Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
My hard drive no longer indicates motion of light going round. Plus receiver won't recognize driver.
My receiver does not recognize drive. The indicator blue light usually goes round and round when dive is powered up. That no longer happens. The light stops after powered up in a frozen position.
  • SimpleTech Master
  • 27,725 Answers
Make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
http://www.ebay.com.au/itm/280406610810?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
$2.37 + $2.61 postage worldwide
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
$10.65 free postage
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
http://www.paypal.com/
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps you
Posted on Feb 14, 2012
Testimonial: "Yes, but the problem persist. My hardrive needs to be replaced since it no longer is recognized nor does it function properly as when working. Thanks for your help. Much appreciated. Rodger"
Motion sensor outdoor light won't go off
How long has this been going on? Has this light fixture been updated recently? Has the lite switch been changed that operates this fixture?
Feb 23, 2013 | Cooper Lighting regent light BRZ Motion...
My laptop stop recognizing my external harddrive
chances are its no good , external HDDs in plastic cases don't last very long , its the constant plugging in and unplugging plus any wretching
will cause it to break , I myslef have 3 of them that no longer work
ranging from those reasons .
Feb 23, 2013 | Antec Computers & Internet
A8VE-SE won't recognize SATA HDD
If you are trying to install Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Jan 08, 2013 | VIA Asus A8v-e Se Socket 939 Pci-e K8t890...
Pxe e61
You have a hard drive problem. The bios is going through the boot order, looking for a bootable device, it is not recognizing the hard drive as bootable so it moves on to pxe....a network boot. Bottom line....make sure the hard drive is all plugged in. Find out the make....and go to the manufacturer's website....download the ISO to make a bootable diagnostic cd.....and do a quick test, then a long test of the hard drive. If it passes, you make have to re-install the operating system. Sometimes you need to load sata drivers to recognize the disk, but not usually with most newer stuff (unless it asks for the driver during the install, won't see any hard drive). So I would find out if the hard drive is any good, or not. If you cannot find the diagnostic you could try seatools which works on most hard drives, but its best to use the one for that hard drive.
Here's the link for seatools:
http://www.seagate.com/support/downloads/seatools/?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD
Jun 25, 2012 | Acer Aspire 5738Z-423G32Mn Notebook
Pavillion P6000 won't recognize any drives
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 15, 2012 | HP Computers & Internet
Bios hard disk not recognize
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 04, 2012 | Computers & Internet
I have just received the hard drive casings ECS_U35K. I followed instructions. I cannot get Windows 7 to recognize this drive. Any help would be much appreciated.
Sabrent website indicates that this enclosure is compatible with your operating system
http://www.sabrent.com/category/hard-drive-enclosures/ECS-U35K/
this is just an enclosure and you have to put in your hard drive in it.
Supports Standard Desktop 3.5? SATA/SATA II Desktop Hard Drives.
Supports hard drives up to 2TB.
Ultra Light Aluminum Case provides heat dissipation.
On/Off power switch.
LED light indicates Power and Activity status.
Hot-swappable, plug and play, no drivers needed.
Reverse compatible with USB 1.1.
Sep 14, 2011 | Televison & Video
My mac no longer recognized the drive. When it is attached it makes a clicking sound.
Clicking means a dead hard drive, usually the controller board is bad, but most shops won't repair this, hopefully it's under warranty.
Jun 10, 2011 | Hitachi Retail 0s02520 500 Gb External...
Computer not recognizing external HD
1st try a different computers make sure its not your Hard drive!
2nd if that works then go to the hard drive maker and download a software driver for it that should fix the problem
Aug 10, 2009 | SmartDisk FireLite 40 GB Hard Drive
My computer no longer recognizes my Maxtor One Touch III Firewire 400/USB 2.0
go to my computer proeprty then uninstall usb driver and then right clik any driver then clik on scan for hardware then it searches usb and install automatically.
May 22, 2009 | Maxtor One Touch III 500GB FireWire/USB2.0...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
332 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
