Question about Canon imageRUNNER 5000 Copier
Problem with Canon imageRUNNER 5000 Copier E000061-0101
checkitright
  • 1362 Answers
SOURCE: canon ir6000 error codes E000061-0001..
E061 Specific potential is not required or the limiter is activated as the potential is controlled.
I beleive it is the Potential of the "drum sensor"
there is a sensor that reads the drum and adjust the machine, this may need to be adjusted, cleaned or replaced. Has to be done by a tech.
Posted on Aug 25, 2008
  • 523 Answers
SOURCE: Making a Canon Imagerunner 400S a network printer
connect network cable from the machine to the switch or router, and give ur machine ip address compitable with ur network, then load the driver on ur computer and u will be fine.
Posted on Jul 06, 2009
randula7
  • 78 Answers
SOURCE: my copier canon IR6000 shows error code E000061-0001. plaese help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} E061
Main Cause The laser shutter is faulty. The laser unit is faulty. The potential measurement
PCB is faulty. The DC controller PCB is faulty.
Mode of
Detection
0001 As the result of potential control, the drum surface potential (VL2)
of the white background is about 200 V (generating solid black images).
0002 The primary charging output used for print output and the drum
surface potential after laser output has been made are about 200 V
Posted on Sep 08, 2009
PATHAMPAD
  • 25 Answers
SOURCE: how do i disable sleep mode in canon imagerunner
I dont know to disabling sleep mode
but I know extent it go
(*) timer setting > auto sleep time >extent maximum 4 hour
Posted on Nov 04, 2009
canontech
  • 1219 Answers
SOURCE: Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
Hi, the waste toner is located inside drum unit.
When you open the front cover and left sideway door, realese blue handle, and pull out the drum unit ( may be little dificult to pull out - but pull harder ).
On the top of drum unit there is cork, remove it and vacume the waste toner out.
Put it back and it will work.
Posted on Jul 07, 2010
There is an error in our canon imagerunner 5000 M/c.
clear problem description is half of the solution. please describe your problem clearly ,thanks.
Jan 04, 2011 | Canon imageRUNNER 5000 Copier
Can I use the software that I have for an ImageRunner 5570 for an ImageRunner 5000?
unfortunatly no you can't. the software is more like firmware it is good ONLY for the machine that it was desinged for. unfortunatly thats the way canon desinged them. the 5570 thou simular to the 5000 the control boards are a 3rd generation board and completly different
Jun 11, 2010 | Canon imageRUNNER 5000 Copier
ImageRUNNER 5000 Copier: I own a Ir 5000 and i just started getting "tire t...
Try to clean corona wires, pick up, feed and separation rollers, check drum cleaning blade and fixing assy.If the tracks are white, check also the toner unit
May 17, 2010 | Canon imageRUNNER 5000 Copier
ImageRUNNER 5000 Copier: how to set a password for ir 5000...
under User mode ( round button with * ), choose ID management. The rest is yust the reading from panel.
Pls. rate
May 05, 2010 | Canon imageRUNNER 5000 Copier
How do i disable sleep mode in canon imagerunner 5000?
Nov 02, 2009 | Canon imageRUNNER 5000 Copier
E000001-0000 error code
it s a thermistor problem
to clear the error do the following.
press additionel functionel* button & press 2&8 at a time &press additionel functionel button* select COPIER>FUN CTION>CLEAR>ERROR>OK.
Aug 06, 2008 | Canon imageRUNNER 5000 Copier
Problems Printing from PC to Copier
What type of driver are you using? Postscript or PCL? Are you printing over TCIP port or a direct connection like a USB? Are there any updates for the Imagerunner since you bought it? They release updates like microsoft releases updates. Also what type of operating system do you have?
Aug 06, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
521 people viewed this question
old marine
old marine
