechanisms of this type and that is dried up grease and parts that are not moving as they were designed to.
The deck needs to go to a Technician.
Feb 21, 2016 | Audio Players & Recorders
My toyota Tacoma hesitate after reduceing spped from 75 to 65
Carby if its not fuel injected,accelerator pump plunger,or blocked jet.
Jul 20, 2014 | 2001 Toyota Tacoma
My sony cfs-w360boombox plays tape at high speed upon play, normal or high speed poition
there may be 2 possibles
1, the pinch roller is not going down and staying in the fixed when during playback, easy way to check power down the unit, press play and see if it looks firm, it will push back, if working right
if its loose, it may well have come off a little sping, and may well be an easy ish fix, by someone who know about cassette decks,
2, the speed adjustment has failed, there will be an internal speed control, which keeps the playback at a correct speed, if this has failed it may be fixable, but only by someone who can take it to bits and remove and solder a new one in, and they are very small and Sony items i have had have failed on speed control! too for me its a junker box
good luck
Sep 24, 2013 | Sony Boom Box With CD Player & Cassette...
Sir i have bajaj pulsar 150..sir there is a problem in my pulsar that its maximum speed is 60km..i cant go upper then 60km....60km is last spped..whats the problem?
Hi, Samirslike and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichner valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper fuel level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue please visit the websites below. Good luck and have a nice day.
Documents matching bajaj pulsar 150 Scribd
Sep 23, 2012 | 2007 Bajaj Pulsar 150
How can I delete old podcasts from my Nano?
You will need to plug you nano into your computer and open iTunes. Once iTunes has recognized your iPod, click on the iPods name. There should be a page with a picture of your iPod, at the top of that page there will be a tab labeled "Podcasts," click on it. On that page there will be a check box with a drop-down menu, this is where we will change your podcast settings. The drop-down menu controls which podcasts are synced to you iPod:
All - This will sync all of your podcasts whether played or unplayed 1,3,5,10 most recent - this syncs only the (x) most recently added podcasts to your iPod All unplayed - if you have not played the podcast yet iTunes will sync them to your iPod 1,3,5,10 most recent unplayed - syncs the (x) most recently added unplayed podcasts to your iPod 1,3,5,10 least recent unplayed - syncs the (x) oldest unplayed podcasts to your iPod all new - syncs all of the newest podcasts 1,3,5,10 most recent new - syncs the (x) most recent new podcasts 1,3,5,10 least recent new - syncs the (x) least recent new podcast
those last two are a bit confusing, basically if you add a lot of podcasts you can either get the (x) newest of that set or the (x) least newest (hope that makes sense).
The second drop-down menu controls whether those setting apply to every podcast, or only the ones that you select in the menu underneath that.jsimpsonjr_0.png
Apr 01, 2011 | Apple iPod nano
My iPod Touch is speeding up, downloaded podcasts are starting to sound like a chipmunk cartoon. Any ideas?
Mar 26, 2010 | Apple iPod touch
Playing podcasts fast
Mar 18, 2010 | Apple iPod touch
How to set carborator adjustment on Poulan Wild Thing 2375?
hello,the starting point for adjustment screws is 2 turns out.turn in til lightly seated so as not to damage them. there are 2 or more style carbs used on saw,some have plastic caps that need to be removed(a small metal screw used as a corkscrew or pry off) or you need a special tool -splined.set high spped til runs good and back off an 1/8-1/4 turn so you dont burn it up. fine tune low spped so it accelerates when trigger squeezed and re check high speed adjustment.single screw is for idle spped-raises or lowers-if chain turns while at idle back off screw.
mowerman33@verizon.net
Oct 05, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The car did not spped up
Hi there
if you check out your throttle cable make sure that it is not broken in the assembly going to the engine
Feb 15, 2009 | 2003 Toyota Camry
Treadmill speed problems
http://webpages.charter.net/chestnuts/Trimline%20Owner%27s%20Manual-1600-2600-3600-4600.pdf
Nov 26, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Apple iPod touch Second Gen (8 GB, MB528LL/A) Digital Media Player Logo
656 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
