Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Self cleaning oven problems - Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
  • 2 more comments
  • Michael Thomas
    Michael Thomas Feb 13, 2012
    Hello there and welcome to fixya Can you please fill me in  on the problem that you are experiencing so i can further assist you  on this problem okpost me your problem Best regards MIke
  • angel4375
    angel4375 Feb 14, 2012
    my range is 9yrs old my door wont shut . i think i had it on self cleaning my door locked i got it open nowe it wont shut it has a dr code i cant use my oven
  • Michael Thomas
    Michael Thomas Feb 14, 2012
    Hello there again
    Thanks for the reply
    Ok this is a door lock error code now it could be a simple fix
    What you are going to have to do is to unplug the oven and leave it sit for at least 1 hour this is very important the reason is that these ovens have a self reset feature on them and it takes the full hour ( no less) to reset then after the hour is up plug in the oven and you may hear a click sound or a audiable beep if so great simply press the cancle button or your button that you normally use to turn off the oven then try to unlock the oven door or youmay have to try to relock and unlock it then it should be ok from there ok?
    Please comment back to me on how this is going ok?
    Best regards MIke
  • Michael Thomas
    An error has been detected by the control. Most error codes are generated as a result of irregularities in the power supply or usage. Error codes can often be resolved by removing power to the appliance for a minute and then restoring the power.
    Note: By unplugging the appliance it allows the control to receive a fresh supply of power. This in turn will clear the controls memory of any irregularities it may have received from the power supply. Once refreshed the error should no longer be displayed.
    Unplug the unit or turn the circuit breaker off for 60 seconds.
    Restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
    Check to see if the error code is still displayed on the range.
Need cleaning instructions for tappan self-cleaning oven model number TEF351EWE
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 24, 2011 | Tappan 30IN ELEC IGNa Oven
Have Whirlpool self clean electric oven model # F368LXKQ. Am trying to self clean-get a F5E1 or FSE1 error code and it will not start to self clean/heat. Any idea what the problem is?
heatman101
Jan 19, 2011 | Whirlpool Ovens
I Need directions to use self cleaning oven.
heatman101
Jan 15, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
How do I use the self cleaning feature on a GE Self Cleaning oven model VJ33VWLW-3?
heatman101
Jan 09, 2011 | Ovens
How do you turn on the self cleaning oven
heatman101
Dec 26, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door will not lock for self cleaning
heatman101
Nov 29, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
30 " self cleaning oven,
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Need to know how to set self cleaning ge p7 self cleaning oven
heatman101
Sep 24, 2010 | GE Ovens
I need instructions to start up the self cleaning for a Refridgeadaire Gallery self cleaning convection oven
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 14, 2010 | Ovens
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
42 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
