Question about Garden
Mower recoil rivets - Garden
5 Suggested Answers
  • 78 Answers
SOURCE: Recently, the rope recoil mechanism on my lawnboy
Im sorry but it sounds like the spring has broken. So I am not that familiar with Lawnboy but some rewinder are not serviceable and the whole housing has to be replaced .
Posted on Oct 22, 2009
rycgl
  • 1545 Answers
SOURCE: trying to change a pull rope on a 6hp tecumsah
No nuts are underneath the rivets. If you want, you can drill the rivets out and replace them with bolts, lockwashers and nuts. I would recommend taking that entire assembly off if you go that route.
Posted on Sep 15, 2010
Knucklebstr
  • 222 Answers
SOURCE: I have a BRIGGS AND STRATTON QUANTUM XTS 60 push mower and have broken the starting cord. Can you advise how to replace. It would appear that the recoil section of the starter is pop rivetted onto the
NO! Do not drill out the rivets. You need to remove the entire blower cover with 4 bolts (2 up front, 2 in back)
I'm going to link you to my two favorite "How-To" videos. Depending on your machine, one of these will show you enough to do it yourself. Once you do one, You'll be a pro. Just make sure you use enough rope and do not wind the spring too tight or you'll break it;
Video 1: http://www.youtube.com/watch?v=GyjQir3b3xI
Video 2: http://www.youtube.com/watch?v=i3ZMVFi0yqY
Best of Luck to you.
James
Posted on Nov 11, 2011
  • 6468 Answers
SOURCE: removing recoil assembly on Lawn Boy 20" mower. Appears to be riveted on. Do I need to snap rivets?
you can drill them out and replace when done or remove the whole cover and repair the recoil on the cover bolts and lock nuts can replace them if you must take it off just make sure they don't hit the flywheel
Posted on Aug 21, 2012
Have a Excell 2300psi pressure washer. Pull cord
yes very short ones. or pop rivet back on . easy and inexpensive
Oct 11, 2014 | Garden
Removing recoil assembly on Lawn Boy 20" mower. Appears to be riveted on. Do I need to snap rivets?
Aug 20, 2012 | Briggs & Stratton Garden
I need to replace the pull string on my toro personal pace mower. The toro part appears to be riveted to the body of the mower. All other mowers the part you need to remove to attach the pull string to is...
If I'm not mistaken, I had one like this once. I think when you purchase the new one, it comes with screws. You have to drill out the rivets to replace the recoil assembly. Try calling to purchase a new assembly and question them.
Gary
Jun 07, 2011 | Toro Power Lawn Mower
Trying to change a pull rope on a 6hp tecumsah engine,& it looks like there are rivets holding the recoil-part atop a heavy metal cowling. do i have to take off that entire piece; are there nuts...
Sep 15, 2010 | Briggs & Stratton Garden
I have a toro personal pace gts self propelled. only model number i foind was 2h802. pull cord broke, would like to know how to replace it
You can buy the whole part...cord,handle,recoil spring all in one piece and remove the old install the new...or you can just buy a legth of pull cord and swap everything over.
First take off the top 4 phillip screws and remove the plastic cover....don't forget to pull off the oil fill cap, next drill out the center of the three pop rivets that hold the recoil spring in place, use a drill bit a little smaller than the rivet, next tap the rivet out using a punch and a hammer, next install the pull chord by first rewindind the coil spring then locking it oin place so it wont twist back and install the new line(pull cord)...next install it on the top of the motor and install 3 new 1/4" aluminumn pop rivets 3/8" long with a pop rivet gun all can be purchased atb Ace Hardware...reinstall the reverse of dismantle proceedure and happy mowing...don't forget to attach the black plastic/rubber pull cord handle.
Happy Mowing!!
Jul 22, 2010 | Toro Garden
Pull string won;t recoil
The recoil spring has broken. These are available at any lawn mower parts supply store. The process of changing the spring is tedious but can be done by anyone with average mechanical ability. If you removed the recoil assy (and air shroud if it is riveted on) and took the assembly to a Lawn Mower Repair shop usually they will change out the spring while you wait. If you can't get the recoil assy off take the mower with you to the repair shop. Again most shops will fix it while you if wait but if they are very busy usually they are serviced within 24 hours.
If you do attempt this yourself check in the tips section of FixYa on how to change the recoil stater rope after replacement of the spring.
I highly recommend you replace the pull rope at the time of the recoil spring replacement.
One final note... there is a possibility that the pull rope spool has been damaged where the spring attaches.
Thanks for using FixYa,
Kelly
Apr 28, 2010 | Mtd 22" Yard Machine Push Mower
Recently, the rope recoil mechanism on my lawnboy mower would not recoil completely or not at all. I removed the complete recoil assembly and the rope in order to rewind the coil, which appeared to be...
Oct 22, 2009 | Garden
How to change the pull starter cord.
drill out rivets then re-rivet or use self tapping screws
Oct 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Replace pull rope
Yes, take the shroud off that the recoil is riveted to
Apr 15, 2009 | Mtd 22" Yard Machine Push Mower
Broken recoil on 10 briggs the recoil rivets came out of housing
I have had the same problem and use a pop rivet gun with steel rivets when reassembling the housings. Frequently these rivets get loose, & need drilled out & changed. I am assuming that the rivet holes in the housing are not elongated or you might have to drill to the next larger size rivet to install them. Hope this helps you, Rick
Apr 11, 2009 | Briggs Electrical Supplies
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
