Question about Miele Vacuums
I have an old Miele canister vacuum and I do not know how to disassemble the hose to check for a clog. I think it sucked up a nerf ball the size of a ping pong ball. I changed the bag but it did isn't appear to be in the bag. The vacuum powers on but I do not have suction with the hose, and since the hose has hard plastic elbow joints I do not want to pry them apart and break it
    Genius:
  • 1,739 Answers
Hi Emily: If you have the model number for your machine you may be able to find your manual on the Miele website. Check here for older models Here for newer models.
In trying to isolate the clog it would be best to disassemble the wand and hose to more easily isolate the problem. If the problem is a ball it is quite likely lodged at the first elbow
Generally, to detach the suction hose from the canister press the release buttons at the sides of the elbow and lift the hose from the socket.
To release the handpiece from the wand, press the locking button and pull the handpiece away from the wand. Similarly if your unit has a floorbrush this can be detached by pressing the locking button and pulling the wand out of the floor brush.
You may need to insert a wire from the canister end to push out the clog or ball opposite to the direction it was sucked in.
If these directions are not helpful and you cannot locate the manual for your model, please reply with your model number as I may be able to locate it from other sources.
Thank you for using FixYa!
Posted on Feb 13, 2012
  • Emily Jean Feb 13, 2012
    Thanks, I saw the little rectangular locking buttons but not being an octopus it was hard/impossible to hold each end taut and depress the locking buttons to release them AND swivel the pieces apart to separate them. It is a two person job and one must be over age seven. I thank you for your communique to assure me that is how it should be done. Nerf ball lodged precisely in elbow and I used a wire brush designed for cleaning turkey basters to dislodge the little ******. And now I have downloaded the manual in order to have that resource available. It is amazing how the Miele can work so well even after years if it is properly maintained.
Suction not working. Opened machine and dirt is not going into the bag even though it is empty. Inside of machine is dirty.
Check that the hose is not plugged. If you hang it over a railing, then look down into it, you won't need a second person. Alternately drop a golf ball or a marble through it. If the ball makes it through, then it can't be clogged.
Mar 08, 2015 | Miele S548 Bagged Canister Vacuum
My Miele vacuum's hose has stopped sucking-help!!
Sounds like you might have something caught in it. If you have another vacuum with a hose, use that machine to suck out the clog in your Miele hose.
Sep 06, 2014 | Vacuums
Miele not sucking
1. Check if the bag is full. Yes. Change bag.
2. Check the head. Clean head.
3. Object stuck in the hose. remove hose from the vacuum. Remove extensions from the Head end. Poke garden hose down the hose from the handle end.
4. If all else fails. Read the destructions.
Jul 05, 2014 | Miele S318 Bagged Canister Vacuum
Why miele s8 vacuum does not suck well
Try taking it apart and see if their is an obstruction.
www.mieleusa.com/service/index.asp
Jun 26, 2014 | Miele S8 UniQ S8990 Canister HEPA Vacuum...
It seems like the hose might be clogged. How do I get possible blockage out? The hose is so long - too long for a wire hanger to reach all the way through.
put a golf ball through it or if that is to big get a smaller heavy ball bearing put in hose and hold hose up until it passes thru
Dec 11, 2009 | Miele S246i Bagged Canister Vacuum
Dirt Devil Upright Bagless Vibe Vacuum no longer sucks
Sounds like there's a clog in the long hose that connects to the dirt canister. Remove the hose completely and check for clogs. There is a blue plastic piece that the hose is attached to. You can remove it by taking out the two screws in the back, and the four screws behind the dirt canister. Once those are removed, the hose comes away from the vacuum with the blue plastic piece attached. That should allow you to check for clogs. If necessary, take the hose outside or a place that is well lit, so you can visually verify the absence of clogs.
Mar 09, 2009 | Dirt Devil M087700SV Bagless Upright...
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Clog in handle/hose
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113654&thid=579130
Clog in handle/hose
Posted by TCow on May 08, 2008
Small rubber ball got sucked up and is caught in the handle or hose. How can I take it part to remove the object?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. in some cases the Electrolux handle will come apart but id not then I use a couple of methods, if you have another canister vacuum or shop vac then turn on the Electrolux and the other canister vacuum and try to pull the ball out one way or the other. Or you can use a wire coat hander and create a little hook on the end and insert it into the handle portion of the vacuum to see if you can pull out the ball or loosen it so that it will roll out. One other choice that id you have a long small broom handle the length of the hose or longer and then you can push the ball out but the handle has to be smaller than the size of the inside of the hose and also be VERY CAREFUL… because it is an electric hose and it is very expensive so if you cannot remove the small ball bring it to a local vacuum cleaner dealer or the absolute last resort is to replace the hose, but most clogs can be removed. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Go Ahead. Use Us.
May 08, 2008 | Electrolux Guardian Bagged Canister Vacuum
Kenmore Cannister Vacuum Model 26312
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=109396&thid=552260
Kenmore Canister Vacuum Model 26312
Posted by Alecia Rojas on Apr 28, 2008
Kenmore 23612 Progressive PowerMate Canister Vacuum
Vacuum is not sucking. It is just over a year old.
It sounds like you have a clogged hose or a full bag, or dirty filter. The best way to check your electric hose id to run a marble or steel ball thru the hose and if it goes thru all the way then check the bag and filter, most times it is the vacuum hose. If it id the hose you can try to pull apart the clog from both ends using another central or canister vacuum. If not and the ball stops mid way thru the hose then you can use a broom handle with a round hook on the end so that it does not puncture the hose is any place and the round hook can loosen or break up your clog and then your suction will return, if you poke a hole in the vacuum hose there are repair kits that go on the outside of the hose that will slide over the hose and then you use a heat gun and shrink the hose repair kit down to size therefore plugging the leak. (Hose repair kit). So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuums Logo
117 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
