Question about Exercise & Fitness
My Proform cx10i belt is slipping
Sluggish belt slips
SOURCE: i have a proform treadmill that slips as soon as i
There should be adjustment screws on the back left and right sides. The screws will be horizontal with the tread, and probably need an allen wrench to tighten. If the tread runs straight, tighten each side 1/4 turn at a time to keep them even. Check the tread after each adjustment, and stop as soon as the tread quits slipping.
Posted on Sep 09, 2009
SOURCE: belt is slipping on a proform 740cs treadmill.
Similar solution on a ProForm 500i. Symptom was that the belt would slip whenever you'd step down.
Solution was to use an Allen wrench to tighten the bolts at the back (behind) of the running deck. Had to go two full turns. Careful to unplug first, and careful to tighten each exactly the same amount.
Also wiped the parts of the platform I could reach under the belt with vinegar water, since they were gunky.
These two things fixed the problem
Posted on Feb 01, 2010
  • 18 Answers
SOURCE: We have a Proform Sport 1000 treadmill which when
There is a belt between the front roller and the motor (drive belt) that is under the motor hood. The trick is to watch the front roller when you get on the walking belt. If the front roller stops with the walking belt, then the drive belt is loose and needs to be replaced or tightened. If you have already adjusted the walking belt, and you can hear the motor, it's the drive belt. There will be 3 screw on the front of the machine, and a couple of screws under the main frame. Tip the unit over to find the screws, and take off the cover. You'll be able to see where the slip is.
Posted on Mar 10, 2010
bwinton
  • 83 Answers
SOURCE: Belt slipping on treadmill
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
bwinton
  • 83 Answers
SOURCE: treadmill belt slipping
Belt slips when running on treadmill
see the video and proceed according. God bless you
Jan 31, 2013 | Proform XP Weight Loss 620 Treadmill
How do you keep belt from slipping
see the video attached and proceed according. God bless you
Dec 13, 2012 | Proform Crosswalk Advanced 525s Walking...
Proform 360p belts slips
Side to side? Or front to back? If side to side, turn the Allen bolts on both sides of the back of the base the same direction in the opposite way of the slip. If front to back and the machine has been used a lot, the belt is probably stretched and needs to be replaced. See Treadmill Parts for a quote.
Apr 17, 2012 | Proform Exercise & Fitness
When I am walking It feels like the belt is slipping, like it is not tight enough.
check the tension on the w/belt if good or still slipping then its your motor belt
Mar 09, 2011 | Proform CrossTrainer Treadmill
Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Apr 26, 2010 | Treadmill Doctor Proform 622 Exp Treadmill...
Proform Crosswalk Advanced 525X the belt slips and it squeaks when slipping.....I have tried adjusting the end of the belt but that doesnt seem to help
One possibility is the pulley in the front roller.The shaft that goes into the roller slips making the belt seem as if its slipping. To check it it requires tmarking both surfaces with paint and then see if the mark seperates.
Nov 30, 2009 | Proform Crosswalk 500 Treadmill
My 525x slips. Which part typicaly causes this?
This usually caused by a slipping drive motor belt. remove the hood cover, one screw in rear and 2 on the bottom. There will be an adjustable bracket on the drive motor. Good luck, Tim
Nov 05, 2009 | Proform Crosswalk 500 Treadmill
Proform Crosswalk Dual Motion Cross Trainer Treadmill. motor works great. Rubber on right side under the moving belt has come off so belt slips when in use
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
Belt is slipping
your macnine needs some maintenance. slippage on the proform is usually due to a worn out front roller and a worn motor driving the belt. both can be replaced. or you may want to find a good used one as many get no use before the optomististic owner decides to sell.
Aug 17, 2009 | Proform CrossTrainer Treadmill
Exercise & Fitness Logo
57 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
